I already have an icon saved in /data/static folder and able to open in browser. What should i type at UI Page icon setting to use stored image?
Im using settings.js and enable httpStatic route.
ok, can you access the image in your browser? for example, if your image is named test.png can you access it using the node-red main url + any static path setting + /test.png?
If you are unsure, show us your node-red start up log (it lists out http static entries and the path they will use)
also, which settings.js file have you modified? (full path please)
Yes. I can access image in browser.
Settings.js I only uncomment httpStatic.
Ah, so rereading your first post, the issue isnt hosting/viewing the image, it is setting the pages icon on the side menu? You might have to do this via scripting (in a ui-template) or custom CSS (also in a ui-template).
Do a bit digging in devtools. In the mean time, someone who has time to look into this might pop in with a solution for you.
Okay I managed to using locally stored icon using below command
.v-navigation-drawer--rail .v-list .v-list-item:nth-of-type(2) .v-icon {
background-image: url("/assets/icons/homecustom.png");
background-size: cover;
background-position: center;
background-repeat: no-repeat;
width: 36px !important;
height: 36px !important;
font-size: 0 !important; /* Hide default MDI icon */
color: transparent !important;
