Linking between multiple flows
Hello, I have created a common Authentication Flow, where all the endpoints before proceeding with its actual task, needs to go through this authentication process and continue if the status of the Authentication Flow is success else return failure response. For this I am using the link in and link out nodes. I need to know how to use them in my flow.
The following is my authentication flow :
[{"id":"3a61fed1.4aa072","type":"tab","label":"Authentication Flow","disabled":false,"info":""},{"id":"4b32e7a4.bdf37","type":"http in","z":"3a61fed1.4aa072","name":"","url":"/secure","method":"post","upload":false,"swaggerDoc":"","x":170,"y":400,"wires":[["a147469f.d5cb5","eac4412f.6ddd1"]]},{"id":"4eeb8722.ec4b4","type":"http response","z":"3a61fed1.4aa072","name":"Failure response","statusCode":"400","headers":{},"x":910,"y":660,"wires":[]},{"id":"1ab8b951.bac427","type":"http response","z":"3a61fed1.4aa072","name":"Match Success Response","statusCode":"200","headers":{},"x":1300,"y":460,"wires":[]},{"id":"5b08a105.205fe8","type":"change","z":"3a61fed1.4aa072","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"token","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":340,"wires":[["1ab8b951.bac427"]]},{"id":"eac4412f.6ddd1","type":"function","z":"3a61fed1.4aa072","name":"query","func":"var DBTOKEN = global.get('spoorsdevconfig').oracledbschema + `.` + global.get('spoorsdevconfig').tableAUTH;\nnode.log(\"DBTOKEN==>\" + DBTOKEN)\nmsg.payload={};\nmsg.payload =  { \n    \"queryName\": \"\",\n    \"msgArray\": [],\n    \"query\": `select * from ` + DBTOKEN + ``\n}\nreturn msg;","outputs":1,"noerr":0,"x":430,"y":400,"wires":[["67d578c6.5c6ac8","136ee21e.f7d966"]]},{"id":"8f994dee.35e378","type":"function","z":"3a61fed1.4aa072","name":"Verifying Token","func":"if (msg.req.headers.clientid && msg.req.headers.authorization) { \n    var dbToken = msg.responsedata[0][2];\n    var dbCId = msg.responsedata[0][0];\n\n    if((msg.req.headers.clientid == dbCId) && \n    (msg.req.headers.authorization === msg.responsedata[0][2]))\n    {\n         msg.statusCode = 200;\n         msg.token = msg.req.headers.authorization;\n         node.log(\"Successfully logged in\")\n         node.send(msg);\n    }\n    else \n    {\n        msg.statusCode = 401;\n        node.log(\"Unauthorized access\")\n        node.send([null, msg]);  \n    }\n }\n else {\n  msg.statusCode = 400;\n  node.log(\"Token Missing\")\n  node.send([null, msg]);\n}","outputs":3,"noerr":0,"x":660,"y":440,"wires":[["4a5771ce.87449"],["74385fba.4bfc1"],["b85b6135.57ba48"]]},{"id":"8c4e53f3.1b051","type":"http response","z":"3a61fed1.4aa072","name":"Match Failure Response","statusCode":"401","headers":{},"x":1050,"y":520,"wires":[]},{"id":"74385fba.4bfc1","type":"function","z":"3a61fed1.4aa072","name":"","func":"var res = {};\n\nres.status = 'Unauthorized access';\n\nres.message = 'Invalid Credentials';\n\nmsg.payload = res;\n\nreturn msg;","outputs":1,"noerr":0,"x":930,"y":440,"wires":[["8c4e53f3.1b051"]]},{"id":"b85b6135.57ba48","type":"function","z":"3a61fed1.4aa072","name":"","func":"var res = {};\n\nres.status = 'Unauthorized access';\n\nres.message = 'Invalid Credentials';\n\nmsg.payload = res;\n\nreturn msg;","outputs":1,"noerr":0,"x":770,"y":560,"wires":[["4eeb8722.ec4b4"]]},{"id":"67d578c6.5c6ac8","type":"debug","z":"3a61fed1.4aa072","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":570,"y":300,"wires":[]},{"id":"2750bf59.4f825","type":"debug","z":"3a61fed1.4aa072","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":555.8333740234375,"y":590.1190795898438,"wires":[]},{"id":"a147469f.d5cb5","type":"debug","z":"3a61fed1.4aa072","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":140,"y":600,"wires":[]},{"id":"cd96fcb9.2b0a6","type":"inject","z":"3a61fed1.4aa072","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":200,"y":240,"wires":[["eac4412f.6ddd1"]]},{"id":"136ee21e.f7d966","type":"oracle-db","z":"3a61fed1.4aa072","name":"","x":520,"y":500,"wires":[["8f994dee.35e378","2750bf59.4f825"]]},{"id":"4a5771ce.87449","type":"JsonWebToken","z":"3a61fed1.4aa072","name":"Decrypt","tokenconfig":"776a7e3c.62f7c8","x":805.2083129882812,"y":322.7083435058594,"wires":[["5b08a105.205fe8"]]},{"id":"1f8dcdec.ef2dc2","type":"link in","z":"3a61fed1.4aa072","name":"","links":["1fdec263.874fd6","60a2cc0a.8b5cbc","696d140.b51dfec","7b7759f1.bae578","8fcb76ed.4c111","95a7a2d6.31c23","97c14d32.aba32","bfde62d4.f388a8","e27f2bfd.b20ad","ee7e67e9.8cdee"],"x":375,"y":160,"wires":[["eac4412f.6ddd1","7400bd3b.dfcf1c"]]},{"id":"7400bd3b.dfcf1c","type":"link out","z":"3a61fed1.4aa072","name":"","links":["7bd15570.9161ec","81e3321a.fd8228","677b3081.c35"],"x":555,"y":100,"wires":[]},{"id":"776a7e3c.62f7c8","type":"JsonWebToken_config","z":"","name":"My Secret Key","secret":"dshjfjkfgi2345ggyhujkdghy58uirjefut7685irofkf/riuhggkoHJKyujk"}]
I am trying to link it to my other endpoints in the following way
[{"id":"659d8993.948e3","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"4b9d564c.8a873","type":"debug","z":"659d8993.948e3","name":"","active":true,"console":"false","complete":"false","x":1130,"y":380,"wires":[]},{"id":"88e3619e.8e1ed8","type":"html","z":"659d8993.948e3","name":"","property":"","tag":".node-red-latest-version","ret":"text","as":"single","x":820,"y":400,"wires":[["4b9d564c.8a873"]]},{"id":"163f2a04.c0dcbe","type":"http in","z":"659d8993.948e3","name":"","url":"https://nodered.org","method":"get","upload":false,"swaggerDoc":"","x":320,"y":400,"wires":[["10b0675b.6d4c81","bfde62d4.f388a8"]]},{"id":"10b0675b.6d4c81","type":"function","z":"659d8993.948e3","name":"Verify Auth","func":"\nif(msg.statusCode == '200'){\n\n   node.send([msg,null]);    \n    \n}else{\n    \n  node.send([null,msg]);  \n  \n}","outputs":2,"noerr":0,"x":550,"y":400,"wires":[["88e3619e.8e1ed8"],["4d01e080.4e68f","8fcb76ed.4c111"]]},{"id":"bfde62d4.f388a8","type":"link out","z":"659d8993.948e3","name":"","links":["1f8dcdec.ef2dc2"],"x":495,"y":280,"wires":[]},{"id":"4d01e080.4e68f","type":"http response","z":"659d8993.948e3","name":"Failure Response","statusCode":"401","headers":{},"x":650,"y":560,"wires":[]},{"id":"8fcb76ed.4c111","type":"link out","z":"659d8993.948e3","name":"","links":["1f8dcdec.ef2dc2"],"x":716.1666259765625,"y":466.16668701171875,"wires":[]}]
Maybe, I am not using the link node properly.
Thanks in Advance.
I cannot import your flows properly (due to the missing links), but this sounds like a good candidate for a subflow. The subflow would handle authentication, connect the rest of your flow to the subflow and if auth success, then the message is passed through. (note that this would work exactly the same as with links, but more condensed).
First off I would name the input output nodes - it makes it easier to connect the right ones.
Secondly, in the 'Authentication Flow' why do you connect the link in to the link out?`
Third, you have three link outs and one link in is that how you are meaning it to be setup?
Yeah Thanks. Can you provide me some links where I can get similar kind of examples? I am new to Node-RED and badly in need of help.
The three link outs is to connect it with my other flows where the authentication to be performed. I am really not sure on how to use it. But, I can tell you my requirement. I wanted all the endpoints that I create to pass through this Authentication process and continue with the job only it passes the authentication. Else give the failure response. For this, which is the best approach? Using a subflow or link nodes?
Thanks :slight_smile:
The idea of a subflow is like this example:
[{"id":"2b06d674.593c62","type":"subflow","name":"authentication","info":"","category":"","in":[{"x":86,"y":154,"wires":[{"id":"2b212201.8faade"}]}],"out":[{"x":306,"y":154,"wires":[{"id":"2b212201.8faade","port":0}]}],"env":[]},{"id":"2b212201.8faade","type":"function","z":"2b06d674.593c62","name":"","func":"m = msg.payload\nif(m==\"accepted\"){\n    return {payload:\"authentication succesfull\"}\n}\nif(m==\"denied\"){\n    return {payload:\"authentication denied\"}\n}\n","outputs":1,"noerr":0,"x":182,"y":154,"wires":[[]]},{"id":"a6268655.38e88","type":"inject","z":"4f1314bf.e449fc","name":"","topic":"","payload":"accepted","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":170,"y":198,"wires":[["6dcc3d96.c4d8d4"]]},{"id":"8086038.262f38","type":"inject","z":"4f1314bf.e449fc","name":"","topic":"","payload":"denied","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":182,"y":242,"wires":[["6dcc3d96.c4d8d4"]]},{"id":"6dcc3d96.c4d8d4","type":"subflow:2b06d674.593c62","z":"4f1314bf.e449fc","name":"","x":378,"y":220,"wires":[["42728432.8111f4"]]},{"id":"42728432.8111f4","type":"debug","z":"4f1314bf.e449fc","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":572,"y":220,"wires":[]}]
The subflow will become a node that you can (re)use.
Thanks @bakman2 , I will try it.
