Node-RED frequent crashing - "Connection Lost X"
Dear all,
I have been experiencing frequent Node-RED crashings in Industrial Panel PCs (Windows 10 64bit based) that we use to automate different systems. Since Node-RED should be running in the background always, I have added it to the Task Scheduler (Windows accessory) to autorun even the PC restarts. I'm using node-red dashboard for the application.
In the same time I'm using multiple node-red-contrib-s7 nodes to communicate with Siemens PLC S7-1500 that we use to automate industrial applications. I mentioned about the node specially because that node also still has some bugs.
So anyway sometimes node-red showing Connection Lost in the dashboard and when I go to the task scheduler, I can see that node red isn't running. Basically the service stops. Then I can manually restart the node-red but even sometimes its not even restarting. This keeps happening since few weeks back, even upgrading firmware did not help so far.
I guess this can happen due to the miss configuration of node-red-contrib-s7. But I have no clear idea what's going on.
Any suggestion would be really appreciated. If you want more details I can provide.
Jude
Start by checking the node red log to see what is going wrong.
It's hard to say what is causing the "crash", could you please post here your complete flow plus the node-red version, nodes versions, and node-red logs, so that we can help you.
We have more than 150 machines running exactly the same setup (NodeRED + S7 node) 24/7 and never heard about frequent crashes.
oh okay. I will share record logs and all the information you asked.
Thanks for the reply.
Quick update about the crash. It happened due to having multiple IP configurations inside S7 node. I used not to delete old configurations, therefore It keeps crashing node red. When I remove all unwanted configurations that problem solved.
Great that you fixed the problem and also posted the solution here. Thanks!
I see this multiple configuration nodes issue happening very often with people that are just starting with node-red.
Thanks!
