JSON to WLED2 node
can someone tell me, which format must have a json object to send it to a wled2 node to change the brightness or effects?
Thx.
Regards
Hermann
Hi Herman,
this is part of my flow to communicate with WLED. I'm using the WLED mqtt to receive any changes in the setting and than reading via JSON.
I'm using JSON format to send the updated command back to WLED
[{"id":"6de5dd6.2860024","type":"group","z":"b31aa1b9.92df1","name":"weld-TV","style":{"fill":"#d1d1d1","label":true,"color":"#ff0000"},"nodes":["1674e2e0.591bfd","5a31ccd3.5b1094","7ad9698.c98fb98","ead35b6e.b38c68","e18826a5.5c7998","cda22258.49cec","452458d2.d76fb8","5fcfb1af.334f3","75f000f1.f7503","2e635ab7.e359a6","fe7a5fd2.4a477","9b502f94.bcf7d","15419443.1a787c","4dae7400.ff5ffc","57124885.93dcc8","c000bbb5.b91438","8820f03e.dc707","9261b39e.89fe8","aeb740c8.511c7","8693f79a.e83138","46b627ff.346d78","244aa000.429e4","16a5693f.1690e7","b74b410b.92123","ef2f854c.37cd28","699f22f2.24c3fc","c7a13082.5c07c","502911fc.de803","777a63c2.6c986c","c4c5257.321b5d8","74c839f8.d52a38","bf4c3b07.5c0288","507702cf.603aec","8531a4ba.c63028","34cbedc3.e57672","49f58b7c.063614","1759146c.8e007c","f6b747e5.8c5b08","c0f16036.7f38b","bda9fdca.f1fb5","9d618bc3.5df5c8","26605f27.376c","ee2e4d47.41e2e","6c18cd98.b71b84","2fe89291.912bee","859c360b.85a1f8","8132032.1a12d","1d444c23.e8e334","ba65195f.1a5758","e0df2f07.4db61","7e337947.3de2f8","cada5b61.7de888","a2009b3f.5248a8","6fb9b83c.277d78","ab6b7ded.6f854","03fd3fc82f27baf6","51a940abf5ea430c","13e2ec9181749aa9","16c85d8e3b1b5d38"],"x":34,"y":859,"w":1732,"h":662},{"id":"1674e2e0.591bfd","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"seg[0].fx","rules":[{"t":"move","p":"payload.seg[0].fx","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":1120,"wires":[["15419443.1a787c"]]},{"id":"5a31ccd3.5b1094","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"seg[0].sx","rules":[{"t":"move","p":"payload.seg[0].sx","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":1160,"wires":[["8820f03e.dc707"]]},{"id":"7ad9698.c98fb98","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"seg[0].ix","rules":[{"t":"move","p":"payload.seg[0].ix","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":1200,"wires":[["9261b39e.89fe8"]]},{"id":"ead35b6e.b38c68","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"seg[0].ix","rules":[{"t":"move","p":"payload.seg[0].pal","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":1080,"wires":[["4dae7400.ff5ffc"]]},{"id":"e18826a5.5c7998","type":"link in","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"","links":["57b4446e.2639dc","c5204131.d6df8"],"x":555,"y":1100,"wires":[["452458d2.d76fb8"]]},{"id":"cda22258.49cec","type":"link in","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"","links":["94af607.637eea","2886bd5a.6b08f2"],"x":555,"y":1060,"wires":[["5fcfb1af.334f3"]]},{"id":"452458d2.d76fb8","type":"ui_dropdown","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"","label":"Effect","tooltip":"Choose the Color/Animation Effect","place":"Solid","group":"f78cd514.c13198","order":3,"width":0,"height":0,"passthru":false,"multiple":false,"options":[{"label":"Solid xxx","value":0,"type":"num"},{"label":"Blink xxx ","value":1,"type":"num"},{"label":"Breathexxx","value":2,"type":"num"},{"label":"Wipe","value":3,"type":"num"},{"label":"Wipe Random","value":4,"type":"num"},{"label":"Random Colors","value":5,"type":"num"},{"label":"Sweep","value":6,"type":"num"},{"label":"Dynamic","value":7,"type":"num"},{"label":"Colorloop","value":8,"type":"num"},{"label":"Rainbow","value":9,"type":"num"},{"label":"Scan","value":10,"type":"num"},{"label":"Dual Scan","value":11,"type":"num"},{"label":"Fade","value":12,"type":"num"},{"label":"Chase","value":13,"type":"num"},{"label":"Chase Rainbow","value":14,"type":"num"},{"label":"Running","value":15,"type":"num"},{"label":"Saw","value":16,"type":"num"},{"label":"Twinkle","value":17,"type":"num"},{"label":"Dissolve","value":18,"type":"num"},{"label":"Dissolve Rnd","value":19,"type":"num"},{"label":"Sparkle","value":20,"type":"num"},{"label":"Dark Sparkle","value":21,"type":"num"},{"label":"Sparkle+","value":22,"type":"num"},{"label":"Strobe","value":23,"type":"num"},{"label":"Strobe Rainbow","value":24,"type":"num"},{"label":"Mega Strobe","value":25,"type":"num"},{"label":"Blink Rainbow","value":26,"type":"num"},{"label":"Android","value":27,"type":"num"},{"label":"Chase","value":28,"type":"num"},{"label":"Chase Random","value":29,"type":"num"},{"label":"Chase Rainbow","value":30,"type":"num"},{"label":"Chase Flash","value":31,"type":"num"},{"label":"Chase Flash Rnd","value":32,"type":"num"},{"label":"Rainbow Runner","value":33,"type":"num"},{"label":"Colorful","value":34,"type":"num"},{"label":"Traffic Light","value":35,"type":"num"},{"label":"Sweep Random","value":36,"type":"num"},{"label":"Running 2","value":37,"type":"num"},{"label":"Red & Blue","value":38,"type":"num"},{"label":"Stream","value":39,"type":"num"},{"label":"Scanner","value":40,"type":"num"},{"label":"Lighthouse","value":41,"type":"num"},{"label":"Fireworks","value":42,"type":"num"},{"label":"Rain","value":43,"type":"num"},{"label":"MerryChristmas","value":44,"type":"num"},{"label":"Fire Flicker","value":45,"type":"num"},{"label":"Gradient","value":46,"type":"num"},{"label":"Loading","value":47,"type":"num"},{"label":"In Out","value":48,"type":"num"},{"label":"In In","value":49,"type":"num"},{"label":"Out Out","value":50,"type":"num"},{"label":"Out In","value":51,"type":"num"},{"label":"Circus","value":52,"type":"num"},{"label":"Halloween","value":53,"type":"num"},{"label":"Tri Chase","value":54,"type":"num"},{"label":"Tri Wipe","value":55,"type":"num"},{"label":"TriFade","value":56,"type":"num"},{"label":"Lightning","value":57,"type":"num"},{"label":"ICU","value":58,"type":"num"},{"label":"Multi Comet","value":59,"type":"num"},{"label":"Dual Scanner","value":60,"type":"num"},{"label":"Stream 2","value":61,"type":"num"},{"label":"Oscillate","value":62,"type":"num"},{"label":"Pride 2015","value":63,"type":"num"},{"label":"Juggle","value":64,"type":"num"},{"label":"Palette","value":65,"type":"num"},{"label":"Fire 2012","value":66,"type":"num"},{"label":"Color waves","value":67,"type":"num"},{"label":"BPM","value":68,"type":"num"},{"label":"Fill Noise","value":69,"type":"num"},{"label":"Noise 1","value":70,"type":"num"},{"label":"Noise 2","value":71,"type":"num"},{"label":"Noise 3","value":72,"type":"num"},{"label":"Noise 4","value":73,"type":"num"},{"label":"Colortwinkle","value":74,"type":"num"},{"label":"Lake","value":75,"type":"num"},{"label":"Meteor","value":76,"type":"num"},{"label":"SmoothMeteor","value":77,"type":"num"},{"label":"Railway","value":78,"type":"num"},{"label":"Ripple","value":79,"type":"num"},{"label":" Twinklefox","value":80,"type":"num"}],"payload":"","topic":"","x":650,"y":1120,"wires":[["ef2f854c.37cd28"]]},{"id":"5fcfb1af.334f3","type":"ui_dropdown","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"","label":"Pallette","tooltip":"Choose the Color Palette","place":"Default","group":"f78cd514.c13198","order":6,"width":0,"height":0,"passthru":false,"multiple":false,"options":[{"label":"Default xxx","value":0,"type":"num"},{"label":"Random Cycle xxx","value":1,"type":"num"},{"label":"Primary colorxxx","value":2,"type":"num"},{"label":"Based on primary","value":3,"type":"num"},{"label":"Set colors","value":4,"type":"num"},{"label":"Based on set","value":5,"type":"num"},{"label":"Party","value":6,"type":"num"},{"label":"Cloud","value":7,"type":"num"},{"label":"Lava","value":8,"type":"num"},{"label":"Ocean","value":9,"type":"num"},{"label":"Forest","value":10,"type":"num"},{"label":"Rainbow","value":11,"type":"num"},{"label":"Rainbow bands","value":12,"type":"num"},{"label":"Sunset","value":13,"type":"num"},{"label":"Rivendell","value":14,"type":"num"},{"label":"Breeze","value":15,"type":"num"},{"label":"Red & Blue","value":16,"type":"num"},{"label":"Yellowout","value":17,"type":"num"},{"label":"Analoguous","value":18,"type":"num"},{"label":"Splash","value":19,"type":"num"},{"label":"Pastel","value":20,"type":"num"},{"label":"Sunset 2","value":21,"type":"num"},{"label":"Beech","value":22,"type":"num"},{"label":"Vintage","value":23,"type":"num"},{"label":"Departure","value":24,"type":"num"},{"label":"Landscape","value":25,"type":"num"},{"label":"Beach","value":26,"type":"num"},{"label":"Sherbet","value":27,"type":"num"},{"label":"Hult","value":28,"type":"num"},{"label":"Hult 64","value":29,"type":"num"},{"label":"Drywet","value":30,"type":"num"},{"label":"Jul","value":31,"type":"num"},{"label":"Grintage","value":32,"type":"num"},{"label":"Rewhi","value":33,"type":"num"},{"label":"Tertiary","value":34,"type":"num"},{"label":"Fire","value":35,"type":"num"},{"label":"Icefire","value":36,"type":"num"},{"label":"Cyane","value":37,"type":"num"},{"label":"Light Pink","value":38,"type":"num"},{"label":"Autumn","value":39,"type":"num"},{"label":"Magenta","value":40,"type":"num"},{"label":"Magred","value":41,"type":"num"},{"label":"Yelmag","value":42,"type":"num"},{"label":"Yelblu","value":43,"type":"num"},{"label":"Orange & Teal","value":44,"type":"num"},{"label":"Tiamat","value":45,"type":"num"},{"label":"April Night","value":46,"type":"num"}],"payload":"","topic":"","x":660,"y":1080,"wires":[["502911fc.de803"]]},{"id":"75f000f1.f7503","type":"ui_switch","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"","label":"OFF/ON","tooltip":"","group":"f78cd514.c13198","order":1,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"","topicType":"str","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":true,"x":880,"y":980,"wires":[["03fd3fc82f27baf6"]]},{"id":"2e635ab7.e359a6","type":"switch","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"ON","vt":"str"},{"t":"eq","v":"On","vt":"str"},{"t":"eq","v":"on","vt":"str"},{"t":"true"},{"t":"false"},{"t":"eq","v":"OFF","vt":"str"},{"t":"eq","v":"Off","vt":"str"},{"t":"eq","v":"off","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":9,"x":470,"y":980,"wires":[["8132032.1a12d"],["8132032.1a12d"],["8132032.1a12d"],["8132032.1a12d"],["1d444c23.e8e334"],["1d444c23.e8e334"],["1d444c23.e8e334"],["1d444c23.e8e334"],[]]},{"id":"fe7a5fd2.4a477","type":"ui_slider","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"","label":"brightness","tooltip":"","group":"f78cd514.c13198","order":2,"width":0,"height":0,"passthru":false,"outs":"end","topic":"","min":"1","max":"255","step":1,"x":670,"y":1240,"wires":[["777a63c2.6c986c"]]},{"id":"9b502f94.bcf7d","type":"Thing Trigger","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","nodeName":"update","triggerThing":{"path":"name","type":"str","value":"WLED.TV"},"triggerState":"state","triggerTest":null,"ignoreInit":false,"payload":{"type":"state","value":""},"x":110,"y":1200,"wires":[["1674e2e0.591bfd","5a31ccd3.5b1094","7ad9698.c98fb98","c0f16036.7f38b","ead35b6e.b38c68","bda9fdca.f1fb5","9d618bc3.5df5c8","26605f27.376c","6c18cd98.b71b84","2fe89291.912bee"]]},{"id":"15419443.1a787c","type":"rbe","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","x":470,"y":1120,"wires":[["452458d2.d76fb8"]]},{"id":"4dae7400.ff5ffc","type":"rbe","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","x":470,"y":1080,"wires":[["5fcfb1af.334f3"]]},{"id":"57124885.93dcc8","type":"ui_slider","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"","label":"Effect speed","tooltip":"","group":"f78cd514.c13198","order":4,"width":0,"height":0,"passthru":false,"outs":"end","topic":"","min":0,"max":"255","step":1,"x":670,"y":1160,"wires":[["699f22f2.24c3fc"]]},{"id":"c000bbb5.b91438","type":"ui_slider","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"","label":"Effect intensity","tooltip":"","group":"f78cd514.c13198","order":5,"width":0,"height":0,"passthru":false,"outs":"end","topic":"","min":0,"max":"255","step":1,"x":680,"y":1200,"wires":[["c7a13082.5c07c"]]},{"id":"8820f03e.dc707","type":"rbe","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","x":470,"y":1160,"wires":[["57124885.93dcc8"]]},{"id":"9261b39e.89fe8","type":"rbe","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","x":470,"y":1200,"wires":[["c000bbb5.b91438"]]},{"id":"aeb740c8.511c7","type":"ui_iro-color-picker","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","group":"f78cd514.c13198","order":10,"width":6,"height":1,"name":"","label":"Primary","stateField":"payload","enableField":"enable","layoutDirection":"horizontal","widgetIndent":"0","buttonWidth":"0","pickerType":"popupCW","pickerSize":"800","backgroundDim":"50","backgroundColor":"#000000","backgroundVariable":false,"components":[{"options":{"borderColor":"#000000","borderWidth":0,"wheelLightness":true,"wheelAngle":0,"wheelDirection":"anticlockwise","minTemperature":3000,"maxTemperature":6000},"componentId":"picker"},{"options":{"borderColor":"#000000","borderWidth":0,"sliderType":"red","minTemperature":3000,"maxTemperature":6000},"componentId":"slider"},{"options":{"borderColor":"#000000","borderWidth":0,"sliderType":"green","minTemperature":3000,"maxTemperature":6000},"componentId":"slider"},{"options":{"borderColor":"#000000","borderWidth":0,"sliderType":"blue","minTemperature":3000,"maxTemperature":6000},"componentId":"slider"},{"options":{"borderColor":"#000000","borderWidth":0,"sliderType":"saturation","minTemperature":3000,"maxTemperature":6000},"componentId":"slider"}],"format":"hex","outFormat":"rgb","dynOutput":"input:end","outputConfirmed":false,"outputLimit":"10","passthru":true,"topic":"topic","topicType":"msg","iroColorValue":"#000000","x":720,"y":1340,"wires":[["34cbedc3.e57672","859c360b.85a1f8"]]},{"id":"8693f79a.e83138","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"rgb","rules":[{"t":"move","p":"payload","pt":"msg","to":"led","tot":"msg"},{"t":"set","p":"payload.r","pt":"msg","to":"led[0]","tot":"msg"},{"t":"set","p":"payload.g","pt":"msg","to":"led[1]","tot":"msg"},{"t":"set","p":"payload.b","pt":"msg","to":"led[2]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":1340,"wires":[["ab6b7ded.6f854"]]},{"id":"46b627ff.346d78","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"rgb","rules":[{"t":"move","p":"payload","pt":"msg","to":"led","tot":"msg"},{"t":"set","p":"payload.r","pt":"msg","to":"led[0]","tot":"msg"},{"t":"set","p":"payload.g","pt":"msg","to":"led[1]","tot":"msg"},{"t":"set","p":"payload.b","pt":"msg","to":"led[2]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":1380,"wires":[["1759146c.8e007c"]]},{"id":"244aa000.429e4","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"rgb","rules":[{"t":"move","p":"payload","pt":"msg","to":"led","tot":"msg"},{"t":"set","p":"payload.r","pt":"msg","to":"led[0]","tot":"msg"},{"t":"set","p":"payload.g","pt":"msg","to":"led[1]","tot":"msg"},{"t":"set","p":"payload.b","pt":"msg","to":"led[2]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":1420,"wires":[["f6b747e5.8c5b08"]]},{"id":"16a5693f.1690e7","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"state.on","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.on","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1140,"y":980,"wires":[["b74b410b.92123"]]},{"id":"b74b410b.92123","type":"json","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"","property":"payload","action":"str","pretty":false,"x":1390,"y":980,"wires":[["ee2e4d47.41e2e"]]},{"id":"ef2f854c.37cd28","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"seg[0].fx","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.seg[0].fx","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1000,"y":1120,"wires":[["b74b410b.92123"]]},{"id":"699f22f2.24c3fc","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"seg[0].sx","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.seg[0].sx","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1000,"y":1160,"wires":[["b74b410b.92123"]]},{"id":"c7a13082.5c07c","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"seg[0].ix","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.seg[0].ix","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1000,"y":1200,"wires":[["b74b410b.92123"]]},{"id":"502911fc.de803","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"seg[0].pal","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.seg[0].pal","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1000,"y":1080,"wires":[["b74b410b.92123"]]},{"id":"777a63c2.6c986c","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"state.bri","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.bri","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1000,"y":1240,"wires":[["b74b410b.92123"]]},{"id":"c4c5257.321b5d8","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"state.seg[0].col[0]","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.seg[0].col[0]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1090,"y":1340,"wires":[["b74b410b.92123"]]},{"id":"74c839f8.d52a38","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"state.seg[0].col[0]","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.seg[0].col[1]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1090,"y":1380,"wires":[["b74b410b.92123"]]},{"id":"bf4c3b07.5c0288","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"state.seg[0].col[2]","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.seg[0].col[2]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1090,"y":1420,"wires":[["b74b410b.92123"]]},{"id":"507702cf.603aec","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"rgb","rules":[{"t":"move","p":"payload","pt":"msg","to":"led","tot":"msg"},{"t":"delete","p":"payload","pt":"msg"},{"t":"move","p":"led.r","pt":"msg","to":"payload[0]","tot":"msg"},{"t":"move","p":"led.g","pt":"msg","to":"payload[1]","tot":"msg"},{"t":"move","p":"led.b","pt":"msg","to":"payload[2]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":830,"y":1420,"wires":[["bf4c3b07.5c0288"]]},{"id":"8531a4ba.c63028","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"rgb","rules":[{"t":"move","p":"payload","pt":"msg","to":"led","tot":"msg"},{"t":"delete","p":"payload","pt":"msg"},{"t":"move","p":"led.r","pt":"msg","to":"payload[0]","tot":"msg"},{"t":"move","p":"led.g","pt":"msg","to":"payload[1]","tot":"msg"},{"t":"move","p":"led.b","pt":"msg","to":"payload[2]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":830,"y":1380,"wires":[["74c839f8.d52a38"]]},{"id":"34cbedc3.e57672","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"rgb","rules":[{"t":"move","p":"payload","pt":"msg","to":"led","tot":"msg"},{"t":"delete","p":"payload","pt":"msg"},{"t":"move","p":"led.r","pt":"msg","to":"payload[0]","tot":"msg"},{"t":"move","p":"led.g","pt":"msg","to":"payload[1]","tot":"msg"},{"t":"move","p":"led.b","pt":"msg","to":"payload[2]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":1340,"wires":[["c4c5257.321b5d8"]]},{"id":"49f58b7c.063614","type":"link in","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"TV-ON/OFF","links":["398fffd1.88501","8129da3b.b535e8"],"x":275,"y":940,"wires":[["2e635ab7.e359a6","ba65195f.1a5758"]]},{"id":"1759146c.8e007c","type":"ui_iro-color-picker","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","group":"f78cd514.c13198","order":11,"width":6,"height":1,"name":"","label":"Secondary","stateField":"payload","enableField":"enable","layoutDirection":"horizontal","widgetIndent":"0","buttonWidth":"0","pickerType":"popupCW","pickerSize":"800","backgroundDim":"50","backgroundColor":"#000000","backgroundVariable":false,"components":[{"options":{"borderColor":"#000000","borderWidth":0,"wheelLightness":true,"wheelAngle":0,"wheelDirection":"anticlockwise"},"componentId":"picker"},{"options":{"borderColor":"#000000","borderWidth":0,"sliderType":"red"},"componentId":"slider"},{"options":{"borderColor":"#000000","borderWidth":0,"sliderType":"green"},"componentId":"slider"},{"options":{"borderColor":"#000000","borderWidth":0,"sliderType":"blue"},"componentId":"slider"},{"options":{"borderColor":"#000000","borderWidth":0,"sliderType":"saturation"},"componentId":"slider"}],"format":"hex","outFormat":"rgb","dynOutput":"input:end","outputConfirmed":false,"outputLimit":"10","passthru":false,"topic":"topic","topicType":"msg","iroColorValue":"#000000","x":670,"y":1380,"wires":[["8531a4ba.c63028"]]},{"id":"f6b747e5.8c5b08","type":"ui_iro-color-picker","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","group":"f78cd514.c13198","order":12,"width":6,"height":1,"name":"","label":"3rd Color","stateField":"payload","enableField":"enable","layoutDirection":"horizontal","widgetIndent":"0","buttonWidth":"0","pickerType":"popupCW","pickerSize":"800","backgroundDim":"50","backgroundColor":"#000000","backgroundVariable":false,"components":[{"options":{"borderColor":"#000000","borderWidth":0,"wheelLightness":true,"wheelAngle":0,"wheelDirection":"anticlockwise"},"componentId":"picker"},{"options":{"borderColor":"#000000","borderWidth":0,"sliderType":"red"},"componentId":"slider"},{"options":{"borderColor":"#000000","borderWidth":0,"sliderType":"green"},"componentId":"slider"},{"options":{"borderColor":"#000000","borderWidth":0,"sliderType":"blue"},"componentId":"slider"},{"options":{"borderColor":"#000000","borderWidth":0,"sliderType":"saturation"},"componentId":"slider"}],"format":"hex","outFormat":"rgb","dynOutput":"input:end","outputConfirmed":false,"outputLimit":"10","passthru":false,"topic":"topic","topicType":"msg","iroColorValue":"#000000","x":660,"y":1420,"wires":[["507702cf.603aec"]]},{"id":"c0f16036.7f38b","type":"debug","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"update","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":310,"y":1280,"wires":[]},{"id":"bda9fdca.f1fb5","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"seg[0].col[0]","rules":[{"t":"move","p":"payload.seg[0].col[0]","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":330,"y":1340,"wires":[["8693f79a.e83138"]]},{"id":"9d618bc3.5df5c8","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"seg[0].col[1]","rules":[{"t":"move","p":"payload.seg[0].col[1]","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":330,"y":1380,"wires":[["46b627ff.346d78"]]},{"id":"26605f27.376c","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"seg[0].col[2]","rules":[{"t":"move","p":"payload.seg[0].col[2]","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":330,"y":1420,"wires":[["244aa000.429e4"]]},{"id":"ee2e4d47.41e2e","type":"http request","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"TV state","method":"POST","ret":"obj","paytoqs":"ignore","url":"http://192.168.2.33/json","tls":"","persist":false,"proxy":"","authType":"","senderr":false,"credentials":{},"x":1680,"y":980,"wires":[[]]},{"id":"6c18cd98.b71b84","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"on","rules":[{"t":"move","p":"payload.on","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"update","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":310,"y":980,"wires":[["2e635ab7.e359a6","ba65195f.1a5758"]]},{"id":"2fe89291.912bee","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"bri","rules":[{"t":"move","p":"payload.bri","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":310,"y":1240,"wires":[["fe7a5fd2.4a477"]]},{"id":"859c360b.85a1f8","type":"debug","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"rgb out","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":890,"y":1300,"wires":[]},{"id":"8132032.1a12d","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"on","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":650,"y":960,"wires":[["cada5b61.7de888","75f000f1.f7503"]]},{"id":"1d444c23.e8e334","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"off","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":650,"y":1000,"wires":[["cada5b61.7de888","75f000f1.f7503"]]},{"id":"ba65195f.1a5758","type":"debug","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"switch","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":470,"y":920,"wires":[]},{"id":"e0df2f07.4db61","type":"link out","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"","links":["576b642e.09f61c","bed9e93c.762138","a9f09c03c557d453"],"x":1135,"y":940,"wires":[]},{"id":"7e337947.3de2f8","type":"link out","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"","links":["69fd3c4.7e5d4c4","f7987ec2.266f3","d0770649a9cd37e4"],"x":1135,"y":900,"wires":[]},{"id":"cada5b61.7de888","type":"rbe","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","x":810,"y":940,"wires":[["a2009b3f.5248a8"]]},{"id":"a2009b3f.5248a8","type":"switch","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"on","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":990,"y":920,"wires":[["7e337947.3de2f8","4bbddc7e382349eb"],["e0df2f07.4db61","c2013e474bc46143"]]},{"id":"6fb9b83c.277d78","type":"debug","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"rgb","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":610,"y":1300,"wires":[]},{"id":"ab6b7ded.6f854","type":"function","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"rgb","func":"\nvar r=msg.payload.r;\nvar g=msg.payload.g;\nvar b=msg.payload.b;\n\nif (r==0 && g==0 && b==0){\n        msg.payload.r=0;\n        msg.payload.g=0;\n        msg.payload.b=255;\n    }\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":590,"y":1340,"wires":[["aeb740c8.511c7","6fb9b83c.277d78"]]},{"id":"03fd3fc82f27baf6","type":"rbe","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","x":1010,"y":980,"wires":[["16a5693f.1690e7"]]},{"id":"51a940abf5ea430c","type":"link in","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"RGB-IN","links":["67c1081f0ef28b10"],"x":495,"y":1480,"wires":[["16c85d8e3b1b5d38"]]},{"id":"13e2ec9181749aa9","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"state.seg[0].col[0]","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.seg[0].col[0]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1090,"y":1480,"wires":[["b74b410b.92123"]]},{"id":"16c85d8e3b1b5d38","type":"change","z":"b31aa1b9.92df1","g":"6de5dd6.2860024","name":"rgb","rules":[{"t":"delete","p":"payload","pt":"msg"},{"t":"move","p":"rgb.r","pt":"msg","to":"payload[0]","tot":"msg"},{"t":"move","p":"rgb.g","pt":"msg","to":"payload[1]","tot":"msg"},{"t":"move","p":"rgb.b","pt":"msg","to":"payload[2]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":830,"y":1480,"wires":[["13e2ec9181749aa9"]]},{"id":"f78cd514.c13198","type":"ui_group","name":"WLED TV","tab":"6f0c6de7.251c84","order":1,"disp":true,"width":"6","collapse":false},{"id":"6f0c6de7.251c84","type":"ui_tab","name":"WLED","icon":"fa-lightbulb-o","order":13,"disabled":false,"hidden":false}]
this is the part where I read the info from WLED via JSON (you dont need the THING node and can send the paylod directly to the 1st flow above)
[{"id":"1396531ec4faabb0","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"2dcf4eef11960de7","type":"inject","z":"1396531ec4faabb0","name":"","repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":150,"y":120,"wires":[["72907b474170f093","59161a95ee689b86","1bf7783b3cc133be"]]},{"id":"72907b474170f093","type":"function","z":"1396531ec4faabb0","name":"Variables","func":"var wledname = \"wled/tv-light/api\"\nflow.set(\"wledname\", wledname);\n\n//Button ON Colors\nvar ON_foreground = \"black\";\nvar ON_Background = \"lime\";\n\n//Button OFF Colors\nvar OFF_foreground = \"white\";\nvar OFF_Background = \"grey\";\n//--------------------------------------------\nflow.set(\"ON_foreground\", ON_foreground);\nflow.set(\"OFF_foreground\", OFF_foreground);\nflow.set(\"ON_Background\", ON_Background);\nflow.set(\"OFF_Background\", OFF_Background);\nreturn msg;\n\n\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":700,"y":120,"wires":[[]]},{"id":"59161a95ee689b86","type":"http request","z":"1396531ec4faabb0","name":"Effects","method":"GET","ret":"obj","paytoqs":"ignore","url":"http://192.168.2.31/json/effects","tls":"","persist":false,"proxy":"","authType":"","x":370,"y":160,"wires":[["9688282503465a05","6afed4be425375dd"]]},{"id":"1bf7783b3cc133be","type":"http request","z":"1396531ec4faabb0","name":"Palette","method":"GET","ret":"obj","paytoqs":"ignore","url":"http://192.168.2.31/json/palettes ","tls":"","persist":false,"proxy":"","authType":"","x":370,"y":200,"wires":[["5352f54df3c89b37","0e8ec618f2ad6151"]]},{"id":"9688282503465a05","type":"debug","z":"1396531ec4faabb0","name":"Effects","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":690,"y":280,"wires":[]},{"id":"6afed4be425375dd","type":"switch","z":"1396531ec4faabb0","name":"","property":"statusCode","propertyType":"msg","rules":[{"t":"eq","v":"200","vt":"str"},{"t":"eq","v":"EHOSTUNREACH","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":690,"y":160,"wires":[["9bf0285440619560"],[]]},{"id":"5352f54df3c89b37","type":"debug","z":"1396531ec4faabb0","name":"Palette","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":690,"y":240,"wires":[]},{"id":"0e8ec618f2ad6151","type":"switch","z":"1396531ec4faabb0","name":"","property":"statusCode","propertyType":"msg","rules":[{"t":"eq","v":"200","vt":"str"},{"t":"eq","v":"EHOSTUNREACH","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":690,"y":200,"wires":[["4fafa080e32d760a"],[]]},{"id":"9bf0285440619560","type":"function","z":"1396531ec4faabb0","name":"Prep Pulldown","func":"\nmsg.options = [];//create empty array\nfor(let i = 0; i < msg.payload.length; i++){\n    let row = msg.payload[i]; //get the row\n    let opt = {};//make new opt object\n    opt[row] = i;  // fill object for pulldown\n    msg.options.push(opt);//add the opt to array    \n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":920,"y":140,"wires":[["a221500fee41b7b9","641f4941353c4430"]]},{"id":"4fafa080e32d760a","type":"function","z":"1396531ec4faabb0","name":"Prep Pulldown","func":"\nmsg.options = [];//create empty array\nfor(let i = 0; i < msg.payload.length; i++){\n    let row = msg.payload[i]; //get the row\n    let opt = {};//make new opt object\n    opt[row] = i;  // fill object for pulldown\n    msg.options.push(opt);//add the opt to array    \n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":920,"y":200,"wires":[["ce102ecdf2846809"]]},{"id":"a221500fee41b7b9","type":"link out","z":"1396531ec4faabb0","name":"","links":["87d5764b.3bfc28","6d8c78f2.c6d528","e18826a5.5c7998","9a6fd1f9.e5f77","b4ce40c5.17394"],"x":1035,"y":140,"wires":[]},{"id":"641f4941353c4430","type":"json","z":"1396531ec4faabb0","name":"","property":"options","action":"str","pretty":false,"x":1150,"y":140,"wires":[["d9e5da9991fbbbd1"]]},{"id":"ce102ecdf2846809","type":"link out","z":"1396531ec4faabb0","name":"","links":["8d731a0b.92bbe8","7f987368.d363dc","cda22258.49cec","b1939a3c.621bf8","9b1c5357.b70e1"],"x":1035,"y":200,"wires":[]},{"id":"d9e5da9991fbbbd1","type":"debug","z":"1396531ec4faabb0","name":"Effects","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1290,"y":140,"wires":[]}]
additionally the flow to read Palette and Effects from WLED via JSON
Thanks for your answer.
Now i have chnage my setup to use the JSON Version.
Before i use the WLED2 Node, but here i can't send JSON Strings.
Regards
Hermann
