Live Event Viewer in Dashboard
I would like to cherry pick certain events from my flow to populate an event viewer a in the dashboard (100 lines or so). Can anyone point me in the right direction? Thanks in advance
You can use ui-table to display 100 or even 1.000+ lines to the dashboard. Take a look at the ui-table commands example included.
The design of the flow has to altered if you like to record events during the time the table isn’t visible. (I can help you with that if necessary)
Perhaps you like to look here .. could give you a start for your own event viewer:
https://discourse.nodered.org/t/a-syslog-server-for-the-dashboard/24337/2
Thanks, There is a lot more to this than I first imagined!
