I need to show a list of fixed values as string inputs in the UI of a subflow:
The user should select one out of 10 fixed values for DEVICE, in a dropdown list.
How can I do?
How can I do?
As Bakman says, once you have created the variable, click the down arrow next to its name.
Select 'Select' from the input type dropdown.
Once you have done this, click the furthest right dropdown and you will get an add element ui. Below is an example subflow you can import.
[{"id":"bc04e851.d49ed8","type":"subflow","name":"Subflow 1","info":"","category":"","in":[],"out":[],"env":[{"name":"DeviceNo","type":"str","value":"Dev1","ui":{"icon":"font-awesome/fa-laptop","type":"select","opts":{"opts":[{"l":{"en-US":"Device 1"},"v":"Dev1"},{"l":{"en-US":"Device 2"},"v":"Dev2"},{"l":{"en-US":"Device 3"},"v":"Dev3"}]}}}],"color":"#DDAA99","status":{"x":160,"y":30,"wires":[]}},{"id":"6f86169.b529de8","type":"debug","z":"bc04e851.d49ed8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":360,"y":80,"wires":[]},{"id":"43b1d3cf.f08e5c","type":"inject","z":"bc04e851.d49ed8","name":"","props":[{"p":"payload"}],"repeat":"1","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"DeviceNo","payloadType":"env","x":220,"y":80,"wires":[["6f86169.b529de8"]]},{"id":"1738eaf6.f5d395","type":"subflow:bc04e851.d49ed8","z":"ced96e30.86933","name":"","env":[{"name":"DeviceNo","value":"Dev2","type":"str"}],"x":480,"y":540,"wires":[]}]
