can you paste the actual template code ? (between 2 lots of 3 backticks ``` ) so we can import it and test. Thanks
[{"id":"6fbb690e.026dc8","type":"ui_template","z":"10e78e6.2249672","group":"37595010.f47f2","name":"","order":18,"width":0,"height":0,"format":"<html lang=\"en-GB\">\n<style>\ntable { empty-cells: show; }\nmd-button.lagre { display: none; }\nmd-switch {\nposition: center; \nheight: 5px;\n}\nmd-switch .md-thumb {\n background-color: red;\n}\nmd-switch .md-bar {\n background-color: gray;\n}\nmd-switch .md-checked .md-thumb {\n background-color: darkgreen; \n}\nmd-switch .md-checked .md-thumb {\n background-color: lightgreen;\n}\n</style>\n<table cellpadding=\"1\" border=\"1\" id=\"table-23\" class=\"table-hover\" style=\"width: 100%; border-collapse: collapse; border: 1px solid black\">\n <thead>\n <tr>\n \n \n <th>Av/på</th>\n \n \n \n </tr>\n </thead>\n <tbody>\n <tr>\n \n <td><md-switch aria-label=\"tank\" class=\"md-switch\" ng-model=\"aktiv\" ng-change=\"send({payload : {row:$index, enabled:aktiv}})\" ng-checked=\"row.aktiv==='true'\" ></md-switch>\n </td>\n \n\n\n \n </tr>\n \n </tbody>\n</table>\n\n</html>\n","storeOutMessages":false,"fwdInMessages":false,"templateScope":"local","x":1045,"y":618,"wires":[[]]},{"id":"37595010.f47f2","type":"ui_group","z":"","name":"Group 1","tab":"3c06c23.3e2443e","order":1,"disp":true,"width":"10","collapse":false},{"id":"3c06c23.3e2443e","type":"ui_tab","name":"Tab 9","icon":"dashboard","order":9}]
here is the problematic code isolated from the table
That example works fine for me. Switches between red (off) and blue (on).
Using Vivaldi (Chromium based) latest build.
13 May 16:36:39 - [info] Node-RED version: v0.20.5
13 May 16:36:39 - [info] Node.js version: v10.15.3
13 May 16:36:39 - [info] Windows_NT 10.0.17763 x64 LE
(On is supposed to be green )...
and can be if you get the CSS selector correct
[{"id":"ddd9826.5cf208","type":"ui_template","z":"68636f36.4163c","group":"831103fa.b7f0a","name":"","order":18,"width":"0","height":"0","format":"\n<style>\ntable { empty-cells: show; }\nmd-button.large { display: none; }\nmd-switch {\nposition: center; \nheight: 5px;\n}\nmd-switch .md-thumb {\n background-color: red;\n}\nmd-switch .md-bar {\n background-color: gray;\n}\nmd-switch.md-checked:not([disabled]) .md-bar {\n background-color: darkgreen !important; \n}\nmd-switch.md-checked:not([disabled]) .md-thumb {\n background-color: lightgreen !important;\n}\n</style>\n<table cellpadding=\"1\" border=\"1\" id=\"table-23\" class=\"table-hover\" style=\"width: 300px; border-collapse: collapse; border: 1px solid black\">\n<thead>\n<tr>\n<th>Av/på</th>\n</tr>\n</thead>\n<tbody>\n<tr>\n<td><md-switch aria-label=\"tank\" class=\"md-switch\" ng-model=\"aktiv\" ng-change=\"send({payload : {row:$index, enabled:aktiv}})\" ng-checked=\"row.aktiv==='true'\" ></md-switch>\n</td>\n</tr>\n</tbody>\n</table>\n\n","storeOutMessages":false,"fwdInMessages":false,"templateScope":"local","x":240,"y":640,"wires":[[]]},{"id":"831103fa.b7f0a","type":"ui_group","z":"","name":"Group 1","tab":"9c79f39c.5ed1c","order":1,"disp":true,"width":"10","collapse":false},{"id":"9c79f39c.5ed1c","type":"ui_tab","name":"Tab 9","icon":"dashboard","order":9}]
dceejay,
your correction of my simple code works great. thank you.
