typedInput multiple checkBox list
Hi all, I am attempting to make a dropdown checkbox list for a contrib nodes option ui.
I have sped a good deal of time trying to make it look part of node-red & went to the source of typedInput (packages\node_modules\@node-red\editor-client\src\js\ui\common\typedInput.js) for style references - low and behold in the typedInput src i see...
if (opts.multiple) {
  cb = $('<input type="checkbox">').css("pointer-events","none").data('value',opt.value).prependTo(op).on("mousedown", function(evt) { evt.preventDefault() });
... seems to support check box list?
I have tried for a couple of hours ...
$list.typedInput({default:["options"], types:["options"], type:choiceArray}, {multiple:true});
$list.typedInput({default:"options", types:["options"], type:[{value:"opt1",multiple:true]});
$list.typedInput({default:["options"], types:choiceArray, {multiple:true});
...and about 10 other attempts - but cannot seem to get it right. :frowning:
I've tried searching node-red source for typedInput & multiple but cant find any examples.
I've tried searching the forum for typedInput & multiple but cant find any examples.
I've checked documentation too
anyone have a snippet I can borrow please?
I don’t have code at hand, but have you checked the code for the catch and status nodes? I last read it half a week ago and I think I remember it being an editable list too.
The multiple choice option is used in the subflow properties UI where you can pick what type of input is displayed for a given property.
Thanks Nick (and @afelix)
Just found it 5 mins ago & got it working.
Last problem.
Scenario
  • When building the rows in an editableList - each row has 1 dropdown and 3 typedInput widgets.
  • At runtime, when the dropdown is changed, the typed widgets need to be shown/hidden accordingly
  • This means I need to be able to address the actual typedInput to call show/hide functions.
The problem
It seems the invocation of typedInput doesnt return a reference to the newly created typedInput, nor do custom classes get applied - making it somewhat difficult to show/hide the typedInput
the question(s)
  • Is it possible at invocation to specify a class (or ID) (for later access to the typedInput via a selector)
    or
  • Is there a function or call to the widget available to retrieve the associated typedInput?
Additional info & stuff I've tried...
After instantiating a typedWidget I try to show() / hide() it but it doesnt work as the instance/object returned from the invocation of the typedWidget is the original <input>.
The only workaround I have found is clunky (below is a handful of things I have tried and finally the workaround on the last line) ...
var payloadField = $('<input/>',{class:"node-input-payload",type:"text",style:"margin-left:7px; width:calc(23% - 16px);", placeholder: 'payload', value:option.payload || ""}).appendTo(div);
// $("node-input-payload")  refers to the original payloadField input
var payloadTypedInput = payloadField.typedInput({default:'str',types:['flow', 'global', 'str', 'num', 'bool', 'json', 'bin', 'date', 'env']});
// payloadTypedInput === payloadField  - meaning I dont have a ref to the typedInput
// PROOF: payloadTypedInput.is(payloadField) returns true :(
// So the next line actually adds the custom accessor class to the input not the widget.
payloadTypedInput.addClass("a-class-name-i-can-use-later-for-accessing-this-widget")
// payloadField.typedInput().option is null
// payloadField.typedInput("option","class", "my-class") doesnt work
// payloadField.typedInput( "option", "classes", "my-class" ) doesnt work
// payloadField.typedInput( "option", "css", "my-class" ) doesnt work
//Finally, the workaround - access the sibling div
var actualTypedInput = payloadField.find("+ div.red-ui-typedInput-container")
actualTypedInput.addClass("a-class-name-i-can-use-later-for-accessing-this-widget")
I have noted in the JQuery widget factory documentation, you should be able to add classes at widget creation time so I tried...
  classes: { "red-ui-typedInput-container":"node-input-payload-typed-input" },
... but that doesnt work (or likely, I'm doing it wrong).
I'm likely missing something simple here - anyone know how to handle this scenario better than retrieving the widget via a sibling selector?
ok, I found it by accident
after much ado, showing and hiding a typednput is as simple as ...
payloadField.typedInput("show");
payloadField.typedInput("hide");
