I'm building a lighting feature that I want to control with an IR remote but haven't found any LIRC input node (something like the serial node would be ideal).
I'll be using a first gen Pi-0 so no BT or WIFI (this will be in the garden and wouldn't be in range of those anyway).
Any thoughts or suggestions would be most appreciated.
Are you sure
Ok,you asked....
If memory serves me, LIRC is an IR application that sends (and receives) IR commands. Typically to a TV/other remote controlled system right? (Thinking back to my XBMC days)
So essentially this could be achieved with standard nodes and a serial node but it's certainly not a simple/beginners task and you wish to provide a nice easy to use interface via custom node(s)? It's certainly a worthy addition IMO.
Perhaps when you get this going you will share what components you used and perhaps a video or something demonstrating it in action?
So to think about how users would provide commands to your LIRC node... Do you intend to have a separate LIRC-CONFIG node where you can select the appliance and a LIRC-OUT node that provides a list of available commands to the a user? Will you add ability for user to send a msg input into the node to trigger LIRC outputs dynamically? Perhaps using the database names like "SRC" "LEFT" "V+" etc?. Would you be introducing the ability for users to send a string of commands like "SRC", "RIGHT", "OK" (like a macro)? With a configurable delay between commands? Also, for more advanced users, the ability to send raw codes and other properties like send_once, send_start, send_stop etc? And permit the user to send these commands dynamically via an input msg? E.g. suppose the user builds a UI simulating a remote control, he may wish to do this by sending varying payloads {object} and)or topics to a single LIRC node?
On the flip side, are you also intending on having a LIRC-IN node where commands can be received by the node-red to provide a means of remote controlling actions (flows)? That would be sweet and possibly a great addition. Picture automation guys being able to pick up any old remote and have node-red do a bunch of tasks based on the input from a spare remote control they have laying around.
Lastly, are you updating the old node-red-contrib-lirc node or is this a new beast? Perhaps you could use it as a base or starting point if not?
