Library node set status
Hello
i set a status of a function node for debugging with the command
node.status
how can i do this in a library node?
thank you
Hi @melrose
What is a 'library' node? That isn't a node type I recognise - what module provided it?
hi, i meant a subflow node
In the workspace toolbar you get when editing the subflow template, there's a checkbox to add a Status Output.
Any message you pass to that output will be emitted as the status of the subflow.
https://nodered.org/docs/user-guide/editor/workspace/subflows#status-node
great thanks
