JSONata - $round
I am usinga double query to the influx and I receive two arrays with the values ​​of the two measurements, then convert to JSONata and show it in the chart. (4 values)
I am using the $ round function, for the values ​​in both arrays, for the first one it works well for the second arrays I have an error.
I leave the link: https://try.jsonata.org/M6Gz1Fn7h
thanks
In your data, there are lots of instances where $[3] (and the others) evaluates to null - which $round() does not accept.
You need to decide what you want to do with the null values - do you want to keep them as null or do you want to insert a placeholder value?
The following expression will leave the nulls in place:
            [series[0].values.($boolean($[1])?$round($[1],2):$[1])],
            [series[0].values.($boolean($[2])?$round($[2],2):$[2])],
            [series[1].values.($boolean($[3])?$round($[3],2):$[3])],
            [series[1].values.($boolean($[4])?$round($[4],2):$[4])]
hello
Thanks, yes i want to leave the nulls
Thanks a lot
