Hi folks!
I managed to get input from smart switches and send them via Zigbee2MQTT and Node-RED and OSC / UDP to another app (Cycling '74 Max in my case). You can see how in the attached images.
Now I am trying to control some LED lights in Home Assistant / Node-RED from the other app via OSC / UDP. But I cannot figure out how to separate messages from something like /ha/led01/on and /ha/led02/on to control each individual light
I also tried just using normal messages via UDP set UDP to output a string. And I get a string out from udp in that looks pretty much the same except for an extra comma. But in the debug it says it has some extra 4 index values (in my case 12 instead of 8 for the message /l01/on). If I use an inject node I get 8 index values like I should. And because of this, it is not recognized down the road by other nodes (for example by the change node)
Any idea on how to fix this issues? So firstly how to use OSC to separate the tags. Or how can I get via udp a string with no extra comma and / or without extra 4 index values.
I was thinking as last resort, to extract the extra info from the string but no idea how.
Thank you so much!
