Continuing the discussion from About the Dashboard category:
Am a beginner learning node-red. I do need help with getting resources on learning how to build a SCADA dashboard
I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
Thanks @Sean-McG I went through that already, This is what i need to build with node-red:
I would like to build a scada system that reads data from a PLC. Display these data to a dashboard. I believe i would need to use an SVG to build the dashabord. I do need all the learning resources i can get
Thanks once again..
The forum has been going for a good few years, so it's an excellent resource.
There is a pretty good chance that anything specific you need has already been asked before.
Break your project into key parts and search for similar questions, I have learned a lot over the years that way.
You could also look at https://flows.nodered.org/ and Share Your Projects - Node-RED Forum for inspiration.
This topic may also be useful as it links to a relevant tutorial. - SCADA in node-red using node SVG
I was slightly wary of suggesting node-red-contrib-ui-svg, as I don't think it's quite ready for Dashboard 2 yet.
That is true - but does show what can achieved. But I'm sure it will be by the time Elvis is ready to enter the building ![]()
