Issue with Delete & reconnect where flow loops back
This is a simple flow to implement a queue.
An example of usage is for a batch SQL insert, where "Protracted processing" sends batches to the database. The queue ensures that the batches are inserted in the right order.
If you highlight limit and flush nodes, right click and "Delete & reconnect" (to remove the queue mechanism) it retains the loop back wire, an illegal connection from a node to itself.
I'd say that NR is doing what its been asked to do :slight_smile:
Technically there is nothing invalid with what it has done - it has removed the nodes as you've requested and maintained the connections that were there.
It is not 'illegal' to wire a node to itself; it's a valid thing to if, for example, your Function node is iterating over a list of items.
But the editor will not permit wiring a node's output directly to it's own input.
I don't understand your example: to iterate over a list of items we have the for loop, etc.
You are right - my mistake. Please raise an issue - we shouldn't have an editor action that allows you to get into that state.
This was discuss before and we asked for this behaviour to remain , some of us use this behaviour and like to loop back without extra nodes.
