Hello, I am using opc UA client to connect KepserverEX opc server What is procedure to connect kepserverEX to opc ua client?
I would suggest you use " node-red-contrib-opcua" if you are not.
I'm at home presently and I can update you on an example using " node-red-contrib-opcua" with Kepware tomorrow 6/11/21. That is if you have not had success so far.
