Material Design Icon Broken? The 'outlet' icon does not seem to be found?
I tried 'book', 'looks_3', etc. these MD icons works. But 'outlet' fails?
[{"id":"d76a7e66.86411","type":"inject","z":"9c329f76.c5be1","name":"On","props":[{"p":"payload"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":550,"y":1020,"wires":[["e044be7c.ec032"]]},{"id":"c47711da.cc1fa","type":"inject","z":"9c329f76.c5be1","name":"Off","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"false","payloadType":"bool","x":550,"y":1060,"wires":[["e044be7c.ec032"]]},{"id":"e044be7c.ec032","type":"function","z":"9c329f76.c5be1","name":"Icon","func":"msg.ui_control = {onicon:\"outlet\",oncolor:\"green\",officon:\"outlet\",offcolor:\"red\"}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":690,"y":1040,"wires":[["1c9ce86.dcd9e18"]]},{"id":"1c9ce86.dcd9e18","type":"ui_switch","z":"9c329f76.c5be1","name":"","label":"Test","tooltip":"","group":"110f893b.a0f1d7","order":2,"width":"2","height":"1","passthru":true,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"fa fa-circle","oncolor":"white","offvalue":"false","offvalueType":"bool","officon":"fa fa-circle-thin","offcolor":"white","x":830,"y":1040,"wires":[[]]},{"id":"131f697b.9f5b57","type":"inject","z":"9c329f76.c5be1","name":"On","props":[{"p":"payload"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":550,"y":1120,"wires":[["411b4aa9.976244"]]},{"id":"d3ed9ee6.232e1","type":"inject","z":"9c329f76.c5be1","name":"Off","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"false","payloadType":"bool","x":550,"y":1160,"wires":[["411b4aa9.976244"]]},{"id":"411b4aa9.976244","type":"ui_switch","z":"9c329f76.c5be1","name":"","label":"Test","tooltip":"","group":"110f893b.a0f1d7","order":2,"width":"2","height":"1","passthru":true,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"outlet","oncolor":"green","offvalue":"false","offvalueType":"bool","officon":"outlet","offcolor":"red","x":690,"y":1140,"wires":[[]]},{"id":"110f893b.a0f1d7","type":"ui_group","name":"Default","tab":"7179c13.0628d4","order":13,"disp":true,"width":"6","collapse":false},{"id":"7179c13.0628d4","type":"ui_tab","name":"Test","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Found the icon on the Material Design site...
Source...
Ah, just found the reference that only the original MD icons are baked in. Found the comment that prepending 'mi-' to icon name should pull the icon from the net. So issue solved.
