Iteration stops after first loop
I am having some trouble with iteration and for loop. It stops after first loop. Value_Analog has three objects, first is empty (I don't need it). I need this output
Code in function. I am triggering it by inject node.
var Value_Analog = global.get('Value_Analog');
var Pasalintasempty = Value_Analog.shift();//pasalinam empty array elementa
let index = 0;
for (let i = 0; i < Value_Analog.length; i++)
 msg.payload = ([{[Value_Analog[i].Tag_name]: index}])
   index++;
No it iterates over all the array and as it does it overwrites msg.payload each time.
Try
msg.payload[i] = {[Value_Analog[i].Tag_name]: i};
No need for index as i is doing the same thing.
[edit] Make sure you define msg.payload as an array before the loop msg.payload = [];
Thank you, it works now.
