Issues on new project
Creating my first project (WIN 10).
I can do Pull updates, but Push fails. Here the log:
2020-02-23T10:04:14.508Z Pull changes : http_github/master
2020-02-23T10:04:14.520Z git -c credential.helper= -c user.email="marco.sillano@gmail.com" -c user.name="msillano" pull http_github master
2020-02-23T10:04:15.586Z [err] From https://github.com/msillano/NiMH_charger_logger
2020-02-23T10:04:15.586Z [err]  * branch            master     -> FETCH_HEAD
2020-02-23T10:04:15.736Z [out] Merge made by the 'recursive' strategy.
2020-02-23T10:04:15.795Z [out]  LICENSE | 1 -
2020-02-23T10:04:15.795Z [out]  1 file changed, 1 deletion(-)
2020-02-23T10:04:15.804Z rc=0
2020-02-23T10:04:58.240Z Push changes : http_github/master
2020-02-23T10:04:58.548Z git -c credential.helper= push http_github HEAD:master --porcelain
2020-02-23T10:04:59.385Z [err] bash: /dev/tty: No such device or address
2020-02-23T10:04:59.401Z [err] error: failed to execute prompt script (exit code 1)
2020-02-23T10:04:59.401Z [err] fatal: could not read Username for 'https://github.com': No error
2020-02-23T10:04:59.411Z rc=128
Where I make error ??
Best regards.
m.s.
Hi Marco, welcome to the forum.
You are not doing it wrong. It is an issue specific to Git for Windows. As far as I know (but maybe I am mistaken) it is unresolved. As a workaround you can push to Github from the command line.
This issue has been discussed before in this forum.
Thanks... Beg pardon for the duplicated issue :frowning_face:
Windows is not very loved (with reason) by node developers! :disappointed_relieved:
Update:
Tested CMD: it worked. I will create a BAT for it. Thanks.
Best regards.
m.s.
