Good evening,
i need to export in a .txt file a long text modified by some funcion.
The example of text is
0
0
0
{{{some var}}}
0
0
0
I've try something like
var a = 0
0
0
0
but this is not correct.
Any ideas?
Thank you!
Good evening,
0
0
0
{{{some var}}}
0
0
0
var a = 0
0
0
0
Any ideas?
Thank you!
I don't fully understand your usecase.
But maybe multiline string formatting does the trick?
msg.payload = `
0
0
${msg.payload}
0
0`;
Thank you walbaer, it words perfectly!
Good evening waldbaer,
i need to ask you something more.
I have file, that i read from "read file" function.
Can i change some line of this text like you did in your example?
I've tried to change the original file with ${variable} in specified point but the result is ${variable} also in the output.
Thank you!
@danieleronchi please provide some more context and concrete function code you are using.
Modifying 'any' line of a parsed file depends on the file content.
Either the content is a parsable format you can parse, modify structured data, export.
Or you know exactly the location you want to modify (e.g. the line number, character number etc).
But a general answer is not possible here if I must assume that you just have a text file with random content. A file ist in principle just a long chain of bytes. Even characters can be encoded with many different encodings etc.
