Looking for a freelancer to update a working flow
Hello All,
I have an existing flow that works, I put it together, but doubt my ability to make an efficient system using nodered.
I am using the hosted flowfuse.
Here is the basic idea (and what I already have):
  • I have many IoT devices setup, and they send data.
  • (in my ui) User sets up "rules". They can say, if Data xyz is over/under/equal to some number then send the data somewhere else (email, sms, discord, http(s), etc...)
In Flowfuse: Data comes in via an MQTT connection, branches 2 directions:
1: stored in the database (data table)
2: alerting flow
The alerting flow does the following:
  • reads the device from the incoming data. (this is free as we need to handle the data anyway)
  • gets the owner of the device (DB Read)
  • gets the rules that the owner setup (DB Read)
  • checks the data against the fules (DB Read)
  • checks the destination the owner setup (DB Read)
  • sends the data (X service write)
  • Save that the alert was triggered OR clears the alert as the data is normal (DB Write)
With all of that in mind, Here is what I want from you! I need someone that can simplify my flow and make it more profecional, or if it is already okay, let me know my work is OK.
If you message me, let me know your current rate and we can chat about a time for you to have a look at the actual system and get a better estimation of what type of work would be involved in this.
Thank you very much,
-Kevin
Hi Kevin,
Your setup sounds like a solid foundation. I can go through the flow, clean it up where needed, and make sure the logic is efficient and maintainable. If everything looks good as is, I will let you know that too.
We can talk through the details whenever you are ready.
You can reach out to me on my email here
Colin
@colin1 I notice that it seems that you have never provided any help to anyone here on the forum, or shared any of your projects with us. In fact the only posts you have ever replied to are those offering paid work. Please correct me if I am wrong.
Hello Everybody!
Thanks to all who messaged. I didn't want to keep anyone wondering what the results of this was..
We found a suitable candidate and will be moving forward with them. If aditional
work is required now or in the future, will will be sure to reach out!
Thanks again!
