I have array of query
I try sent msg.topic to mysql like this
but it send me only one query
How to loop query as msg.topic and send to mysql ?
you can have only 1 return statement in a function.
I assume that query.length comes from msg.query.length.
But in order to send messages within a loop use node.send({ msg.topic: query[i] })
and add return null at the bottom
To make it shorter:
msg.query.forEach(query => node.send({topic: query}))
return null
Not exactly true, you can have many but as soon as one is executed the function node will exit and the flow will move to the next node.
Yes sorry indeed that is a better formulation; return = exit
Kind of weird, because I use that all the time in "guard clauses"
I try 'return exit' 'exit' 'return = exit' and its fault.
What is the correct?
It just means that any return statement will exit the function and / or function node
