I posted a tutorial about controlling NeoPixels, in Share Your Projects, a couple of years ago.
I used a Wemos D1 Mini, flashed with ESP Easy, as ESP Easy has device drivers for Neopixels built-in, so it's very easy to implement and control the lights using MQTT.
Three things to note about the tutorial.
- The leading slash ( / ) sould be removed in the MQTT references.
- The Wemos works off of 3.3v so for reliable operation you might need a level shifter to drive the 5v strips. You may find the logic-1 level (from the Wemos) is high enough to trigger the Din of the Neopixels so you may get away without a level shifter. More details are in the tutorial.
- Neopixels consume a lot of current and need to be powered from an external power supply.
