List the db connections in MSSQL-CN
Hello Everyone !
I have quite a few connections in MSSQL-CN, established with databases to use the MSSQL PLUS node.
I would like to regularly check the list of these connections, as well as their properties:
name , server, port, username, and if it is possible the connection status (if the db is reachable or not).
The connection are all on SQL server DB.
After days of research, I still have no clue how to do it ! With a function node ? Or there is an existing node that can do it ?
Any advice will be welcome !
Thanks for your help
You could form a simple query like SELECT @@SERVERNAME as server, SERVERPROPERTY('Edition') AS Edition, GetDate() as serverTime and a whole bunch more
If you get a response, the server is online (full end 2 end check)
If you do not get a response, it is not.
