Margin between two widgets inside a group
I would like to reduce the vertical margin between two widgets inside a group.
I would like to solve it with some "template.node" and "margin-top" property for example.
But i don't know how to script the template-node.
Thanks in advance!
Some of that space is part of the actual widget, so not sure how you could reduce that further without actually editing the widget itself (and don't ask me how :stuck_out_tongue: )
However, you can make some adjustments to any padding/spacing across the dashboard...
Correct answer is - you can't. Regular gauge uses available space as the space is defined by rectangles x by x - all that space is reserved for that widget. How the widget uses reserved space is up to widget and as the regular gauge needs to be able to provide 4 different layouts including full circle - there is not much to change.
Thanks for the detailed explanation. I was hoping it would be possible to force overlapping of the two widgets by using a negative margin for the donut-widget. But if that is not possible, than it is so.
Again thank you. :slight_smile:
It happens by accident... but not something that I think we can control.
Thanks for the help, in the end i changed the design a little bit.
Now the layout looks like this, more clean than with the donut for the shut off timer:
For anyone who wants the source code, here:
[{"id":"2df2987b.4d9058","type":"tab","label":"Strom","disabled":false,"info":""},{"id":"20b3caed.10f5a6","type":"mqtt in","z":"2df2987b.4d9058","name":"Tasmota - Sensoren Infos","topic":"tasmota/tele/SENSOR","qos":"2","datatype":"json","broker":"45313de8.078d8c","nl":false,"rap":true,"rh":0,"x":160,"y":200,"wires":[["7f5e487f.914408","6cbcb097.04c86"]]},{"id":"7f5e487f.914408","type":"switch","z":"2df2987b.4d9058","name":"Button PC - 1x click","property":"payload.ZbReceived[\"Button-PC\"].MultiInValue","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":640,"y":180,"wires":[["51cea7a3.09df8"]]},{"id":"6cbcb097.04c86","type":"switch","z":"2df2987b.4d9058","name":"Button PC - keep pressed","property":"payload.ZbReceived[\"Button-PC\"].MultiInValue","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":650,"y":240,"wires":[["5202486e.f1fd08"]]},{"id":"e3c9d451.bcce3","type":"mqtt out","z":"2df2987b.4d9058","name":"Steckdose PC - Befehle senden","topic":"shellies/shellyplug-PC/relay/0/command","qos":"2","retain":"false","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"45313de8.078d8c","x":1970,"y":180,"wires":[]},{"id":"51cea7a3.09df8","type":"change","z":"2df2987b.4d9058","name":"switch on","rules":[{"t":"set","p":"payload","pt":"msg","to":"on","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":940,"y":180,"wires":[["e3c9d451.bcce3","1a41c60d.bc5c3a"]]},{"id":"4e2ff937.87a838","type":"mqtt in","z":"2df2987b.4d9058","name":"Steckdose PC - Power Consumption","topic":"shellies/shellyplug-PC/relay/0/power","qos":"2","datatype":"json","broker":"45313de8.078d8c","nl":false,"rap":true,"rh":0,"x":170,"y":440,"wires":[["9d8ec2c8.853c08","9871a8b.12b6ed8","60146cb1.6671a4","13910136.3749ff"]]},{"id":"5202486e.f1fd08","type":"change","z":"2df2987b.4d9058","name":"switch off","rules":[{"t":"set","p":"payload","pt":"msg","to":"off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":940,"y":240,"wires":[["e3c9d451.bcce3","1a41c60d.bc5c3a"]]},{"id":"10d8c710.a1c049","type":"mqtt in","z":"2df2987b.4d9058","name":"Steckdose Kino - Power Consumption","topic":"shellies/shellyplug-Kino/relay/0/power","qos":"2","datatype":"json","broker":"45313de8.078d8c","nl":false,"rap":true,"rh":0,"x":190,"y":760,"wires":[["ce306.6d9914fa8","2d838456.fb12bc","9348dff6.a5325","c2407ca1.e82b48"]]},{"id":"1a41c60d.bc5c3a","type":"mqtt out","z":"2df2987b.4d9058","name":"Steckdose Kino - Befehle senden","topic":"shellies/shellyplug-Kino/relay/0/command","qos":"2","retain":"false","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"45313de8.078d8c","x":1970,"y":240,"wires":[]},{"id":"adb72234.193a58","type":"comment","z":"2df2987b.4d9058","name":"STECKDOSEN STEUERN BEAMERZIMMER & KINO","info":"","x":820,"y":80,"wires":[]},{"id":"467773ed.35f31c","type":"comment","z":"2df2987b.4d9058","name":"Button PC auswerten","info":"","x":770,"y":120,"wires":[]},{"id":"df4972df.90477","type":"comment","z":"2df2987b.4d9058","name":"Steckdosen ein/ausschalten","info":"","x":1970,"y":120,"wires":[]},{"id":"70ce545a.d57644","type":"comment","z":"2df2987b.4d9058","name":"Steckdose PC - Stromverbrauch überwachen - ausschaulten bei Unterschreitung Grenzwert","info":"","x":800,"y":300,"wires":[]},{"id":"d0ae646a.54dbd8","type":"comment","z":"2df2987b.4d9058","name":"Steckdose PC - Stromverbrauch überwachen - ausschaulten bei Unterschreitung Grenzwert","info":"","x":800,"y":660,"wires":[]},{"id":"99c61ccf.082f6","type":"comment","z":"2df2987b.4d9058","name":"Stromanzeige Dashboard","info":"","x":500,"y":500,"wires":[]},{"id":"31e67de9.5e523a","type":"comment","z":"2df2987b.4d9058","name":"Stromanzeige Dashboard","info":"","x":540,"y":820,"wires":[]},{"id":"6e7914b3.b4a074","type":"mytimeout","z":"2df2987b.4d9058","name":"30 Minuten Timer","outtopic":"","outsafe":"","outwarning":"off","outunsafe":"0","warning":"1","timer":"1800","debug":false,"ndebug":false,"ignoreCase":false,"repeat":false,"again":false,"x":1230,"y":760,"wires":[["e9c73bcf.5df84"],["df8d7aac.d14808"]]},{"id":"891ba5ca.96e7a","type":"trigger","z":"2df2987b.4d9058","name":"","op1":"1","op2":"0","op1type":"num","op2type":"str","duration":"0","extend":false,"overrideDelay":false,"units":"s","reset":"false","bytopic":"all","topic":"payload","outputs":1,"x":950,"y":740,"wires":[["6e7914b3.b4a074"]]},{"id":"917c6ae5.277ce","type":"switch","z":"2df2987b.4d9058","name":"switch","property":"payload","propertyType":"msg","rules":[{"t":"false"}],"checkall":"true","repair":false,"outputs":1,"x":830,"y":820,"wires":[["78fc92c2.5c1c94"]]},{"id":"78fc92c2.5c1c94","type":"change","z":"2df2987b.4d9058","name":"reset timer","rules":[{"t":"set","p":"payload","pt":"msg","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1010,"y":820,"wires":[["6e7914b3.b4a074"]]},{"id":"e9c73bcf.5df84","type":"switch","z":"2df2987b.4d9058","name":"timer finished","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":1460,"y":760,"wires":[["a116470f.2e85e8"]]},{"id":"a116470f.2e85e8","type":"change","z":"2df2987b.4d9058","name":"switch off","rules":[{"t":"set","p":"payload","pt":"msg","to":"off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1700,"y":760,"wires":[["1a41c60d.bc5c3a"]]},{"id":"ce306.6d9914fa8","type":"function","z":"2df2987b.4d9058","name":"Überwachung Stromverbrauch Grenzwert","func":"var current = msg.payload;\n\nif (current > 0.1 && current <= 10.0) {\n    msg.payload = true;\n} \nelse\n{\n    msg.payload = false;\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":540,"y":760,"wires":[["891ba5ca.96e7a","917c6ae5.277ce"]]},{"id":"a7449447.6d89c","type":"comment","z":"2df2987b.4d9058","name":"Strom zwischen 0.1 und 10 Watt, dann ausschalten, ansonsten reset","info":"","x":550,"y":700,"wires":[]},{"id":"e1f774ca.47c7a","type":"mytimeout","z":"2df2987b.4d9058","name":"30 Minuten Timer","outtopic":"","outsafe":"","outwarning":"off","outunsafe":"0","warning":"1","timer":"1800","debug":false,"ndebug":false,"ignoreCase":false,"repeat":false,"again":false,"x":1230,"y":420,"wires":[["506b53c7.fca824"],["31cc53db.d49bfc"]]},{"id":"62be9cc7.eb58ec","type":"trigger","z":"2df2987b.4d9058","name":"","op1":"1","op2":"0","op1type":"num","op2type":"str","duration":"0","extend":false,"overrideDelay":false,"units":"s","reset":"false","bytopic":"all","topic":"payload","outputs":1,"x":940,"y":400,"wires":[["e1f774ca.47c7a"]]},{"id":"e3e47120.e77ad","type":"switch","z":"2df2987b.4d9058","name":"","property":"payload","propertyType":"msg","rules":[{"t":"false"}],"checkall":"true","repair":false,"outputs":1,"x":850,"y":480,"wires":[["e3fef47e.d2d36"]]},{"id":"e3fef47e.d2d36","type":"change","z":"2df2987b.4d9058","name":"reset timer","rules":[{"t":"set","p":"payload","pt":"msg","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1010,"y":480,"wires":[["e1f774ca.47c7a"]]},{"id":"506b53c7.fca824","type":"switch","z":"2df2987b.4d9058","name":"timer finished","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":1460,"y":420,"wires":[["913aba49.c84fb8"]]},{"id":"913aba49.c84fb8","type":"change","z":"2df2987b.4d9058","name":"switch off","rules":[{"t":"set","p":"payload","pt":"msg","to":"off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1620,"y":420,"wires":[["e3c9d451.bcce3"]]},{"id":"9d8ec2c8.853c08","type":"function","z":"2df2987b.4d9058","name":"Überwachung Stromverbrauch Grenzwert","func":"var current = msg.payload;\n\nif (current > 0.1 && current <= 10.0) {\n    msg.payload = true;\n} \nelse\n{\n    msg.payload = false;\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":540,"y":420,"wires":[["62be9cc7.eb58ec","e3e47120.e77ad"]]},{"id":"2589aeb2.78806a","type":"comment","z":"2df2987b.4d9058","name":"Strom zwischen 0.1 und 10 Watt, dann ausschalten, ansonsten reset","info":"","x":550,"y":360,"wires":[]},{"id":"99f71fb4.4b81f","type":"comment","z":"2df2987b.4d9058","name":"start timer","info":"","x":940,"y":700,"wires":[]},{"id":"3159d0c6.373518","type":"comment","z":"2df2987b.4d9058","name":"start timer","info":"","x":940,"y":360,"wires":[]},{"id":"892d2437.b6e768","type":"comment","z":"2df2987b.4d9058","name":"reset timer","info":"","x":940,"y":440,"wires":[]},{"id":"bc6168e3.06aab8","type":"comment","z":"2df2987b.4d9058","name":"reset timer","info":"","x":940,"y":780,"wires":[]},{"id":"6d8e88ee.8a1f28","type":"inject","z":"2df2987b.4d9058","name":"automatic reset for triggers at midnight","props":[{"p":"payload"}],"repeat":"","crontab":"00 00 * * *","once":false,"onceDelay":0.1,"topic":"","payload":"false","payloadType":"bool","x":220,"y":40,"wires":[["62be9cc7.eb58ec","891ba5ca.96e7a","853fc229.78bc2","e3e47120.e77ad","917c6ae5.277ce","a92cf60b.04aaa8"]]},{"id":"53267442.4f947c","type":"mqtt in","z":"2df2987b.4d9058","name":"Tasmota - Sensoren Infos","topic":"tasmota/tele/SENSOR","qos":"2","datatype":"json","broker":"45313de8.078d8c","nl":false,"rap":true,"rh":0,"x":170,"y":1180,"wires":[["48d7118c.2b6598","930dcf41.6d93c8"]]},{"id":"48d7118c.2b6598","type":"switch","z":"2df2987b.4d9058","name":"Button Wohnzimmer - 1x click","property":"payload.ZbReceived[\"Button-Wohnzimmer\"].MultiInValue","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":680,"y":1160,"wires":[["cb4f4218.f72e48"]]},{"id":"930dcf41.6d93c8","type":"switch","z":"2df2987b.4d9058","name":"Button Wohnzimmer - keep pressed","property":"payload.ZbReceived[\"Button-Wohnzimmer\"].MultiInValue","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":690,"y":1220,"wires":[["5905b0e6.12df58"]]},{"id":"fc347e63.c5c2f8","type":"mqtt out","z":"2df2987b.4d9058","name":"Steckdose Wohnzimmer - Befehle senden","topic":"shellies/shellyplug-Wohnzimmer/relay/0/command","qos":"2","retain":"false","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"45313de8.078d8c","x":2010,"y":1160,"wires":[]},{"id":"cb4f4218.f72e48","type":"change","z":"2df2987b.4d9058","name":"switch on","rules":[{"t":"set","p":"payload","pt":"msg","to":"on","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":950,"y":1160,"wires":[["fc347e63.c5c2f8"]]},{"id":"ff4a76e1.d9e368","type":"mqtt in","z":"2df2987b.4d9058","name":"Steckdose Wohnzimmer - Power Consumption","topic":"shellies/shellyplug-Wohnzimmer/relay/0/power","qos":"2","datatype":"json","broker":"45313de8.078d8c","nl":false,"rap":true,"rh":0,"x":200,"y":1400,"wires":[["968ae4c2.63adf","b2ef3e27.196048","2efb1dcc.7808ca","976a3c6a.122518"]]},{"id":"5905b0e6.12df58","type":"change","z":"2df2987b.4d9058","name":"switch off","rules":[{"t":"set","p":"payload","pt":"msg","to":"off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":950,"y":1220,"wires":[["fc347e63.c5c2f8"]]},{"id":"c06b4210.9d51f8","type":"comment","z":"2df2987b.4d9058","name":"STECKDOSEN STEUERN WOHNZIMMER","info":"","x":890,"y":1060,"wires":[]},{"id":"6092b542.e8bd44","type":"comment","z":"2df2987b.4d9058","name":"Button Wohnzimmer auswerten","info":"","x":810,"y":1100,"wires":[]},{"id":"da1dfb27.08a348","type":"comment","z":"2df2987b.4d9058","name":"Steckdosen ein/ausschalten","info":"","x":1980,"y":1100,"wires":[]},{"id":"d618963c.25711","type":"comment","z":"2df2987b.4d9058","name":"Steckdose PC - Stromverbrauch überwachen - ausschaulten bei Unterschreitung Grenzwert","info":"","x":810,"y":1280,"wires":[]},{"id":"9fd6d982.3c8478","type":"comment","z":"2df2987b.4d9058","name":"Stromanzeige Dashboard","info":"","x":510,"y":1480,"wires":[]},{"id":"5d8e5506.86098c","type":"mytimeout","z":"2df2987b.4d9058","name":"30 Minuten Timer","outtopic":"","outsafe":"","outwarning":"off","outunsafe":"0","warning":"1","timer":"1800","debug":false,"ndebug":false,"ignoreCase":false,"repeat":false,"again":false,"x":1240,"y":1400,"wires":[["bd954bbf.d1836"],["7cc21b3c.6d274c"]]},{"id":"853fc229.78bc2","type":"trigger","z":"2df2987b.4d9058","name":"","op1":"1","op2":"0","op1type":"num","op2type":"str","duration":"0","extend":false,"overrideDelay":false,"units":"s","reset":"false","bytopic":"all","topic":"payload","outputs":1,"x":950,"y":1380,"wires":[["5d8e5506.86098c"]]},{"id":"a92cf60b.04aaa8","type":"switch","z":"2df2987b.4d9058","name":"","property":"payload","propertyType":"msg","rules":[{"t":"false"},{"t":"eq","v":"on","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":860,"y":1460,"wires":[["7e875c19.5c2ef4"],["7e875c19.5c2ef4"]]},{"id":"7e875c19.5c2ef4","type":"change","z":"2df2987b.4d9058","name":"reset timer","rules":[{"t":"set","p":"payload","pt":"msg","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1020,"y":1460,"wires":[["5d8e5506.86098c"]]},{"id":"bd954bbf.d1836","type":"switch","z":"2df2987b.4d9058","name":"timer finished","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":1470,"y":1400,"wires":[["31ce2f1c.a33ab"]]},{"id":"31ce2f1c.a33ab","type":"change","z":"2df2987b.4d9058","name":"switch off","rules":[{"t":"set","p":"payload","pt":"msg","to":"off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1630,"y":1400,"wires":[["fc347e63.c5c2f8"]]},{"id":"968ae4c2.63adf","type":"function","z":"2df2987b.4d9058","name":"Überwachung Stromverbrauch Grenzwert","func":"var current = msg.payload;\n\nif (current > 0.1 && current <= 10.0) {\n    msg.payload = true;\n} \nelse\n{\n    msg.payload = false;\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":600,"y":1400,"wires":[["853fc229.78bc2","a92cf60b.04aaa8"]]},{"id":"7259609b.696988","type":"comment","z":"2df2987b.4d9058","name":"Strom zwischen 0.1 und 10 Watt, dann ausschalten, ansonsten reset","info":"","x":560,"y":1340,"wires":[]},{"id":"badcab3b.7c289","type":"comment","z":"2df2987b.4d9058","name":"start timer","info":"","x":950,"y":1340,"wires":[]},{"id":"ce43e628.aa0168","type":"comment","z":"2df2987b.4d9058","name":"reset timer","info":"","x":950,"y":1420,"wires":[]},{"id":"236ebe93.b6b66a","type":"ui_button","z":"2df2987b.4d9058","name":"","group":"147ae808.a499a","order":6,"width":"3","height":"1","passthru":false,"label":"ON","tooltip":"","color":"","bgcolor":"{{BackgroundOnButton}}","className":"","icon":"","payload":"on","payloadType":"str","topic":"topic","topicType":"msg","x":1550,"y":920,"wires":[["1a41c60d.bc5c3a","917c6ae5.277ce","3a450289.161fa6"]]},{"id":"2d838456.fb12bc","type":"switch","z":"2df2987b.4d9058","name":"ist ein","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":1190,"y":920,"wires":[["71ed86e6.249788"]]},{"id":"6e80062e.2e6f4","type":"change","z":"2df2987b.4d9058","name":"set background","rules":[{"t":"set","p":"BackgroundOnButton","pt":"msg","to":"gray","tot":"str"},{"t":"set","p":"BackgroundOffButton","pt":"msg","to":"#ED5360","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1360,"y":980,"wires":[["b7ed7947.ffb9","236ebe93.b6b66a"]]},{"id":"9348dff6.a5325","type":"switch","z":"2df2987b.4d9058","name":"ist aus","property":"payload","propertyType":"msg","rules":[{"t":"neq","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":1200,"y":980,"wires":[["6e80062e.2e6f4"]]},{"id":"9bc74d6e.f609d","type":"comment","z":"2df2987b.4d9058","name":"change button colour","info":"","x":1270,"y":500,"wires":[]},{"id":"b7ed7947.ffb9","type":"ui_button","z":"2df2987b.4d9058","name":"","group":"147ae808.a499a","order":7,"width":"3","height":"1","passthru":false,"label":"OFF","tooltip":"","color":"","bgcolor":"{{BackgroundOffButton}}","className":"","icon":"","payload":"off","payloadType":"str","topic":"topic","topicType":"msg","x":1550,"y":980,"wires":[["1a41c60d.bc5c3a"]]},{"id":"71ed86e6.249788","type":"change","z":"2df2987b.4d9058","name":"set background","rules":[{"t":"set","p":"BackgroundOnButton","pt":"msg","to":"#0B8F95","tot":"str"},{"t":"set","p":"BackgroundOffButton","pt":"msg","to":"gray","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1360,"y":920,"wires":[["236ebe93.b6b66a","b7ed7947.ffb9"]]},{"id":"ae1e8f92.7d6708","type":"ui_button","z":"2df2987b.4d9058","name":"","group":"147ae808.a499a","order":2,"width":"3","height":"1","passthru":false,"label":"ON","tooltip":"","color":"","bgcolor":"{{BackgroundOnButton}}","className":"","icon":"","payload":"on","payloadType":"str","topic":"topic","topicType":"msg","x":1570,"y":540,"wires":[["e3c9d451.bcce3","e3e47120.e77ad","eb03c14d.9b9bf"]]},{"id":"9871a8b.12b6ed8","type":"switch","z":"2df2987b.4d9058","name":"ist ein","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":1210,"y":540,"wires":[["9305a91e.721148"]]},{"id":"2f9cbc48.bd3acc","type":"change","z":"2df2987b.4d9058","name":"set background","rules":[{"t":"set","p":"BackgroundOnButton","pt":"msg","to":"gray","tot":"str"},{"t":"set","p":"BackgroundOffButton","pt":"msg","to":"#ED5360","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1380,"y":600,"wires":[["4ce89092.01f29","ae1e8f92.7d6708"]]},{"id":"60146cb1.6671a4","type":"switch","z":"2df2987b.4d9058","name":"ist aus","property":"payload","propertyType":"msg","rules":[{"t":"neq","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":1220,"y":600,"wires":[["2f9cbc48.bd3acc"]]},{"id":"4ce89092.01f29","type":"ui_button","z":"2df2987b.4d9058","name":"","group":"147ae808.a499a","order":3,"width":"3","height":"1","passthru":false,"label":"OFF","tooltip":"","color":"","bgcolor":"{{BackgroundOffButton}}","className":"","icon":"","payload":"off","payloadType":"str","topic":"topic","topicType":"msg","x":1570,"y":600,"wires":[["e3c9d451.bcce3"]]},{"id":"9305a91e.721148","type":"change","z":"2df2987b.4d9058","name":"set background","rules":[{"t":"set","p":"BackgroundOnButton","pt":"msg","to":"#0B8F95","tot":"str"},{"t":"set","p":"BackgroundOffButton","pt":"msg","to":"gray","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1380,"y":540,"wires":[["ae1e8f92.7d6708","4ce89092.01f29"]]},{"id":"85485cc2.87a548","type":"ui_button","z":"2df2987b.4d9058","name":"","group":"811b704e.0a63d8","order":3,"width":"3","height":"1","passthru":false,"label":"ON","tooltip":"","color":"","bgcolor":"{{BackgroundOnButton}}","className":"","icon":"","payload":"on","payloadType":"str","topic":"topic","topicType":"msg","x":1570,"y":1560,"wires":[["fc347e63.c5c2f8","8185508d.088f8"]]},{"id":"b2ef3e27.196048","type":"switch","z":"2df2987b.4d9058","name":"ist ein","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":1210,"y":1560,"wires":[["203ede00.33019a"]]},{"id":"cbf9d12e.998d8","type":"change","z":"2df2987b.4d9058","name":"set background","rules":[{"t":"set","p":"BackgroundOnButton","pt":"msg","to":"gray","tot":"str"},{"t":"set","p":"BackgroundOffButton","pt":"msg","to":"#ED5360","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1380,"y":1620,"wires":[["2d2081f4.da5316","85485cc2.87a548"]]},{"id":"2efb1dcc.7808ca","type":"switch","z":"2df2987b.4d9058","name":"ist aus","property":"payload","propertyType":"msg","rules":[{"t":"neq","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":1220,"y":1620,"wires":[["cbf9d12e.998d8"]]},{"id":"2d2081f4.da5316","type":"ui_button","z":"2df2987b.4d9058","name":"","group":"811b704e.0a63d8","order":4,"width":"3","height":"1","passthru":false,"label":"OFF","tooltip":"","color":"","bgcolor":"{{BackgroundOffButton}}","className":"","icon":"","payload":"off","payloadType":"str","topic":"topic","topicType":"msg","x":1570,"y":1620,"wires":[["fc347e63.c5c2f8"]]},{"id":"203ede00.33019a","type":"change","z":"2df2987b.4d9058","name":"set background","rules":[{"t":"set","p":"BackgroundOnButton","pt":"msg","to":"#0B8F95","tot":"str"},{"t":"set","p":"BackgroundOffButton","pt":"msg","to":"gray","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1380,"y":1560,"wires":[["85485cc2.87a548","2d2081f4.da5316"]]},{"id":"4624d733.bf7de8","type":"comment","z":"2df2987b.4d9058","name":"Buttons zum schalten Steckdose ","info":"","x":1570,"y":1520,"wires":[]},{"id":"cf67b7cc.10ce3","type":"comment","z":"2df2987b.4d9058","name":"Buttons zum schalten Steckdose ","info":"","x":1550,"y":880,"wires":[]},{"id":"709f3df5.97acac","type":"comment","z":"2df2987b.4d9058","name":"Buttons zum schalten Steckdose ","info":"","x":1530,"y":500,"wires":[]},{"id":"1315adb3.c5126a","type":"comment","z":"2df2987b.4d9058","name":"change button colour","info":"","x":1290,"y":880,"wires":[]},{"id":"bb75c83e.899338","type":"comment","z":"2df2987b.4d9058","name":"change button colour","info":"","x":1310,"y":1520,"wires":[]},{"id":"c2407ca1.e82b48","type":"ui_gauge","z":"2df2987b.4d9058","name":"","group":"147ae808.a499a","order":5,"width":0,"height":0,"gtype":"gage","title":"Steckdose Kino","label":"Watt","format":"{{value}}","min":0,"max":"300","colors":["#ca3838","#e6e600","#00b500"],"seg1":"10","seg2":"50","className":"","x":480,"y":880,"wires":[]},{"id":"13910136.3749ff","type":"ui_gauge","z":"2df2987b.4d9058","name":"","group":"147ae808.a499a","order":1,"width":0,"height":0,"gtype":"gage","title":"Steckdose PC","label":"Watt","format":"{{value}}","min":0,"max":"300","colors":["#ca3838","#e6e600","#00b500"],"seg1":"10","seg2":"50","className":"","x":460,"y":540,"wires":[]},{"id":"976a3c6a.122518","type":"ui_gauge","z":"2df2987b.4d9058","name":"","group":"811b704e.0a63d8","order":1,"width":0,"height":0,"gtype":"gage","title":"Steckdose Fernseher & Co","label":"Watt","format":"{{value}}","min":0,"max":"300","colors":["#ca3838","#e6e600","#00b500"],"seg1":"10","seg2":"50","className":"","x":520,"y":1520,"wires":[]},{"id":"7cc21b3c.6d274c","type":"ui_artlessgauge","z":"2df2987b.4d9058","group":"811b704e.0a63d8","order":5,"width":0,"height":0,"name":"switch off timer","icon":"","label":"switch off timer","unit":"s","layout":"linear","decimals":0,"differential":false,"minmax":false,"colorTrack":"#555555","style":"","colorFromTheme":true,"property":"payload","secondary":"secondary","inline":true,"animate":true,"sectors":[{"val":0,"col":"#ca3838","t":"min","dot":0},{"val":600,"col":"#e6e600","t":"sec","dot":0},{"val":1200,"col":"#00b500","t":"sec","dot":0},{"val":1800,"col":"#00b500","t":"max","dot":0}],"lineWidth":3,"bgcolorFromTheme":true,"diffCenter":"","x":1480,"y":1460,"wires":[]},{"id":"df8d7aac.d14808","type":"ui_artlessgauge","z":"2df2987b.4d9058","group":"147ae808.a499a","order":8,"width":0,"height":0,"name":"switch off timer","icon":"","label":"switch off timer","unit":"s","layout":"linear","decimals":0,"differential":false,"minmax":false,"colorTrack":"#555555","style":"","colorFromTheme":true,"property":"payload","secondary":"secondary","inline":true,"animate":true,"sectors":[{"val":0,"col":"#ca3838","t":"min","dot":0},{"val":600,"col":"#e6e600","t":"sec","dot":0},{"val":1200,"col":"#00b500","t":"sec","dot":0},{"val":1800,"col":"#00b500","t":"max","dot":0}],"lineWidth":3,"bgcolorFromTheme":true,"diffCenter":"","x":1460,"y":820,"wires":[]},{"id":"31cc53db.d49bfc","type":"ui_artlessgauge","z":"2df2987b.4d9058","group":"147ae808.a499a","order":4,"width":0,"height":0,"name":"switch off timer","icon":"","label":"switch off timer","unit":"s","layout":"linear","decimals":0,"differential":false,"minmax":false,"colorTrack":"#555555","style":"","colorFromTheme":true,"property":"payload","secondary":"secondary","inline":true,"animate":true,"sectors":[{"val":0,"col":"#ca3838","t":"min","dot":0},{"val":600,"col":"#e6e600","t":"sec","dot":0},{"val":1200,"col":"#00b500","t":"sec","dot":0},{"val":1800,"col":"#00b500","t":"max","dot":0}],"lineWidth":3,"bgcolorFromTheme":true,"diffCenter":"","x":1460,"y":460,"wires":[]},{"id":"8185508d.088f8","type":"change","z":"2df2987b.4d9058","name":"reset timer","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":1450,"y":1720,"wires":[["853fc229.78bc2","a92cf60b.04aaa8"]]},{"id":"3a450289.161fa6","type":"change","z":"2df2987b.4d9058","name":"reset timer","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":1550,"y":1060,"wires":[["917c6ae5.277ce","891ba5ca.96e7a"]]},{"id":"eb03c14d.9b9bf","type":"change","z":"2df2987b.4d9058","name":"reset timer","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":1570,"y":660,"wires":[["e3e47120.e77ad","62be9cc7.eb58ec"]]},{"id":"45313de8.078d8c","type":"mqtt-broker","name":"tasmota","broker":"192.168.111.25","port":"1883","clientid":"","usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""},{"id":"147ae808.a499a","type":"ui_group","name":"Beamerzimmer","tab":"910865fe.8cd058","order":1,"disp":true,"width":"6","collapse":false,"className":""},{"id":"811b704e.0a63d8","type":"ui_group","name":"Wohnzimmer","tab":"910865fe.8cd058","order":2,"disp":true,"width":"6","collapse":false,"className":""},{"id":"910865fe.8cd058","type":"ui_tab","name":"Strom","icon":"dashboard","order":3,"disabled":false,"hidden":false}]
