Would someone have a tip for how to change a msg.payload?
For example the msg.payload going into the function block is Boolean True or False. Can I modify the payload to something different?
var payload = msg.payload
if (payload==True){
// JSON PAYLOAD FOR MOTOR ON
msg.payload = {
"address": "12345:2",
"object_type": "analogValue",
"object_instance": "302",
"value": "100",
"priority": "11"
if (payload==False){
// JSON PAYLOAD FOR MOTOR OFF
msg.payload = {
"value": "0",
"priority": "11"
Ultimately this needs to be JSON, would I then feed this output into a JSON block? Thanks for any tips
True is pyhton
true is JavaScript
You need javascript
E1cid
4 September 2021 19:56
3
Yes if you return an object, No if you return a string in json format.
// string in JSON format PAYLOAD FOR MOTOR ON
msg.payload = `{
"value": "100",
"priority": "11"
Gunner
4 September 2021 21:13
4
Isn't this topic about the same thing as your previous one? You started to ask the question there.
Can someone give me a tip on how to incorporate using the UI scheduler node to send out different different JSON payloads that get rolled into the body of an HTTP GET requests?
The equipment that I am scheduling through ui scheduler handles rest API.
For example when UI scheduler node is True from the schedule or the slider I need this JSON payload to start a motor:
"value": "100",
"priority": …
Yes, sorry newbie here. Not sure how ask good questions
thats make sense! Thanks for the Python insight I have learned that first now picking up javascript
