JS make array from object values with "key" filtering
Hi all,
I'm looking to make a array of values from object.
I would like to filter the object keys, to make array only with the desired objects.
I have tested with this code, but something is wrong:
var GlObject=global.get("Objecte")||0;
var uploaditems=[];
for (const property in GlObject) {
    if (Object.keys(GlObject).includes("VOLTATGEL1")){
        //uploaditems.push(GlObject.value);
        uploaditems.push(property); }
global.set("uploaditems",uploaditems);
return {payload:uploaditems};
This is how global object is:
Global Object
Thank you all!
should be
uploaditems.push({[property]: GlObject[property]});
if you wish to return the object
Hi .. What exactly you want to be returned ? The matching key and value pair ?
For example VOLTATGEL1: 400 ?
GlObject = {
     VOLTATGEL1: 400,
     INTENSITATL1: 2,
     POTENCIAL1: 12,
     POTREACL1: 1,
     FACTORPOTL1: 0.95,
     VOLTATGEL2: 405,
     INTENSITATL2: 22,
     POTENCIAL2: 12,
     POTREACL2: 3,
     FACTORPOTL2: 0.96,
     VOLTATGEL3: 399,
     INTENSITATL3: 17,
     POTENCIAL3: 6,
     POTREACL3: 2,
     FACTORPOTL3: 0.89,
     POTENCIAACTIVAIII: 25,
     POTENCIAINDUCTIVAIII: 20,
     POTENCIACAPACITIVAIII: 5,
     COSPHI: 0.85
let result = []
Object.entries(GlObject).forEach( ([key,value]) => {
    if ( key.match(/VOLTATGEL1/) )
        result.push({[key]: value })
msg.payload = result
Test flow :
[{"id":"de91c851.6e103","type":"inject","z":"aa111c28.0194a","name":"trigger","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":280,"y":200,"wires":[["48ada723.4577a"]]},{"id":"48ada723.4577a","type":"function","z":"aa111c28.0194a","name":"","func":"GlObject = {\n     VOLTATGEL1: 400, \n     INTENSITATL1: 2, \n     POTENCIAL1: 12, \n     POTREACL1: 1,\n     FACTORPOTL1: 0.95,\n     VOLTATGEL2: 405, \n     INTENSITATL2: 22, \n     POTENCIAL2: 12, \n     POTREACL2: 3, \n     FACTORPOTL2: 0.96, \n     VOLTATGEL3: 399, \n     INTENSITATL3: 17, \n     POTENCIAL3: 6, \n     POTREACL3: 2, \n     FACTORPOTL3: 0.89, \n     POTENCIAACTIVAIII: 25, \n     POTENCIAINDUCTIVAIII: 20, \n     POTENCIACAPACITIVAIII: 5, \n     COSPHI: 0.85 \n}\n\nlet result = []\n\nObject.entries(GlObject).forEach( ([key,value]) => {\n    if ( key.match(/VOLTATGEL1/) )\n    {\n        result.push({[key]: value }) \n    }\n})\n    \nmsg.payload = result\n   \nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":460,"y":200,"wires":[["b3e46e18.7e1578"]]},{"id":"b3e46e18.7e1578","type":"debug","z":"aa111c28.0194a","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":650,"y":200,"wires":[]}]
Hi @UnborN thanks for your help.
I answer your questions.
The main goal is to filter object keys that contain for example:
VOLT or ENSIT ... I don't know if it is possible.
Sample:
I want to filter in object keys the word containing (ENSIT). How should be the output?
msg2.payload= [2,22,17]
msg2.topic=[INTENSITATL1,INTENSITATL2,INTENSITATL3]
You want the Topic also to be an array ? .. usually in Node-red the msg.topic is reserved to be used as a small description of what the msg is about. It would be better if you returned an array of objects but if you need it this way.
GlObject = {
    VOLTATGEL1: 400,
    INTENSITATL1: 2,
    POTENCIAL1: 12,
    POTREACL1: 1,
    FACTORPOTL1: 0.95,
    VOLTATGEL2: 405,
    INTENSITATL2: 22,
    POTENCIAL2: 12,
    POTREACL2: 3,
    FACTORPOTL2: 0.96,
    VOLTATGEL3: 399,
    INTENSITATL3: 17,
    POTENCIAL3: 6,
    POTREACL3: 2,
    FACTORPOTL3: 0.89,
    COSPHI: 0.85
let payload = []
let topic = []
   if ( key.match(/ENSIT/) )   // regex to match
       payload.push(value)
       topic.push(key)
msg.payload = payload
msg.topic = topic
Or
let GlObject = {
     VOLTATGEL1: 400,
     INTENSITATL1: 2,
     POTENCIAL1: 12,
     POTREACL1: 1,
     FACTORPOTL1: 0.95,
     VOLTATGEL2: 405,
     INTENSITATL2: 22,
     POTENCIAL2: 12,
     POTREACL2: 3,
     FACTORPOTL2: 0.96,
     VOLTATGEL3: 399,
     INTENSITATL3: 17,
     POTENCIAL3: 6,
     POTREACL3: 2,
     FACTORPOTL3: 0.89,
     COSPHI: 0.85
key = "ENSIT";
msg.payload = [];
msg.topic =[];
for(const K in GlObject){ // loop through keys
   if(K.includes(key)){
       msg.payload.push(GlObject[K]);
       msg.topic.push(K);
Thank you all!! SOLVED
