I added a node (s7com) and soon after deleting the same only it is generating a lot of connection failure logs.
Is this normal or has the component been active in some other configuration?
what is the node-red node you installed and deleted?
Did you deploy after deleting the node?
have you tried stop/starting node-red?
Did you check the configuration tab?
The node is s7comm/s7
Yes, i am did deploy after deleting node.
No, i not restart node-red,
In configuration tab the node no show.
so what happens if you restart NR?
After restart NR the erros not show.
The restart resolve the problem.
Thanks.
