M-bus heatmeter problem
Hi have a problem with reading heatmeters.
Installed node-red-contrib-m-bus 2.0.0 and after scanning there are no meters found, when i try scanning it trough rs485 to usb converter and other app, it will find all meters with no problem 11 to be exact.
There is a rs485 to mbus coverter istalled, working with no problem.
Case is urgent.
Any help or pointers will be greatly appriciated.
I want to update on the issue, we can pin down what is wrong, the timeout in the libmbus static library is set to low, when we change it to 1200ms it find all the meters but this is with the manual using libmbus.
How can we change the timeouts in the static library inside the node-red?
