How to increase array length? I have to store move then 20K records in array
What do you mean? you give limited info.
If you you mean you only see 1000 in debug sidecar, that is because the sidebar truncates for performance reasons the array is still there in memory.
e.g array size 25000
[{"id":"3decb5f518882686","type":"subflow","name":"live debug","info":"<A href=\"http://127.0.0.1:1880/debug\">localhost/debug</a>","category":"","in":[{"x":240,"y":160,"wires":[{"id":"45dbf990.ba2408"}]}],"out":[{"x":560,"y":160,"wires":[{"id":"45dbf990.ba2408","port":1}]}],"env":[{"name":"debug_name","type":"str","value":"Debug","ui":{"label":{"en-US":"Name"},"type":"input","opts":{"types":["str"]}}},{"name":"debug_property","type":"str","value":"msg","ui":{"label":{"en-US":"Property Path"},"type":"input","opts":{"types":["str"]}}},{"name":"pass_debug_property","type":"bool","value":"false","ui":{"label":{"en-US":"Pass Property Path"},"type":"input","opts":{"types":["bool"]}}}],"meta":{"module":"Live_debug","type":"common","version":"0.0.1"},"color":"#DDAA99"},{"id":"45dbf990.ba2408","type":"function","z":"3decb5f518882686","name":"format time nicely","func":"let msg1 = {payload: RED.util.cloneMessage(msg)};\nmsg1.payload.debug_property = msg.debug_property || env.get(\"debug_property\") || \"msg\"\ntry {\n msg1.payload.debug_property_array = RED.util.normalisePropertyExpression(msg1.payload.debug_property)\n}\ncatch(error){\n msg.payload = error;\n msg1.payload.error = error;\n}\nmsg1.payload.debug_name = env.get(\"debug_name\") || msg._msgid || \"name error\"\nmsg1.payload.pass_debug_property = env.get(\"pass_debug_property\") || false\nreturn [msg1,msg];","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":390,"y":120,"wires":[["50da04b3.af25fc"],[]]},{"id":"50da04b3.af25fc","type":"websocket out","z":"3decb5f518882686","name":"","server":"985ecbc7.67a138","client":"","x":680,"y":120,"wires":[]},{"id":"1787be40.e87842","type":"http in","z":"3decb5f518882686","name":"","url":"/debug","method":"get","upload":false,"swaggerDoc":"","x":330,"y":40,"wires":[["1857548e.e7a8ab"]]},{"id":"1857548e.e7a8ab","type":"template","z":"3decb5f518882686","name":"Simple Web Page","field":"payload","fieldType":"msg","format":"html","syntax":"mustache","template":"<!DOCTYPE HTML>\n<html>\n <head>\n <style>\n span.debug_name {\n color: black;\n }\n span.debug_error{\n color: red;\n }\n span.debug_date{\n color:blue;\n }\n pre[id^='json_data_']{\n font-size:20px;\n background-color: ghostwhite;\n border: 1px solid silver;\n padding: 10px 20px;\n margin: 20px; \n white-space: pre-wrap;\n }\n .json-key {\n color: olive;\n }\n .json-value {\n color: navy;\n }\n .json-string {\n color: brown;\n }\n\n </style>\n <title>Debug Messages</title>\n <script type=\"text/javascript\">\n var ws;\n var wsUri = \"ws:\";\n var loc = window.location;\n console.log(loc);\n if (loc.protocol === \"https:\") { wsUri = \"wss:\"; }\n // This needs to point to the web socket in the Node-RED flow\n wsUri += \"//\" + loc.host + loc.pathname.replace(\"debug\",\"ws/debug\");\n\n function wsConnect() {\n console.log(\"connect\",wsUri);\n ws = new WebSocket(wsUri);\n ws.onmessage = function(msg) {\n segments = document.getElementById('json_data').innerHTML;\n var paused = document.getElementById('paused').innerText === \"Pause\";\n var data;\n var line = \"\";\n var error = \"\";\n var date = new Date().toISOString();\n // parse the incoming message as a JSON object\n try { \n data = JSON.parse(msg.data);\n } catch (json_error) {\n data = {error: [\"json parse error\", json_error]};\n }; \n if(!data.error){\n var debug_name = data.debug_name ;\n var debug_property = data.debug_property_array;\n var original_property = data.debug_property;\n if(!data.pass_debug_property) delete data.debug_property;\n delete data.pass_debug_property;\n delete data.debug_property_array;\n delete data.debug_name;\n debug_property.slice(1).forEach((prop, index) => {\n if(data[prop]) { \n data = data[prop];\n }else{\n error = \"Property path Error on or after - \" + debug_property[index];\n }\n });\n\n line = `<div id=\"element${date}\">\n <hr/>\n <span class=\"debug_name\">${debug_name}</span> <span class=\"debug_date\">${date}</span> \n <span class=\"debug_orginal\">${original_property}</span> <span class=\"debug_error\">${error}</span> \n <button title=\"copy\" alt=\"copy\" onclick=\"copy_text('json_data_${date}')\"> ❒ </button>\n <button title=\"delete\" alt=\"delete\" onclick=\"delete_text('element${date}')\"> ❌ </button> \n <span class=\"json_data\">\n <pre id=\"json_data_${date}\"><code id=data>${library.json.prettyPrint(data)}</code></pre></span> \n </div>`;\n }else{\n line = `<div id=\"element${date}\">\n <hr/>\n <span class=\"debug_error\">Error: ${JSON.stringify(data.error)}</span> <span class=\"debug_date\">${date}</span> \n <button title=\"delete\" alt=\"delete\" onclick=\"delete_text('element${date}')\"> ❌ </button> \n </div>`;\n }\n // append line to segment\n if(paused){\n document.getElementById('json_data').innerHTML = line + segments;\n }\n }\n ws.onopen = function() {\n // update the status div with the connection status\n document.getElementById('status').innerHTML = \"connected\";\n //ws.send(\"Open for data\");\n console.log(\"connected\");\n }\n ws.onclose = function() {\n // update the status div with the connection status\n document.getElementById('status').innerHTML = \"not connected\";\n // in case of lost connection tries to reconnect every 3 secs\n setTimeout(wsConnect,3000);\n }\n }\n function copy_text(input) {\n // Get the text field\n var copyText = document.getElementById(input).innerText;\n var dummy = document.createElement(\"textarea\");\n document.body.appendChild(dummy);\n dummy.value = copyText;\n dummy.select();\n document.execCommand(\"copy\");\n document.body.removeChild(dummy);\n alert(\"Copied Data to Clipboard\\n\\n\" + copyText)\n }\n function delete_text(input) {\n // Get the text field\n document.getElementById(input).innerHTML = \"\";\n }\n if (!library) var library = {};\n library.json = {\n replacer: function(match, pIndent, pKey, pVal, pEnd) {\n var key = '<span class=json-key>\"';\n var val = '<span class=json-value>';\n var str = '<span class=json-string>';\n var r = pIndent || '';\n if (pKey)\n r = r + key + pKey.replace(/[\": ]/g, '') + '\"</span>: ';\n if (pVal)\n r = r + (pVal[0] == '\"' ? str : val) + pVal + '</span>';\n return r + (pEnd || '');\n },\n prettyPrint: function(obj) {\n var jsonLine = /^( *)(\"[\\w]+\": )?(\"[^\"]*\"|[\\w.+-]*)?([,[{])?$/mg;\n return JSON.stringify(obj, null, 4)\n .replace(/&/g, '&').replace(/\\\\\"/g, '"')\n .replace(/</g, '<').replace(/>/g, '>')\n .replace(jsonLine, library.json.replacer);\n }\n \n };\n function pause() {\n var element_paused = document.getElementById(\"paused\");\n paused = (element_paused.innerText === \"Resume\") ? \"Pause\" : \"Resume\";\n element_paused.innerText = paused;\n }\n \n </script>\n </head>\n <body onload=\"wsConnect();\" onunload=\"ws.disconnect();\">\n <font face=\"Arial\">\n <h1>Debug Messages <button id=\"paused\" value=\"pause\" onclick=\"pause()\">Pause</button> </h1>\n <div id=\"json_data\"></div>\n <hr/>\n <div id=\"status\">unknown</div>\n </font>\n </body>\n</html>\n","x":550,"y":40,"wires":[["42a28745.bd5d78"]]},{"id":"42a28745.bd5d78","type":"http response","z":"3decb5f518882686","name":"","x":730,"y":40,"wires":[]},{"id":"985ecbc7.67a138","type":"websocket-listener","z":"65617ffeb779f51c","path":"/ws/debug","wholemsg":"false"},{"id":"609931113ccf23c0","type":"inject","z":"d1395164b4eec73e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":100,"y":3500,"wires":[["74cd2a7b6d0a93fd"]]},{"id":"8c5aa69b5884130c","type":"debug","z":"d1395164b4eec73e","name":"debug 2465","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":350,"y":3500,"wires":[]},{"id":"74cd2a7b6d0a93fd","type":"function","z":"d1395164b4eec73e","name":"function 151","func":"msg.payload = Array(25000).fill(0)\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":230,"y":3500,"wires":[["8c5aa69b5884130c","1292a93a8babfac9"]]},{"id":"1292a93a8babfac9","type":"subflow:3decb5f518882686","z":"d1395164b4eec73e","name":"","env":[{"name":"debug_property","value":"msg.payload","type":"str"}],"x":380,"y":3600,"wires":[[]],"info":"http://ip:1880/debug"}]
If you go to http://ip_of_node-red:1880/debug you will see the full array.
I have to store 10000-50000 items in array but seems like there is limit of adding element in that number? so is there any setting to increase this number
What makes you think there is a limit?
What do you mean by limit? Javascript arrays can contain up to 2^32 elements, so that should be more than enough. ![]()
Here is some relevant info on the basics of arrays in Javascript:
Furthermore, JS is rather lenient regarding array size, you can push new elements or set indexes without explicitly increasing the size. Here's more info on the length property.
