Max size of array in function
I have a funtion, poster here - "Closest Array Match" with 1025 entries.
When i do my checks, the array index is always 1020 on the maximum.
I get the same resault with my function and with "UnborN" function that he posted.
Is 1020 the max array size, or am i doing something wrong?
const foo = new Array(1500)
for(var i = 0; i < foo.length; i++){
  foo[i] = Math.random()
msg.payload = foo
So something would seem to be wrong in your code? Want to share?
Hi TotallyInformation
Thank you for that, see my test flow below.
[{"id":"3e70b103.f9c7de","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"a9acd99e.7d07d8","type":"ui_slider","z":"3e70b103.f9c7de","name":"","label":"slider","tooltip":"","group":"cf677043.b89ff","order":2,"width":0,"height":0,"passthru":false,"outs":"end","topic":"","min":0,"max":"150","step":1,"x":150,"y":220,"wires":[["ace43ab4.20e888","8fdfa66f.e42aa8"]]},{"id":"ace43ab4.20e888","type":"ui_gauge","z":"3e70b103.f9c7de","name":"","group":"cf677043.b89ff","order":1,"width":0,"height":0,"gtype":"gage","title":"gauge","label":"kW","format":"{{value}}","min":0,"max":"150","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":910,"y":160,"wires":[]},{"id":"75fbd248.66bc9c","type":"function","z":"3e70b103.f9c7de","name":"","func":"msg.payload = (5/1024)*msg.payload\nlet array = [0, 0.004, 0.008, 0.012, 0.016, 0.02, 0.024, 0.028, 0.032, 0.036, 0.04, 0.0425, 0.045, 0.0475, 0.05, 0.0525, 0.055, 0.0575, 0.06, 0.0625, \n0.065, 0.0677, 0.0704, 0.0731, 0.0758, 0.0785, 0.0812, 0.0839, 0.0866, 0.0893, 0.092, 0.0945, 0.097, 0.0995, 0.102, 0.1045, 0.107, 0.1095, 0.112, 0.1145, \n0.117, 0.1195, 0.122, 0.1245, 0.127, 0.1295, 0.132, 0.1345, 0.137, 0.1395, 0.142, 0.1445, 0.147, 0.1495, 0.152, 0.1545, 0.157, 0.1595, 0.162, 0.1645, \n0.167, 0.1698, 0.1726, 0.1754, 0.1782, 0.181, 0.1838, 0.1866, 0.1894, 0.1922, 0.195, 0.1976, 0.2004, 0.2032, 0.206, 0.2088, 0.2116, 0.2144, 0.2172, 0.22, \n0.221, 0.22355, 0.2261, 0.2286, 0.2312, 0.2337, 0.2363, 0.2388, 0.2414, 0.2439, 0.2465, 0.249, 0.2515, 0.254, 0.2565, 0.259, 0.2615, 0.264, 0.2665, 0.269, \n0.2715, 0.274, 0.2769, 0.2798, 0.2827, 0.2856, 0.2885, 0.2914, 0.2943, 0.2972, 0.3001, 0.303, 0.3058, 0.3086, 0.3114, 0.3142, 0.317, 0.3198, 0.3226, 0.3254, \n0.3282, 0.331, 0.3337, 0.3364, 0.3391, 0.3418, 0.3445, 0.3472, 0.3499, 0.3526, 0.3553, 0.358, 0.3608, 0.3636, 0.3664, 0.3692, 0.372, 0.3748, 0.3776, 0.3804, \n0.3832, 0.386, 0.3891, 0.3922, 0.3953, 0.3984, 0.4015, 0.4046, 0.4077, 0.4108, 0.4139, 0.417, 0.4198, 0.4226, 0.4254, 0.4282, 0.431, 0.4338, 0.4366, 0.4394, \n0.4422, 0.445, 0.4475, 0.4501, 0.4526, 0.4552, 0.4577, 0.4603, 0.4628, 0.4654, 0.4679, 0.4705, 0.473, 0.4759, 0.4788, 0.4817, 0.4846, 0.4875, 0.4904, 0.4933, \n0.4962, 0.4991, 0.502, 0.5053, 0.5086, 0.5119, 0.5152, 0.5185, 0.5218, 0.5251, 0.5284, 0.5317, 0.535, 0.5378, 0.5406, 0.5434, 0.5462, 0.549, 0.5518, 0.5546, \n0.5574, 0.5602, 0.563, 0.5662, 0.5694, 0.5726, 0.5758, 0.579, 0.5822, 0.5854, 0.5886, 0.5918, 0.595, 0.5979, 0.6008, 0.6037, 0.6066, 0.6095, 0.6124, 0.6153, \n0.6182, 0.6211, 0.624, 0.6274, 0.6308, 0.6342, 0.6376, 0.641, 0.6444, 0.6478, 0.6512, 0.6546, 0.658, 0.6611, 0.6642, 0.6673, 0.6704, 0.6735, 0.6766, 0.6797, \n0.6828, 0.6859, 0.689, 0.6918, 0.6946, 0.6975, 0.7003, 0.7031, 0.7059, 0.7087, 0.7115, 0.7144, 0.7172, 0.72, 0.7232, 0.7264, 0.7296, 0.7328, 0.736, 0.7392, \n0.7424, 0.7456, 0.7488, 0.752, 0.7553, 0.7586, 0.7619, 0.7652, 0.7685, 0.7718, 0.7751, 0.7784, 0.7817, 0.785, 0.7884, 0.7918, 0.7952, 0.7986, 0.802, 0.8054, \n0.8088, 0.8122, 0.8156, 0.819, 0.8223, 0.8256, 0.8289, 0.8322, 0.8355, 0.8388, 0.8421, 0.8454, 0.8487, 0.852, 0.8553, 0.8586, 0.8619, 0.8652, 0.8685, 0.8718, \n0.8751, 0.8784, 0.8817, 0.885, 0.8884, 0.8918, 0.8952, 0.8986, 0.902, 0.9054, 0.9088, 0.9122, 0.9156, 0.919, 0.9226, 0.9262, 0.9298, 0.9334, 0.937, 0.9406, \n0.9442, 0.9478, 0.9514, 0.955, 0.9583, 0.9615, 0.9648, 0.9681, 0.9714, 0.9746, 0.9779, 0.9812, 0.9845, 0.9877, 0.991, 0.994, 0.997, 1, 1.003, 1.006, 1.009, \n1.012, 1.015, 1.018, 1.021, 1.024, 1.0276, 1.0312, 1.0348, 1.0384, 1.042, 1.0456, 1.0492, 1.0528, 1.0564, 1.06, 1.0639, 1.0678, 1.0717, 1.0756, 1.0795, 1.0834, \n1.0873, 1.0912, 1.0951, 1.099, 1.1025, 1.106, 1.1095, 1.113, 1.1165, 1.12, 1.1235, 1.127, 1.1305, 1.134, 1.1376, 1.1412, 1.1448, 1.1484, 1.152, 1.1556, 1.1592, \n1.1628, 1.1664, 1.17, 1.1739, 1.1778, 1.1817, 1.1856, 1.1895, 1.1934, 1.1973, 1.2012, 1.2051, 1.209, 1.2131, 1.2172, 1.2213, 1.2254, 1.2295, 1.2336, 1.2377, \n1.2418, 1.2459, 1.25, 1.2534, 1.2567, 1.2601, 1.2635, 1.2668, 1.2702, 1.2735, 1.2769, 1.2803, 1.2836, 1.287, 1.291, 1.295, 1.299, 1.303, 1.307, 1.311, 1.315, \n1.319, 1.323, 1.327, 1.3306, 1.3342, 1.3378, 1.3414, 1.345, 1.3486, 1.3522, 1.3558, 1.3594, 1.363, 1.3675, 1.372, 1.3765, 1.381, 1.3855, 1.39, 1.3945, 1.399, \n1.4035, 1.408, 1.4121, 1.4162, 1.4203, 1.4244, 1.4285, 1.4326, 1.4367, 1.4408, 1.4449, 1.449, 1.4529, 1.4568, 1.4607, 1.4646, 1.4685, 1.4724, 1.4763, 1.4802, \n1.4841, 1.488, 1.4919, 1.4958, 1.4997, 1.5036, 1.5075, 1.5114, 1.5153, 1.5192, 1.5231, 1.527, 1.5318, 1.5366, 1.5414, 1.5462, 1.551, 1.5558, 1.5606, 1.5654, \n1.5702, 1.575, 1.5787, 1.5825, 1.5862, 1.5899, 1.5936, 1.5974, 1.601, 1.6048, 1.6085, 1.612, 1.616, 1.6202, 1.6244, 1.6286, 1.6328, 1.637, 1.6412, 1.6454, \n1.6496, 1.6538, 1.658, 1.6624, 1.6668, 1.6712, 1.6756, 1.68, 1.6844, 1.6888, 1.6932, 1.6976, 1.702, 1.7063, 1.7106, 1.7149, 1.7192, 1.7235, 1.7278, 1.7321, \n1.7364, 1.7407, 1.745, 1.75, 1.755, 1.76, 1.765, 1.77, 1.775, 1.78, 1.785, 1.79, 1.795, 1.7995, 1.804, 1.8085, 1.813, 1.8175, 1.822, 1.8265, 1.831, 1.8355, \n1.84, 1.8444, 1.8488, 1.8532, 1.8576, 1.862, 1.8664, 1.8708, 1.8752, 1.8796, 1.884, 1.8886, 1.8932, 1.8978, 1.9024, 1.907, 1.9116, 1.9162, 1.9208, 1.9254, \n1.93, 1.9346, 1.939, 1.9439, 1.9485, 1.9532, 1.9578, 1.9625, 1.967, 1.9717, 1.9764, 1.981, 1.9857, 1.9904, 1.9951, 1.9998, 2.0045, 2.0092, 2.0139, 2.0186, \n2.0233, 2.028, 2.0327, 2.0374, 2.0421, 2.0468, 2.0515, 2.0562, 2.0609, 2.0656, 2.0703, 2.075, 2.0799, 2.0848, 2.0897, 2.0946, 2.0995, 2.1044, 2.1093, 2.1142, \n2.1191, 2.124, 2.1294, 2.1348, 2.1402, 2.1456, 2.151, 2.1564, 2.1618, 2.1672, 2.1726, 2.178, 2.1831, 2.1882, 2.1933, 2.1984, 2.2035, 2.2086, 2.2137, 2.2188, \n2.2239, 2.229, 2.2341, 2.2392, 2.2443, 2.2494, 2.2545, 2.2596, 2.2647, 2.2698, 2.2749, 2.28, 2.2851, 2.2902, 2.2953, 2.3004, 2.3055, 2.3106, 2.3157, 2.3208, \n2.3259, 2.331, 2.3363, 2.3415, 2.3468, 2.3521, 2.3574, 2.3626, 2.3679, 2.3732, 2.3784, 2.3837, 2.389, 2.3943, 2.3996, 2.4049, 2.4102, 2.4155, 2.4208, 2.4261, \n2.4314, 2.4367, 2.442, 2.4471, 2.4522, 2.457, 2.4624, 2.4675, 2.4725, 2.4776, 2.4827, 2.4878, 2.4929, 2.498, 2.503, 2.508, 2.513, 2.518, 2.523, 2.528, 2.533, \n2.538, 2.543, 2.548, 2.5543, 2.5606, 2.5669, 2.5732, 2.5795, 2.5858, 2.5921, 2.5984, 2.6047, 2.611, 2.6167, 2.6224, 2.6281, 2.6338, 2.6395, 2.6452, 2.6509, \n2.6566, 2.6623, 2.668, 2.6737, 2.6794, 2.6851, 2.6908, 2.6965, 2.7022, 2.7079, 2.7136, 2.7193, 2.725, 2.7306, 2.7362, 2.7418, 2.7474, 2.753, 2.7586, 2.7642, \n2.7698, 2.7754, 2.781, 2.7871, 2.7932, 2.7993, 2.8054, 2.8115, 2.8175, 2.8236, 2.8297, 2.8358, 2.8419, 2.848, 2.8539, 2.8598, 2.8657, 2.8716, 2.8775, 2.8834, \n2.8893, 2.8952,2.9011, 2.907, 2.9132, 2.9194, 2.9256, 2.9318, 2.938, 2.9442,2.9504, 2.9566, 2.9628, 2.969, 2.9752, 2.9814, 2.9876, 2.9938, 3, 3.0062, 3.0124, \n3.0186, 3.0248, 3.031, 3.0373, 3.0436, 3.0499, 3.0562, 3.0625, 3.0688, 3.0751,3.0814, 3.0877, 3.094, 3.1008, 3.1076, 3.1144, 3.1212, 3.128, 3.1348, 3.1416, \n3.1484, 3.1552, 3.162, 3.1685, 3.175, 3.1815, 3.188, 3.1945, 3.201, 3.2075, 3.214, 3.2205, 3.227, 3.2338, 3.2406, 3.2474, 3.2542, 3.261, 3.2678, 3.2746, 3.2814, \n3.2882, 3.295, 3.301, 3.307, 3.313, 3.319, 3.325, 3.331, 3.337, 3.343, 3.349, 3.355, 3.361, 3.3686, 3.3762, 3.3838, 3.3914, 3.399, 3.4066, 3.4142, 3.4218, \n3.4294, 3.437, 3.4438, 3.4506, 3.4574, 3.4642, 3.471, 3.4778, 3.4846, 3.4914, 3.4982, 3.505, 3.5123, 3.5196, 3.5269, 3.5342, 3.5415, 3.5488, 3.5561, 3.5634, \n3.5707, 3.578, 3.5853, 3.6218, 3.6291, 3.6364, 3.6437, 3.651, 3.6588, 3.6666, 3.6744, 3.6822, 3.69, 3.6978, 3.7056, 3.7134, 3.7212, 3.729, 3.7361, 3.7432, \n3.7503, 3.7574, 3.7645, 3.7716, 3.7787, 3.7858, 3.7929, 3.8, 3.8079, 3.8158, 3.8237, 3.8316, 3.8395, 3.8474, 3.8553, 3.8632, 3.8711, 3.879, 3.8862, 3.893, \n3.9005, 3.9077, 3.9149, 3.9221, 3.929, 3.9365, 3.9436, 3.9508, 3.958, 3.9666, 3.9752, 3.9838, 3.9924, 4.001, 4.0096, 4.0182, 4.0268, 4.0354, 4.044, 4.0516, \n4.0592, 4.0668, 4.0744, 4.082, 4.0896, 4.0972, 4.1048, 4.1124, 4.12, 4.129, 4.138, 4.147, 4.156, 4.165, 4.174, 4.183, 4.192, 4.201, 4.21, 4.218, 4.226, 4.234, \n4.242, 4.25, 4.258, 4.266, 4.274, 4.282, 4.29, 4.299, 4.308, 4.317, 4.326, 4.335, 4.344, 4.353, 4.362, 4.371, 4.38, 4.388, 4.396, 4.404, 4.412, 4.42, 4.428, \n4.436, 4.444, 4.452, 4.46, 4.469, 4.478, 4.487, 4.496, 4.505, 4.514, 4.523, 4.532, 4.541, 4.55, 4.5582, 4.5664, 4.5745, 4.5827, 4.5909, 4.5991, 4.6073, \n4.6155, 4.6236, 4.6318, 4.64, 4.65, 4.66, 4.67, 4.68, 4.69, 4.7, 4.71, 4.72, 4.73, 4.74, 4.752, 4.764, 4.776, 4.788, 4.8, 4.812, 4.824, 4.836, 4.848, 4.86, 4.869, \n4.878, 4.887, 4.896, 4.905, 4.914, 4.923, 4.932, 4.941, 4.95, 4.955, 4.96, 4.965, 4.97, 4.975, 4.98, 4.985, 4.99, 4.995, 5]\nlet result = array[0]   // start with first value of array\nlet resultIndex = 0;\n\n\narray.forEach((el, index) => {\n\nif (Math.abs(el - msg.payload)  < Math.abs(result -msg.payload)) {\nresult = el;\nresultIndex = index;\n}\n})\nmsg.array = array;\nmsg.result = result;\nmsg.resultIndex = resultIndex;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":690,"y":220,"wires":[["14d47e3f.d0af32","e2493e5b.b914c"]]},{"id":"824360ff.bdaa9","type":"debug","z":"3e70b103.f9c7de","name":"Slider","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":950,"y":500,"wires":[]},{"id":"14d47e3f.d0af32","type":"ui_text","z":"3e70b103.f9c7de","group":"cf677043.b89ff","order":1,"width":0,"height":0,"name":"","label":"text","format":"{{msg.resultIndex}}","layout":"row-left","x":940,"y":220,"wires":[]},{"id":"e2493e5b.b914c","type":"debug","z":"3e70b103.f9c7de","name":"Calc","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":950,"y":420,"wires":[]},{"id":"8fdfa66f.e42aa8","type":"range","z":"3e70b103.f9c7de","minin":"0","maxin":"150","minout":"0","maxout":"1024","action":"clamp","round":true,"property":"payload","name":"","x":420,"y":220,"wires":[["75fbd248.66bc9c","824360ff.bdaa9"]]},{"id":"cf677043.b89ff","type":"ui_group","z":"","name":"Test","tab":"43958b31.dce714","order":1,"disp":true,"width":"6","collapse":false},{"id":"43958b31.dce714","type":"ui_tab","z":"","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
If you look at the debug message, it seems to only see an array of [1021] and not the full 1025
Do you realize you only have 1021 values in the function node array you build?
:flushed:
coppied from excel - 1025 cells - did not count them in the flow.
:flushed:
If you paste the flow into a text editor, delete the bits round the array so you just have the numbers left and then search for comma you will find (assuming that your editor tells you how many it finds, as gedit does for example) that there are 1020 of them, so that does suggest that @zenofmud is correct, 1021 values.
Were there some empty cells in the spreadsheet possibly?
Hi All
Re-entered the information, and now i get 1025, not sure what went wrong...PEBKAC...
