Issues passing variable to data field? ("None for dictionary value")
I’m trying to pass generated R G B values to an action node and ending up with “None for dictionary value”
I’ve posted my flow below - having read around it looked like it might have been an issue with putting it all together initially which was being interpreted as a string rather than a list (src)
So to try and tackle the issue I’ve split out my R G B values and trying to pull them into the data field as separate payloads. But still getting the error
I’m wondering if it’s as simple as the way I’m trying to grab the payload values is incorrectly?
I've tried every variant I can think of tho, so something still seems off...
Can anyone assist?
[{"id":"405c45f5.97d48c","type":"function","z":"3aa4bb1d045b93c0","name":"change rgb","func":"var i = flow.get(\"i\");\nvar red   = Math.round(Math.sin(0.3*i + 0) * 127 + 128);\nvar green = Math.round(Math.sin(0.3*i + 2) * 127 + 128);\nvar blue  = Math.round(Math.sin(0.3*i + 4) * 127 + 128);\n\ni++;\nif (i>=32) {\n    i = 0;\n}\n\nflow.set(\"i\", i);\n\nmsg.payload = {};\nmsg.payload.data = {};\nmsg.payload.data.rgb_color = \"[\" + red + \", \" + green + \", \" + blue + \"]\";\nmsg.payload.data.r = red;\nmsg.payload.data.g = green;\nmsg.payload.data.b = blue;\n\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":690,"y":320,"wires":[["93f6beb4.23847","6401153b187820c9"]]},{"id":"c0a79053.feb99","type":"inject","z":"3aa4bb1d045b93c0","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":360,"y":320,"wires":[["af891aa6.6452f8"]]},{"id":"af891aa6.6452f8","type":"function","z":"3aa4bb1d045b93c0","name":"set var","func":"flow.set(\"i\", 0);\n\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":530,"y":320,"wires":[["405c45f5.97d48c"]]},{"id":"93f6beb4.23847","type":"delay","z":"3aa4bb1d045b93c0","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":700,"y":400,"wires":[["405c45f5.97d48c"]]},{"id":"6a933fa0.e02d5","type":"api-call-service","z":"3aa4bb1d045b93c0","name":"Cycle","server":"3aa13fed.bf745","version":7,"debugenabled":false,"action":"light.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["light.0xa4c138710fc49807"],"labelId":[],"data":"{\"rgb_color\": [msg.payloadr, msg.payloadg, msg.payloadb]}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"light","service":"turn_on","x":1110,"y":340,"wires":[[]]},{"id":"6401153b187820c9","type":"change","z":"3aa4bb1d045b93c0","name":"","rules":[{"t":"set","p":"payloadr","pt":"msg","to":"payload.data.r","tot":"msg"},{"t":"set","p":"payloadg","pt":"msg","to":"payload.data.g","tot":"msg"},{"t":"set","p":"payloadb","pt":"msg","to":"payload.data.b","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":320,"wires":[["6a933fa0.e02d5","8a58af81d8c0283e"]]},{"id":"8a58af81d8c0283e","type":"debug","z":"3aa4bb1d045b93c0","name":"debug 21","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payloadr","targetType":"msg","statusVal":"","statusType":"auto","x":1080,"y":220,"wires":[]},{"id":"201e0e17a4b81d6f","type":"inject","z":"3aa4bb1d045b93c0","name":"","props":[{"p":"rese","v":"","vt":"date"},{"p":"reset","v":"reset","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":470,"y":400,"wires":[["93f6beb4.23847"]]},{"id":"3aa13fed.bf745","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
Solving my own problem... managed to get things set as a list prior to the final node
[{"id":"405c45f5.97d48c","type":"function","z":"3aa4bb1d045b93c0","name":"change rgb","func":"var i = flow.get(\"i\");\nvar red = Math.round(Math.sin(0.3*i + 0) * 127 + 128);\nvar green = Math.round(Math.sin(0.3*i + 2) * 127 + 128);\nvar blue = Math.round(Math.sin(0.3*i + 4) * 127 + 128);\n\ni++;\nif (i>=32) {\n i = 0;\n}\n\nflow.set(\"i\", i);\n\nmsg.payload = {};\nmsg.payload.data = {};\nmsg.payload.rgb_color = \"[\" + red + \", \" + green + \", \" + blue + \"]\";\nmsg.payload.data.r = red;\nmsg.payload.data.g = green;\nmsg.payload.data.b = blue;\n\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":690,"y":320,"wires":[["93f6beb4.23847","6401153b187820c9"]]},{"id":"c0a79053.feb99","type":"inject","z":"3aa4bb1d045b93c0","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":360,"y":320,"wires":[["af891aa6.6452f8"]]},{"id":"af891aa6.6452f8","type":"function","z":"3aa4bb1d045b93c0","name":"set var","func":"flow.set(\"i\", 0);\n\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":530,"y":320,"wires":[["405c45f5.97d48c"]]},{"id":"93f6beb4.23847","type":"delay","z":"3aa4bb1d045b93c0","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":700,"y":420,"wires":[["405c45f5.97d48c"]]},{"id":"6a933fa0.e02d5","type":"api-call-service","z":"3aa4bb1d045b93c0","name":"Cycle","server":"3aa13fed.bf745","version":7,"debugenabled":false,"action":"light.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["light.ethans_desk_leds"],"labelId":[],"data":"{\t \"rgb_color\": msg.payload,\t \"transition\": \"2\"\t}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"light","service":"turn_on","x":1330,"y":320,"wires":[[]]},{"id":"6401153b187820c9","type":"change","z":"3aa4bb1d045b93c0","name":"","rules":[{"t":"set","p":"payloadr","pt":"msg","to":"payload.data.r","tot":"msg"},{"t":"set","p":"payloadg","pt":"msg","to":"payload.data.g","tot":"msg"},{"t":"set","p":"payloadb","pt":"msg","to":"payload.data.b","tot":"msg"},{"t":"set","p":"payloadrgb","pt":"msg","to":"payload.data.rgb","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":320,"wires":[["bb3647d312bd4634"]]},{"id":"201e0e17a4b81d6f","type":"inject","z":"3aa4bb1d045b93c0","name":"","props":[{"p":"rese","v":"","vt":"date"},{"p":"reset","v":"reset","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":330,"y":420,"wires":[["93f6beb4.23847"]]},{"id":"784577a87c936802","type":"debug","z":"3aa4bb1d045b93c0","name":"debug 29","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1060,"y":400,"wires":[]},{"id":"da328edf30b07381","type":"join","z":"3aa4bb1d045b93c0","name":"","mode":"custom","build":"array","property":"payload.data","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","useparts":true,"accumulate":false,"timeout":"1","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":910,"y":380,"wires":[["784577a87c936802"]]},{"id":"bb3647d312bd4634","type":"change","z":"3aa4bb1d045b93c0","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"[$$.payloadr,$$.payloadg,$$.payloadb]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1100,"y":320,"wires":[["b5d146154ebee55a","6a933fa0.e02d5"]]},{"id":"b5d146154ebee55a","type":"debug","z":"3aa4bb1d045b93c0","name":"debug 34","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1340,"y":280,"wires":[]},{"id":"3aa13fed.bf745","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
