Ldap auth how to give cerfificate path
hi team
I am using "node-red-contrib-nr-ldapauth " node for LDAP Authentication and without cetification its working very fine but in PROD Server its comes with certification . i tried to give certificate path its throwing errors so please let me know how to give that path perfectly
Remember to use absolute path names in nodes that use files. That is because working out a node's relative position in the filing system can be a little tricky.
An absolute path starts with a leading / on Linux.
Also, don't be tempted to use the ~/ shortcut as that too may not give you what you expect.
