Hi, I'm a lost beginner.
Want to join 14 text input node to an ARRAY to send to an S7 PLC.
ARRAY should be updated immediately when any of the text input node is updated.
ARRAY looks like this:
{"signal":"Av-restid","path":"DB4,DWORD26..13","error":0,"value":[0,27600000,27600000,27600000,27600000,27600000,27600000,27600000,27600000,27600000,27600000,27600000,27600000,27600000]}
[{"id":"4baf23af.ed80f4","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"495d4970.0c4c6","type":"s7comm read","z":"4baf23af.ed80f4","connection":"e971ffef.8d56b8","payload":"{\"S7_Type\":\"DB\",\"S7_DBnum\":\"4\",\"S7_Datatype\":\"D\",\"S7_Offset\":\"26\",\"S7_BitOffset\":\"0\",\"S7_Quantity\":\"14\",\"S7_Name\":\"Av-restid\"}","s7Name":"Av-restid","topic":"","name":"","signalSetted":false,"none":"false","repeat":"7","once":true,"x":85,"y":200,"wires":[["f11c0d23.979ec8","9f44a39.f764c6","95388777.87a83","76eec174.a1b018","f977e8ce.f98c","dacf6b0b.ecb35","daced7d3.c9b27","b3106292.086a6","8783fff0.36791","31f1a15e.99567e","627c9bc5.1bae9c","a642ed10.df5658","bdb27c88.91ea98","764c9d45.7dc9a4"]]},{"id":"30d511f9.c94e56","type":"moment","z":"4baf23af.ed80f4","name":"","topic":"","input":"payload.value[0]","inputType":"msg","inTz":"Etc/UTC","adjAmount":0,"adjType":"days","adjDir":"add","format":"hh:mm","locale":"en_gb","output":"","outputType":"msg","outTz":"Etc/UTC","x":312.5,"y":270,"wires":[["d5f1c400.c5d618"]]},{"id":"d5f1c400.c5d618","type":"ui_text_input","z":"4baf23af.ed80f4","name":"","label":"Måndag tid 1","tooltip":"","group":"38e6ec70.739054","order":2,"width":6,"height":1,"passthru":false,"mode":"time","delay":"100","topic":"1","x":500,"y":270,"wires":[["28c0da12.6312a6"]]},{"id":"d94dd544.9faee","type":"s7comm write","z":"4baf23af.ed80f4","connection":"e971ffef.8d56b8","payload":"{\"S7_Type\":\"DB\",\"S7_DBnum\":\"4\",\"S7_Datatype\":\"D\",\"S7_Offset\":\"26\",\"S7_BitOffset\":\"0\",\"S7_Quantity\":\"14\",\"S7_Name\":\"Av-restid\"}","s7Name":"Av-restid","topic":"","name":"","signalSetted":false,"x":1051.5,"y":206,"wires":[["7a62e813.04bf7"]]},{"id":"e72ea8ec.7de7","type":"function","z":"4baf23af.ed80f4","name":"","func":"var msg_out = {payload:{value:[msg.payload]}};\nreturn msg_out;","outputs":1,"noerr":0,"x":853.5,"y":266,"wires":[["7a62e813.04bf7","d94dd544.9faee"]]},{"id":"f11c0d23.979ec8","type":"moment","z":"4baf23af.ed80f4","name":"","topic":"","input":"payload.value[1]","inputType":"msg","inTz":"Etc/UTC","adjAmount":0,"adjType":"days","adjDir":"add","format":"hh:mm","locale":"en_gb","output":"","outputType":"msg","outTz":"Etc/UTC","x":307,"y":322,"wires":[["71e2995c.7dc9c"]]},{"id":"71e2995c.7dc9c","type":"ui_text_input","z":"4baf23af.ed80f4","name":"Måndag tid 2","label":"Måndag tid 2","tooltip":"","group":"38e6ec70.739054","order":3,"width":6,"height":1,"passthru":false,"mode":"time","delay":"100","topic":"2","x":491.5,"y":321,"wires":[["28c0da12.6312a6"]]},{"id":"166e9c34.f71294","type":"function","z":"4baf23af.ed80f4","name":"","func":"var msg_out = {payload:{value:[msg.payload]}};\nreturn msg_out;","outputs":1,"noerr":0,"x":851,"y":320,"wires":[[]]},{"id":"9f44a39.f764c6","type":"moment","z":"4baf23af.ed80f4","name":"","topic":"","input":"payload.value[2]","inputType":"msg","inTz":"Etc/UTC","adjAmount":0,"adjType":"days","adjDir":"add","format":"hh:mm","locale":"en_gb","output":"","outputType":"msg","outTz":"Etc/UTC","x":305,"y":367,"wires":[["cc65950e.de7d"]]},{"id":"cc65950e.de7d","type":"ui_text_input","z":"4baf23af.ed80f4","name":"","label":"Tisdag tid 1","tooltip":"","group":"38e6ec70.739054","order":4,"width":6,"height":1,"passthru":false,"mode":"time","delay":"100","topic":"3","x":489.5,"y":366,"wires":[["28c0da12.6312a6"]]},{"id":"fc82fc40.25b0c8","type":"function","z":"4baf23af.ed80f4","name":"","func":"var msg_out = {payload:{value:[msg.payload]}};\nreturn msg_out;","outputs":1,"noerr":0,"x":849,"y":365,"wires":[[]]},{"id":"95388777.87a83","type":"moment","z":"4baf23af.ed80f4","name":"","topic":"","input":"payload.value[3]","inputType":"msg","inTz":"Etc/UTC","adjAmount":0,"adjType":"days","adjDir":"add","format":"hh:mm","locale":"en_gb","output":"","outputType":"msg","outTz":"Etc/UTC","x":303,"y":413,"wires":[["7940281c.dd6058"]]},{"id":"7940281c.dd6058","type":"ui_text_input","z":"4baf23af.ed80f4","name":"","label":"Tisdag tid 2","tooltip":"","group":"38e6ec70.739054","order":5,"width":6,"height":1,"passthru":false,"mode":"time","delay":"100","topic":"4","x":487.5,"y":412,"wires":[["28c0da12.6312a6"]]},{"id":"bfa2a6ee.0d8df","type":"function","z":"4baf23af.ed80f4","name":"","func":"var msg_out = {payload:{value:[msg.payload]}};\nreturn msg_out;","outputs":1,"noerr":0,"x":847,"y":411,"wires":[[]]},{"id":"76eec174.a1b018","type":"moment","z":"4baf23af.ed80f4","name":"","topic":"","input":"payload.value[4]","inputType":"msg","inTz":"Etc/UTC","adjAmount":0,"adjType":"days","adjDir":"add","format":"hh:mm","locale":"en_gb","output":"","outputType":"msg","outTz":"Etc/UTC","x":306,"y":455,"wires":[["42cd5cbe.35c94c"]]},{"id":"42cd5cbe.35c94c","type":"ui_text_input","z":"4baf23af.ed80f4","name":"","label":"Onsdag tid 1","tooltip":"","group":"38e6ec70.739054","order":6,"width":6,"height":1,"passthru":false,"mode":"time","delay":"0","topic":"","x":490.5,"y":454,"wires":[[]]},{"id":"af8784d8.9da1a","type":"function","z":"4baf23af.ed80f4","name":"","func":"var msg_out = {payload:{value:[msg.payload]}};\nreturn msg_out;","outputs":1,"noerr":0,"x":850,"y":453,"wires":[[]]},{"id":"f977e8ce.f98c","type":"moment","z":"4baf23af.ed80f4","name":"","topic":"","input":"payload.value[5]","inputType":"msg","inTz":"Etc/UTC","adjAmount":0,"adjType":"days","adjDir":"add","format":"hh:mm","locale":"en_gb","output":"","outputType":"msg","outTz":"Etc/UTC","x":306,"y":492,"wires":[["dddc84d4.2c7818"]]},{"id":"dddc84d4.2c7818","type":"ui_text_input","z":"4baf23af.ed80f4","name":"","label":"Onsdag tid 2","tooltip":"","group":"38e6ec70.739054","order":7,"width":6,"height":1,"passthru":false,"mode":"time","delay":"0","topic":"","x":491.5,"y":491,"wires":[[]]},{"id":"fa5c9c20.c5986","type":"function","z":"4baf23af.ed80f4","name":"","func":"var msg_out = {payload:{value:[msg.payload]}};\nreturn msg_out;","outputs":1,"noerr":0,"x":851,"y":490,"wires":[[]]},{"id":"dacf6b0b.ecb35","type":"moment","z":"4baf23af.ed80f4","name":"","topic":"","input":"payload.value[6]","inputType":"msg","inTz":"Etc/UTC","adjAmount":0,"adjType":"days","adjDir":"add","format":"hh:mm","locale":"en_gb","output":"","outputType":"msg","outTz":"Etc/UTC","x":304,"y":534,"wires":[["d047835c.c53e08"]]},{"id":"d047835c.c53e08","type":"ui_text_input","z":"4baf23af.ed80f4","name":"","label":"Torsdag tid 1","tooltip":"","group":"38e6ec70.739054","order":8,"width":6,"height":1,"passthru":false,"mode":"time","delay":"0","topic":"","x":488.5,"y":533,"wires":[[]]},{"id":"d3e602c4.aa8f","type":"function","z":"4baf23af.ed80f4","name":"","func":"var msg_out = {payload:{value:[msg.payload]}};\nreturn msg_out;","outputs":1,"noerr":0,"x":848,"y":532,"wires":[[]]},{"id":"daced7d3.c9b27","type":"moment","z":"4baf23af.ed80f4","name":"","topic":"","input":"payload.value[7]","inputType":"msg","inTz":"Etc/UTC","adjAmount":0,"adjType":"days","adjDir":"add","format":"hh:mm","locale":"en_gb","output":"","outputType":"msg","outTz":"Etc/UTC","x":304,"y":571,"wires":[["66ffa3e1.e57664"]]},{"id":"66ffa3e1.e57664","type":"ui_text_input","z":"4baf23af.ed80f4","name":"","label":"Torsdag tid 2","tooltip":"","group":"38e6ec70.739054","order":9,"width":6,"height":1,"passthru":false,"mode":"time","delay":"0","topic":"","x":489.5,"y":570,"wires":[[]]},{"id":"fdbe4ce3.12d4a","type":"function","z":"4baf23af.ed80f4","name":"","func":"var msg_out = {payload:{value:[msg.payload]}};\nreturn msg_out;","outputs":1,"noerr":0,"x":849,"y":569,"wires":[[]]},{"id":"b3106292.086a6","type":"moment","z":"4baf23af.ed80f4","name":"","topic":"","input":"payload.value[8]","inputType":"msg","inTz":"Etc/UTC","adjAmount":0,"adjType":"days","adjDir":"add","format":"hh:mm","locale":"en_gb","output":"","outputType":"msg","outTz":"Etc/UTC","x":303,"y":610,"wires":[["65f29c78.bee2ac"]]},{"id":"65f29c78.bee2ac","type":"ui_text_input","z":"4baf23af.ed80f4","name":"","label":"Fredag tid 1","tooltip":"","group":"38e6ec70.739054","order":10,"width":6,"height":1,"passthru":false,"mode":"time","delay":"0","topic":"","x":487.5,"y":609,"wires":[[]]},{"id":"c3e1675c.4625b","type":"function","z":"4baf23af.ed80f4","name":"","func":"var msg_out = {payload:{value:[msg.payload]}};\nreturn msg_out;","outputs":1,"noerr":0,"x":847,"y":608,"wires":[[]]},{"id":"8783fff0.36791","type":"moment","z":"4baf23af.ed80f4","name":"","topic":"","input":"payload.value[9]","inputType":"msg","inTz":"Etc/UTC","adjAmount":0,"adjType":"days","adjDir":"add","format":"hh:mm","locale":"en_gb","output":"","outputType":"msg","outTz":"Etc/UTC","x":303,"y":647,"wires":[["10327704.f44bd1"]]},{"id":"10327704.f44bd1","type":"ui_text_input","z":"4baf23af.ed80f4","name":"","label":"Fredag tid 2","tooltip":"","group":"38e6ec70.739054","order":11,"width":6,"height":1,"passthru":false,"mode":"time","delay":"0","topic":"","x":488.5,"y":646,"wires":[[]]},{"id":"ee1d58f5.d19e78","type":"function","z":"4baf23af.ed80f4","name":"","func":"var msg_out = {payload:{value:[msg.payload]}};\nreturn msg_out;","outputs":1,"noerr":0,"x":848,"y":645,"wires":[[]]},{"id":"31f1a15e.99567e","type":"moment","z":"4baf23af.ed80f4","name":"","topic":"","input":"payload.value[10]","inputType":"msg","inTz":"Etc/UTC","adjAmount":0,"adjType":"days","adjDir":"add","format":"hh:mm","locale":"en_gb","output":"","outputType":"msg","outTz":"Etc/UTC","x":301,"y":689,"wires":[["beebce06.67baf8"]]},{"id":"beebce06.67baf8","type":"ui_text_input","z":"4baf23af.ed80f4","name":"","label":"Lördag tid 1","tooltip":"","group":"38e6ec70.739054","order":12,"width":6,"height":1,"passthru":false,"mode":"time","delay":"0","topic":"","x":485.5,"y":688,"wires":[[]]},{"id":"20918187.9e2d16","type":"function","z":"4baf23af.ed80f4","name":"","func":"var msg_out = {payload:{value:[msg.payload]}};\nreturn msg_out;","outputs":1,"noerr":0,"x":845,"y":687,"wires":[[]]},{"id":"627c9bc5.1bae9c","type":"moment","z":"4baf23af.ed80f4","name":"","topic":"","input":"payload.value[11]","inputType":"msg","inTz":"Etc/UTC","adjAmount":0,"adjType":"days","adjDir":"add","format":"hh:mm","locale":"en_gb","output":"","outputType":"msg","outTz":"Etc/UTC","x":301,"y":726,"wires":[["7cef45fb.905eac"]]},{"id":"7cef45fb.905eac","type":"ui_text_input","z":"4baf23af.ed80f4","name":"","label":"Lördag tid 2","tooltip":"","group":"38e6ec70.739054","order":13,"width":6,"height":1,"passthru":false,"mode":"time","delay":"0","topic":"","x":486.5,"y":725,"wires":[[]]},{"id":"cb420276.b270e","type":"function","z":"4baf23af.ed80f4","name":"","func":"var msg_out = {payload:{value:[msg.payload]}};\nreturn msg_out;","outputs":1,"noerr":0,"x":846,"y":724,"wires":[[]]},{"id":"a642ed10.df5658","type":"moment","z":"4baf23af.ed80f4","name":"","topic":"","input":"payload.value[12]","inputType":"msg","inTz":"Etc/UTC","adjAmount":0,"adjType":"days","adjDir":"add","format":"hh:mm","locale":"en_gb","output":"","outputType":"msg","outTz":"Etc/UTC","x":297,"y":769,"wires":[["749e6bf7.77e004"]]},{"id":"749e6bf7.77e004","type":"ui_text_input","z":"4baf23af.ed80f4","name":"","label":"Söndag tid 1","tooltip":"","group":"38e6ec70.739054","order":14,"width":6,"height":1,"passthru":false,"mode":"time","delay":"0","topic":"","x":481.5,"y":768,"wires":[[]]},{"id":"daf079f0.5ec6","type":"function","z":"4baf23af.ed80f4","name":"","func":"var msg_out = {payload:{value:[msg.payload]}};\nreturn msg_out;","outputs":1,"noerr":0,"x":841,"y":767,"wires":[[]]},{"id":"bdb27c88.91ea98","type":"moment","z":"4baf23af.ed80f4","name":"","topic":"","input":"payload.value[13]","inputType":"msg","inTz":"Etc/UTC","adjAmount":0,"adjType":"days","adjDir":"add","format":"hh:mm","locale":"en_gb","output":"","outputType":"msg","outTz":"Etc/UTC","x":297,"y":806,"wires":[["edccc666.db5418"]]},{"id":"edccc666.db5418","type":"ui_text_input","z":"4baf23af.ed80f4","name":"","label":"Söndag tid 2","tooltip":"","group":"38e6ec70.739054","order":15,"width":6,"height":1,"passthru":false,"mode":"time","delay":"0","topic":"","x":482.5,"y":805,"wires":[[]]},{"id":"4df27d6d.9652ac","type":"function","z":"4baf23af.ed80f4","name":"","func":"var msg_out = {payload:{value:[msg.payload]}};\nreturn msg_out;","outputs":1,"noerr":0,"x":842,"y":804,"wires":[[]]},{"id":"7a62e813.04bf7","type":"debug","z":"4baf23af.ed80f4","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1052.5,"y":127,"wires":[]},{"id":"28c0da12.6312a6","type":"debug","z":"4baf23af.ed80f4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":841.5,"y":115,"wires":[]},{"id":"764c9d45.7dc9a4","type":"debug","z":"4baf23af.ed80f4","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":698.5,"y":27,"wires":[]},{"id":"e971ffef.8d56b8","type":"s7comm","z":"","ip":"192.168.1.86","port":"102","rack":"0","slot":"2","payload":[{"S7_Type":"DB","S7_DBnum":"5","S7_Datatype":"R","S7_Offset":"0","S7_BitOffset":"0","S7_Quantity":"1","S7_Name":"UteTemprtur"},{"S7_Type":"DB","S7_DBnum":"5","S7_Datatype":"R","S7_Offset":"20","S7_BitOffset":"0","S7_Quantity":"1","S7_Name":"Tanktopp"},{"S7_Type":"DB","S7_DBnum":"4","S7_Datatype":"D","S7_Offset":"26","S7_BitOffset":"0","S7_Quantity":"14","S7_Name":"Av-restid"},{"S7_Type":"DB","S7_DBnum":"4","S7_Datatype":"D","S7_Offset":"26","S7_BitOffset":"0","S7_Quantity":"1","S7_Name":"Av-Restidwrite"}]},{"id":"38e6ec70.739054","type":"ui_group","z":"","name":"Default","tab":"a4dc9bca.e6c778","order":2,"disp":true,"width":"6","collapse":false},{"id":"a4dc9bca.e6c778","type":"ui_tab","z":"","name":"Test","icon":"dashboard","order":2,"disabled":false,"hidden":false}]
