Hi, im pretty new to Node-red, but my goal is to make a light sequence with Philips hue.
The flow works fine untill delay nr 2. Both 10s delays activates almost at the same time, which messes up the sequence. Is there a easy way to solve this?
I'd go this route.
Similar use case here: PCF9685 Dimmen slow
Thanks Jay, tried your tip and it worked out fine! Really appreciate both of your quick replies
Sounds like you had the delay node set to "Delay each message by 10 sec". In this case you will not have a 10 sec delay between messages, but relative to when they were received.
You could try the "Rate Limiting" mode instead -- set it to send 1 msg / 10 sec. Of course, this only works if the elapsed time between msgs is constant. So if you need different lengths of time between msgs, then Jay's example will work for you.
