I'm having an issue with the TypedInput widget in the "Select multiple items from a list of options" variant. The Problem is when I initially open the edit page of my node the dropdown shows e.g. "4 Selected" which is the correct number of selected options. After the dropdown opens and closes without changing the selection the string changes to "0 Selected".
I'm not sure if this is a bug or if I'm doing something wrong in my code.
Anyone else who experienced something similar or can help with this issue?
Thanks in advance!
test.js:
module.exports = function (RED) {
"use strict";
function TestNode(config) {
RED.nodes.createNode(this, config);
this.lines = (config.lines || "").split(",").filter(Boolean);
this.on("input", function (msg, send, done) {
send(msg);
// Once finished, call 'done'.
done();
RED.nodes.registerType("test-node", TestNode);
test.html
<!-- Test Node -->
<script type="text/html" data-template-name="test-node">
<div class="form-row">
<label for="node-input-name"><i class="fa fa-tag"></i> <span data-i18n="node-red:common.label.name"></span></label>
<input type="text" id="node-input-name" data-i18n="[placeholder]node-red:common.label.name">
</div>
<div class="node-row-lines">
<label for="node-input-zone">Test selection</label>
<input type="text" id="node-input-test" style="width: 300px;">
</div>
</div>
</script>
(function () {
RED.nodes.registerType("test-node", {
category: "Test",
color: "#FFFFFF",
defaults: {
name: { value: "" },
test: { value: "0,1,2,3" },
inputs: 1,
outputs: 1,
label: function () {
return this.name || "Test node";
labelStyle: function () {
return this.name ? "node_label_italic" : "";
oneditprepare: function () {
$("#node-input-test").typedInput({
types: [
value: "test",
multiple: "true",
options: [
{ value: 0, label: "Test 0" },
{ value: 1, label: "Test 1" },
{ value: 2, label: "Test 2" },
{ value: 3, label: "Test 3" }
</script>
