As a continuation to https://discourse.nodered.org/t/lines-over-a-picture-edit-picture/32567, in node-red-contrib-image-tools is there some straightforward way to draw a diagonal line from a point x1,y1 to x2, y2?
Did you try the suggestions from that post?
What kind of issue are you having?
Set up a small test flow showing what you have done, export it and paste it into a reply.
My bad. Playing with that flow I see it can draw horizontal or vertical lines but not lines at an angle.
Maybe @Steve-Mcl might have a suggestion.
