Hello Guys,
Hope everyone is well, I wonder if some one could assist me here, apologies in advance I'm very new to coding function nodes.
Im in the process of trying to turn my dumb paper shredder into a somewhat smart device so I can trigger proactive alerts when the device needs to be serviced.
In order to achieve this I need to work out the the time in seconds between when the machine is running and when it shuts off. Ive kind of got what I need but the formatting isn't correct.
My current flow will trigger when the device power consumption is over a set value, the flow injects a timestamp when it starts, it then waits for the power consumption to drop and then my function node works out of the time between the start and finish timestamps.
The code below seems to work however I producing an example output of -13.972
so my questions are:
1.) Im unsure why it is returning a negative value and how would I change it so the output is 13.972
2.) How would I then adapt my code so it rounds to the nearest second? in this example 14
var starttime = msg.starttime;
var diffMS = starttime - Date.now();
var diffS = diffMS / 1000;
msg.usage = diffS;
Thanks in advance.
