Hi krambriw,
Thank you so much for taking the time to build the example, I have tried it, but format must be wrong (I apologies i probabley didnt explain it very well), Artnet is sent via UDP on port 6454, my node has been written on Atmel 328, and thats working fine, I can see how you have done it, defining an array and looping through, makes sense.
When i operated the sliders My Pi (hosting my node red crashed) The error I get from the debug is
8/22/2019, 3:21:25 PMnode: 3088f50e.7a245afunction : (error)
"TypeError [ERR_INVALID_ARG_TYPE]: The "list[1]" argument must be one of type Array, Buffer, or Uint8Array. Received type string"
Below is the my complete flow for testing so you can see for yourself, you can see the sub flow call Artnet, that node does all the work to send out the data.
Heres the full flow for my test.
Regards
Jono
[{"id":"2e555652.746eaa","type":"subflow","name":"Artnet","info":"# Art-Net encoder/decoder\n\nThis sublow is a bi-directional Art-Net encoder/decoder.\n\n## Receiving\n\nConnect a udp in object set to port 6454 to the input of the subflow. \nThe Art-Net data will be output as msg.payload in Buffer form. \nThe universe is available as msg.topic.\n\n## Sending\n\nSend an Array or Buffer to the Art-Net subflow and connect the sublow's output to a udp out object set to port 6454.\nThe universe must be set as msg.topic.","in":[{"x":180,"y":140,"wires":[{"id":"341dd2db.4ed8d6"}]}],"out":[{"x":440,"y":140,"wires":[{"id":"341dd2db.4ed8d6","port":0}]}]},{"id":"341dd2db.4ed8d6","type":"function","z":"2e555652.746eaa","name":"Artnet","func":"const HEADER_SIZE = 18;\nconst ID = "Art-Net\0";\nconst ArtDmxOpCode = 0x5000;\nconst ProtVer = 14;\ncontext.sequence = context.sequence || 0;\nconst Physical = 0;\n\nvar header = new Buffer(HEADER_SIZE);\nheader.fill(0);\n\nheader.write(ID);\nheader.writeUInt16LE(ArtDmxOpCode, 8);\nheader.writeUInt16BE(ProtVer, 10);\nheader.writeUInt8(Physical, 13);\n\n// Parse incoming Art-Net packets\nif (msg.payload.slice(0, 8).toString() == ID) {\n var Opcode = msg.payload.readUInt16LE(8);\n if (Opcode == ArtDmxOpCode) {\n var Universe = msg.payload.readUInt16LE(14);\n var Length = msg.payload.readUInt16BE(16);\n msg.topic = Universe;\n msg.payload = msg.payload.slice(HEADER_SIZE, Length + HEADER_SIZE);\n node.send(msg);\n }\n// Format incoming buffer or array into Art-Net packet\n} else {\n context.sequence++;\n header.writeUInt8(context.sequence, 12);\n if (context.sequence >= 255)\n context.sequence = 0;\n \n var Universe = msg.topic;\n var Length = msg.payload.length;\n if (Array.isArray(msg.payload)) {\n msg.payload = new Buffer(msg.payload);\n }\n header.writeUInt16LE(Universe, 14);\n header.writeUInt16BE(Length, 16);\n \n msg.payload = Buffer.concat([header, msg.payload]);\n node.send(msg);\n}\n\n\n","outputs":1,"noerr":0,"x":310,"y":140,"wires":[]},{"id":"e2a9b961.e911e8","type":"udp in","z":"ded91775.54ad","name":"","iface":"","port":"6454","ipv":"udp4","multicast":"false","group":"","datatype":"buffer","x":110,"y":201,"wires":[["d47e1dfc.842a48"]]},{"id":"c379aac.06a4558","type":"inject","z":"ded91775.54ad","name":"","topic":"0","payload":"[255,255,255,255,255]","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":"","x":160,"y":341,"wires":[["3088f50e.7a245a"]]},{"id":"d70cbb0c.908808","type":"debug","z":"ded91775.54ad","name":"","active":true,"console":"false","complete":"false","x":480,"y":201,"wires":},{"id":"21041abb.754cb6","type":"comment","z":"ded91775.54ad","name":"Receive","info":"","x":100,"y":161,"wires":},{"id":"d47e1dfc.842a48","type":"subflow:2e555652.746eaa","z":"ded91775.54ad","name":"","x":280,"y":201,"wires":[["d70cbb0c.908808"]]},{"id":"bfbbc79.31082b8","type":"udp out","z":"ded91775.54ad","name":"","addr":"192.168.10.20","iface":"","port":"6454","ipv":"udp4","outport":"","base64":true,"multicast":"false","x":639,"y":341,"wires":},{"id":"3088f50e.7a245a","type":"subflow:2e555652.746eaa","z":"ded91775.54ad","name":"","x":400,"y":341,"wires":[["bfbbc79.31082b8"]]},{"id":"60d83709.cb50e","type":"comment","z":"ded91775.54ad","name":"Send","info":"","x":100,"y":301,"wires":},{"id":"b5845bdd.fac8e8","type":"comment","z":"ded91775.54ad","name":"Art-Net sending and receiving","info":"","x":170,"y":101,"wires":},{"id":"cb61da95.fab7f","type":"inject","z":"ded91775.54ad","name":"","topic":"0","payload":"[0,0,0]","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":"","x":107,"y":388,"wires":[["3088f50e.7a245a"]]},{"id":"e3e77f1c.7bbc18","type":"ui_slider","z":"ded91775.54ad","name":"","label":"slider 0","tooltip":"","group":"2e448404.b81cf4","order":1,"width":0,"height":0,"passthru":true,"outs":"end","topic":"","min":0,"max":"255","step":1,"x":108,"y":571,"wires":[["92ef86a0.88e208"]]},{"id":"a63efaee.31603","type":"debug","z":"ded91775.54ad","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":840,"y":601,"wires":},{"id":"5068dae3.60367c","type":"trigger","z":"ded91775.54ad","op1":"","op2":"true","op1type":"nul","op2type":"bool","duration":"25","extend":false,"units":"ms","reset":"","bytopic":"all","name":"","x":491,"y":602,"wires":[["317fe0fa.6f94b8"]]},{"id":"d2e6a564.b54968","type":"inject","z":"ded91775.54ad","name":"Init","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":100,"y":499,"wires":[["a915d40a.8d166"]]},{"id":"a915d40a.8d166","type":"function","z":"ded91775.54ad","name":"","func":"var arr = new Array(512);\nvar i;\nfor (i = 0; i < arr.length; i++) { \n arr[i] = 0;\n}\nflow.set("array", arr);\n\nnode.status({\n\t text : "Array length: "+arr.length.toString()\n});\n","outputs":0,"noerr":0,"x":300,"y":499,"wires":},{"id":"92ef86a0.88e208","type":"change","z":"ded91775.54ad","name":"","rules":[{"t":"set","p":"array[0]","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":298,"y":571,"wires":[["5068dae3.60367c"]]},{"id":"e436e45b.888768","type":"ui_slider","z":"ded91775.54ad","name":"","label":"slider 2","tooltip":"","group":"2e448404.b81cf4","order":1,"width":0,"height":0,"passthru":true,"outs":"end","topic":"","min":0,"max":"255","step":1,"x":107,"y":635,"wires":[["c41ed7db.d6fe2"]]},{"id":"c41ed7db.d6fe2","type":"change","z":"ded91775.54ad","name":"","rules":[{"t":"set","p":"array[2]","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":297,"y":635,"wires":[["5068dae3.60367c"]]},{"id":"317fe0fa.6f94b8","type":"function","z":"ded91775.54ad","name":"","func":"var arr = flow.get("array");\nnode.send({ payload:0 });\nnode.send({ payload:':' });\nnode.send({ payload:'[' });\nvar i;\nfor (i = 0; i < arr.length; i++) { \n node.send({ payload:arr[i] });\n if (i < arr.length-1){\n node.send({ payload:',' });\n }\n}\nnode.send({ payload:']' });\n","outputs":1,"noerr":0,"x":641,"y":602,"wires":[["a63efaee.31603","3088f50e.7a245a"]]},{"id":"2e448404.b81cf4","type":"ui_group","z":"","name":"DMX","tab":"3bc203ee.438e94","disp":true,"width":"6","collapse":false},{"id":"3bc203ee.438e94","type":"ui_tab","z":"","name":"Testboard","icon":"dashboard","disabled":false,"hidden":false}]
