Iterating through message's child array in SQL Query
I need help figuring out how to instantiate a SQL variable with an array value, or find another method to accomplish iterating through a child array within the message. The results from my attempt are producing empty results:
{"jsonVersion":1,"deviceProperties":{"version":{"value":"1.0"},"deviceId":{"value":"a123456789"}},"records":[{"dataType":{"value":"weightMeasurement"},"weight":{"value":12,"unit":"lbs"},"measurementTime":{"value":"2020-07-08 17:39:59"}}]}
Using: node-red-contrib-mssql-plus v0.4.4
Hi, in this scenario, I move the logic outside of SQL and back to node-red.
E.g. your insert data is in an array, send it through a split node, then you will get multiple msgs sent to the SQL node where you would insert each record.
Thank you for the quick response. I'll learn how to split it first then.
