Yeah, ok, I have a foreign dark theme installed.
I just updated to the latest version.
Going through the tutorial.
But it is hard to read.
It's the installed theme - yeah?
Make sure you've upgraded the theme as well.
Sorry. Yeah, I'll try that.
Yeah, I am not with it.
I am at the page telling me how to install it and I am not sure from where to run the update command.
.npm, .node-red, home
It's a module just like every other node module you have installed in Node-RED.
Assuming you installed it in .node-red then run the install/update there as well.
I did the first part.
pi@BedPi:~/.node-red $ npm install @node-red-contrib-themes/midnight-red
npm WARN ts-lib-utils@2.2.0 requires a peer of typescript@2 || 3 but none is installed. You must install peer dependencies yourself.
npm WARN tsutils@3.17.1 requires a peer of typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta but none is installed. You must install peer dependencies yourself.
npm WARN type-coverage-core@2.4.1 requires a peer of typescript@2 || 3 but none is installed. You must install peer dependencies yourself.
npm WARN node-red-project@0.0.1 No repository field.
npm WARN node-red-project@0.0.1 No license field.
+ @node-red-contrib-themes/midnight-red@1.5.2
updated 1 package and audited 305 packages in 24.461s
9 packages are looking for funding
run `npm fund` for details
found 26 vulnerabilities (12 moderate, 12 high, 2 critical)
run `npm audit fix` to fix them, or `npm audit` for details
pi@BedPi:~/.node-red $ node-red-restart
Restarted Node-RED
But install/update?
I am also a bit worried about those messages at the bottom about vulnerabilities.
(Someone take me out the back and shoot me. Sorry. I am try to remember things, but I am lacking the context of the last part you said)
Haven't we been here before - Tried to install a third party node and this is what I get
Yes, I am sure we have. CRAFT disease is a bi*ch.
It was said in passing.
I think all is working now. Think: bad use of the word.
Shrug. It is working in the sense I can see things on the screen - remote access.
Now I am stuck how to get the tutorial back so I can determine if anything really did happen.
Click the hamburger top right
Click the version number at the bottom of the dropdown
Click 'Take a tour'
Did that and the colours are still not good.
Ah, I have stuffed something else (or haven't done something else) up.
I muddle through things as I get to them.
Sorry folks for wasting time asking.
