Light weight cipher for payload protection
Hello! Is it possible to create a lightweight cipher node, for example, a present cipher or a speck cipher in node-red for payload protection?
Protection from what? Corruption? Being peaked in a network?
There is always simple base64 and there are some encrypt/decrypt contrib nodes in the palette that can be installed.
Yeah, I am using MQTT for payload ( image) transfer between raspberry pi and a windows system so base64 is already used. But if we use the base64 everyone can easily convert the code back from base64. And also I tried the encrypt/decrypt node from node-red but they are using AES, DES encryption algorithm so I just want to create something new like present cipher /speck cipher because they use less memory when compared to AES and DES.
Easy enough to do in a function node.
Install generic-speck from npm into your .node-red directory
Add a reference to it in globals in settings.js
Write a function to use it.
(See node-red docs for how to)
Sorry I see this is in the creating nodes category. Are you planning to make a node that does this?
If so, then ignore my previous post about using function node.
Yes. I am planning to create one but I just have a rough idea about the present cipher I need to code it in javascript and need to create a HTML program for the same and also inexperienced in this field. so, any help?
You can use user/pwd authentication in mqtt and only allow the users you want to access the private topics.
Create a new node using the instructions here
What does that mean?
I mean about the HTML file which defines the node's properties, edit dialog and help text
yes I did that
If you have protected it so only permitted users can access the data then why do you need to encrypt it?
If your payloads are small and you are looking for an out of the box solution you could use a json web token encrypt payload on way in and on the way back out.
But the data transfer is through wifi so if a person using a network analyser tool like Wireshark can easily access the data.
Is it possible to encrypt the data using JSON web token in real-time data transmission?.
Easy enough to try...
You could use the below subflow (inline) to tell you how long the operation takes...
https://flows.nodered.org/flow/63f29373e826a9fd4943d679d43e725f
@Steve-Mcl you sparked my interest
[{"id":"9a693308.7ebaf","type":"subflow","name":"flow-timer","info":"","category":"","in":[{"x":80,"y":100,"wires":[{"id":"7fc82258.93e36c"}]}],"out":[{"x":440,"y":100,"wires":[{"id":"7fc82258.93e36c","port":0}]}],"env":[{"name":"name","type":"str","value":"measure","ui":{"icon":"font-awesome/fa-tag","label":{"en-US":"Timer Name"},"type":"input","opts":{"types":["str","env"]}}},{"name":"operation","type":"str","value":"start","ui":{"icon":"font-awesome/fa-cog","label":{"en-US":"Operation"},"type":"select","opts":{"opts":[{"l":{"en-US":"start"},"v":"start"},{"l":{"en-US":"stop"},"v":"stop"},{"l":{"en-US":"msg.topic"},"v":"msg.topic"},{"l":{"en-US":"msg.operation"},"v":"msg.operation"},{"l":{"en-US":"msg.payload"},"v":"msg.payload"}]}}}],"meta":{"module":"node-red-contrib-flow-performance","type":"flow-performance","version":"1.0.1","author":"Steve-Mcl","desc":"Inline flow performance measure node","keywords":"node-red performance","license":"MIT"},"color":"#DAEAAA","icon":"node-red/timer.svg","status":{"x":280,"y":160,"wires":[{"id":"7fc82258.93e36c","port":1}]}},{"id":"7fc82258.93e36c","type":"function","z":"9a693308.7ebaf","name":"do operation","func":"// @ts-ignore\nvar name = msg.perfName || env.get(\"name\");\n// @ts-ignore\nvar operation = msg.perfOperation || env.get(\"operation\");\nvar measures = global.get(\"flow_timers\") || {};\nvar measure = measures[name] || {};\n\nfunction doOp(measure, op){\n    if(operation === \"start\"){\n        measure.start = Date.now();//change to process.hrtime\n        measure.stop = null;\n        measure.durationMs = null;\n    } else if(operation === \"stop\") {\n        measure.stop = Date.now();//change to process.hrtime\n        measure.durationMs = measure.start ? measure.stop - measure.start : null;\n        msg._performance = measure;\n    }\n}\n\n\nif(operation === \"start\"){\n    doOp(measure, operation);\n} else if(operation === \"stop\") {\n    doOp(measure, operation);\n    node.send([null, { payload: { text: name + \": \" + measure.durationMs + \"ms\" }}]);\n} else if(operation === \"msg.topic\") {\n    operation = msg.topic;\n    doOp(measure, operation);\n} else if(operation === \"msg.operation\") {\n    operation = msg.operation;\n    doOp(measure, operation);\n} else if(operation === \"msg.payload\") {\n    operation = msg.payload;\n    doOp(measure, operation);\n} else {\n    return [msg, null];\n}\nmeasures[name] = measure;\nglobal.set(\"flow_timers\", measures);\n\nreturn [msg, null];","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":250,"y":100,"wires":[[],[]]},{"id":"8fa477b0.2bbac8","type":"inject","z":"df3cdacd.dc9198","name":"function","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"function","payload":"function","payloadType":"str","x":430,"y":160,"wires":[["bee75a4f.ee4ba8"]]},{"id":"2be583a4.ba884c","type":"debug","z":"df3cdacd.dc9198","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":930,"y":180,"wires":[]},{"id":"e5ac4683.f614f8","type":"inject","z":"df3cdacd.dc9198","name":"JSONata","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"JSONata","payload":"JSONata","payloadType":"str","x":420,"y":200,"wires":[["bee75a4f.ee4ba8"]]},{"id":"2c44f3c4.ee5efc","type":"switch","z":"df3cdacd.dc9198","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"function","vt":"str"},{"t":"eq","v":"JSONata","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":590,"y":300,"wires":[["80b9b0b2.1dd84"],["6cb64e4a.f6365"]]},{"id":"90fd90b2.99848","type":"function","z":"df3cdacd.dc9198","name":"Native JS Sort","func":"msg.payload.sort((a,b) => {\n    if(a.age < b.age){\n        return -1;\n    }else if(a.age > b.age){\n        return 1;\n    }else{\n        return 0;\n    }\n})\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":940,"y":260,"wires":[["f6181e74.1732a"]]},{"id":"9b6c9c50.0fd5e","type":"change","z":"df3cdacd.dc9198","name":"JSONata sort","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload^(age)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":940,"y":340,"wires":[["617e024.a7ac9fc"]]},{"id":"e6915905.e4b498","type":"comment","z":"df3cdacd.dc9198","name":"measure time it takes for Function node VS JSONata","info":"","x":770,"y":120,"wires":[]},{"id":"bee75a4f.ee4ba8","type":"function","z":"df3cdacd.dc9198","name":"Generate a dataset","func":"var data = [];\n\nfunction randomFloat(min, max) { \n    return Math.random() * (max - min) + min; \n}\nfunction randomInt(min, max) {\n  return Math.floor(Math.random() * (max - min + 1) + min);\n}\nfunction randomBool() {\n  return Math.random() >= 0.5;\n}\n\nvar makeRow = function() {\n    return {\n        \"name\": \"Item \" + (data.length+1),\n        \"gender\": randomBool() == true ? \"male\" : \"female\",\n        \"age\": randomInt(18,75),\n        \"height\": randomInt(18,75),\n        \"lat\": randomFloat(51.0,54.9),\n        \"lon\": randomFloat(-1.8, 1.8),\n        \"friendCount\": randomInt(30,300),\n        \"employmentDuration\": randomFloat(1.0,35.9),\n        \"accessLevel\": randomInt(1,9),\n        \"canEdit\": randomBool(),\n        \"canWrite\": randomBool(),\n        \"dob\": `${randomInt(1930,1999)}-${randomInt(1,12)}-${randomInt(1,28)}`\n    }\n}\n\nfor(let i = 0; i < 1000; i++) {\n    data.push(makeRow());\n}\n\nmsg.payload = data;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":646,"y":180,"wires":[["2be583a4.ba884c","2c44f3c4.ee5efc"]]},{"id":"80b9b0b2.1dd84","type":"subflow:9a693308.7ebaf","z":"df3cdacd.dc9198","name":"","env":[{"name":"name","value":"function","type":"str"}],"x":760,"y":260,"wires":[["90fd90b2.99848"]]},{"id":"f6181e74.1732a","type":"subflow:9a693308.7ebaf","z":"df3cdacd.dc9198","name":"","env":[{"name":"name","value":"function","type":"str"},{"name":"operation","value":"stop","type":"str"}],"x":1120,"y":260,"wires":[["189d3e26.ffd122"]]},{"id":"6cb64e4a.f6365","type":"subflow:9a693308.7ebaf","z":"df3cdacd.dc9198","name":"","env":[{"name":"name","value":"jsonata","type":"str"}],"x":760,"y":340,"wires":[["9b6c9c50.0fd5e"]]},{"id":"617e024.a7ac9fc","type":"subflow:9a693308.7ebaf","z":"df3cdacd.dc9198","name":"","env":[{"name":"name","value":"jsonata","type":"str"},{"name":"operation","value":"stop","type":"str"}],"x":1120,"y":340,"wires":[["7ce9f7fe.b33ed8"]]},{"id":"7ce9f7fe.b33ed8","type":"debug","z":"df3cdacd.dc9198","name":"JSONata","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1280,"y":340,"wires":[]},{"id":"189d3e26.ffd122","type":"debug","z":"df3cdacd.dc9198","name":"function","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1280,"y":260,"wires":[]}]
so bottom line to encrypt a very simple payload the cost is about ~2 ms. Seems ok to me
Sorry :joy::joy::joy:
Did you try sending something larger like an image?
a 20 mb file - so a 50% cost 4 secs to 6 secs
[{"id":"9a693308.7ebaf","type":"subflow","name":"flow-timer","info":"","category":"","in":[{"x":80,"y":100,"wires":[{"id":"7fc82258.93e36c"}]}],"out":[{"x":440,"y":100,"wires":[{"id":"7fc82258.93e36c","port":0}]}],"env":[{"name":"name","type":"str","value":"measure","ui":{"icon":"font-awesome/fa-tag","label":{"en-US":"Timer Name"},"type":"input","opts":{"types":["str","env"]}}},{"name":"operation","type":"str","value":"start","ui":{"icon":"font-awesome/fa-cog","label":{"en-US":"Operation"},"type":"select","opts":{"opts":[{"l":{"en-US":"start"},"v":"start"},{"l":{"en-US":"stop"},"v":"stop"},{"l":{"en-US":"msg.topic"},"v":"msg.topic"},{"l":{"en-US":"msg.operation"},"v":"msg.operation"},{"l":{"en-US":"msg.payload"},"v":"msg.payload"}]}}}],"color":"#DAEAAA","icon":"node-red/timer.svg","status":{"x":280,"y":160,"wires":[{"id":"7fc82258.93e36c","port":1}]}},{"id":"7fc82258.93e36c","type":"function","z":"9a693308.7ebaf","name":"do operation","func":"// @ts-ignore\nvar name = msg.perfName || env.get(\"name\");\n// @ts-ignore\nvar operation = msg.perfOperation || env.get(\"operation\");\nvar measures = global.get(\"flow_timers\") || {};\nvar measure = measures[name] || {};\n\nfunction doOp(measure, op){\n    if(operation === \"start\"){\n        measure.start = Date.now();//change to process.hrtime\n        measure.stop = null;\n        measure.durationMs = null;\n    } else if(operation === \"stop\") {\n        measure.stop = Date.now();//change to process.hrtime\n        measure.durationMs = measure.start ? measure.stop - measure.start : null;\n        msg._performance = measure;\n    }\n}\n\n\nif(operation === \"start\"){\n    doOp(measure, operation);\n} else if(operation === \"stop\") {\n    doOp(measure, operation);\n    node.send([null, { payload: { text: name + \": \" + measure.durationMs + \"ms\" }}]);\n} else if(operation === \"msg.topic\") {\n    operation = msg.topic;\n    doOp(measure, operation);\n} else if(operation === \"msg.operation\") {\n    operation = msg.operation;\n    doOp(measure, operation);\n} else if(operation === \"msg.payload\") {\n    operation = msg.payload;\n    doOp(measure, operation);\n} else {\n    return [msg, null];\n}\nmeasures[name] = measure;\nglobal.set(\"flow_timers\", measures);\n\nreturn [msg, null];","outputs":2,"noerr":0,"initialize":"","finalize":"","x":250,"y":100,"wires":[[],[]]},{"id":"189d3e26.ffd122","type":"debug","z":"bce50b9f.7a7508","name":"Log it","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1280,"y":1380,"wires":[]},{"id":"f6181e74.1732a","type":"subflow:9a693308.7ebaf","z":"bce50b9f.7a7508","name":"stop jwt","env":[{"name":"name","value":"jwt","type":"str"},{"name":"operation","value":"stop","type":"str"}],"x":1140,"y":1350,"wires":[["189d3e26.ffd122"]]},{"id":"617e024.a7ac9fc","type":"subflow:9a693308.7ebaf","z":"bce50b9f.7a7508","name":"stop clear","env":[{"name":"name","value":"clear","type":"str"},{"name":"operation","value":"stop","type":"str"}],"x":1140,"y":1425,"wires":[["189d3e26.ffd122"]]},{"id":"2f4e3a15.2fab26","type":"jwt verify","z":"bce50b9f.7a7508","name":"","alg":["HS256"],"jwkurl":"","secret":"node-red","key":"","signvar":"payload","storetoken":"payload","x":1000,"y":1350,"wires":[["f6181e74.1732a"]]},{"id":"3f0baaf3.68cafe","type":"mqtt in","z":"bce50b9f.7a7508","name":"","topic":"/jwt-test","qos":"2","datatype":"auto","broker":"8d864a45.0e5a9","x":825,"y":1425,"wires":[["617e024.a7ac9fc"]]},{"id":"a62c2bfa.fdde4","type":"mqtt in","z":"bce50b9f.7a7508","name":"","topic":"/jwt-test-token","qos":"2","datatype":"auto","broker":"8d864a45.0e5a9","x":845,"y":1350,"wires":[["2f4e3a15.2fab26"]]},{"id":"8d864a45.0e5a9","type":"mqtt-broker","name":"","broker":"mqtt","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","closeTopic":"","closeQos":"0","closeRetain":"false","closePayload":"","willTopic":"","willQos":"0","willRetain":"false","willPayload":""}]
Not if you use wss or mqtts. I assumed you were doing that already since you are interested in keeping the data private. That with user/pwd access should be able to do everything you need.
But why bother when you can easily use wss or mqtts?
