Listen to all sub-messages on a MQTT path
Im wondering if it is possible to set up an MQTT-in node to listen to a root string url, passing all subsequent actions.
sample:
If i setup my MQTT path as: /level_1/room_1/lights/ceiling and configure my MQTT-in node to /level_1/room_1/ i want to receive all room actions.
Is it possible to subscribe to shortend url's somehow?
Hi @novski
You can use a wildcard subscription to do exactly this.
Subscribe to /level_1/room_1/#
Also if you read through this guide it will tell you virtually all you need to know about MQTT. MQTT Essentials - All Core Concepts explained
It is recommended you do not start a topic with a /
Never use a leading forward slash
A leading forward slash is permitted in MQTT. For example, /myhome/groundfloor/livingroom . However, the leading forward slash introduces an unnecessary topic level with a zero character at the front. The zero does not provide any benefit and often leads to confusion.
