Hello together,
I need Your help. I would like to receive a message at (for example) 7:00 pm, that the waste will be pick up tomorrow.
This is what I made:
[{"id":"3cabff3a.3305b","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"95697386.bd8e3","type":"server-state-changed","z":"3cabff3a.3305b","name":"Restmüll Tonne","server":"ad8e5e9e.dec0c","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.restmull_collection","entityidfiltertype":"exact","outputinitially":true,"state_type":"str","haltifstate":"2","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":100,"y":440,"wires":[["e99f367f.c025d"],[]]},{"id":"ada1e0f6.fba87","type":"server-state-changed","z":"3cabff3a.3305b","name":"Papier Tonne","server":"ad8e5e9e.dec0c","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.papier_collection","entityidfiltertype":"exact","outputinitially":true,"state_type":"str","haltifstate":"2","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":90,"y":500,"wires":[["e99f367f.c025d"],[]]},{"id":"e568c7e7.e321f","type":"server-state-changed","z":"3cabff3a.3305b","name":"Gelbe Tonne","server":"ad8e5e9e.dec0c","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.gelbe_tonne_collection","entityidfiltertype":"exact","outputinitially":true,"state_type":"str","haltifstate":"2","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":90,"y":560,"wires":[["e99f367f.c025d"],[]]},{"id":"1e620b5a.3a614d","type":"server-state-changed","z":"3cabff3a.3305b","name":"Braune Tonne","server":"ad8e5e9e.dec0c","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.biotonne_collection","entityidfiltertype":"exact","outputinitially":true,"state_type":"str","haltifstate":"2","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":90,"y":620,"wires":[["e99f367f.c025d"],[]]},{"id":"8efbf5e0.c0c5d","type":"time-inject","z":"3cabff3a.3305b","name":"","nameInt":"⏲ 13:03 = Zeitpunkt","positionConfig":"c147288e.624ad","props":[{"p":"","pt":"msgPayload","v":"","vt":"date","o":"","oT":"none","oM":"60000","f":0,"fS":0,"fT":"Millisekunden UNIX-Zeit","fI":"0","next":true,"days":""},{"p":"","pt":"msgTopic","v":"","vt":"str","o":"","oT":"none","oM":"60000","f":0,"fS":0,"fT":"Millisekunden UNIX-Zeit","fI":"0","next":true,"days":""}],"injectTypeSelect":"time","intervalCount":1,"intervalCountType":"num","intervalCountMultiplier":60000,"time":"13:03","timeType":"entered","offset":0,"offsetType":"none","offsetMultiplier":60000,"timeEnd":"","timeEndType":"entered","timeEndOffset":0,"timeEndOffsetType":"none","timeEndOffsetMultiplier":60000,"timeDays":"*","timeOnlyOddDays":false,"timeOnlyEvenDays":false,"timeMonths":"*","timedatestart":"","timedateend":"","property":"","propertyType":"none","propertyCompare":"true","propertyThreshold":"","propertyThresholdType":"num","timeAlt":"","timeAltType":"entered","timeAltDays":"*","timeAltOnlyOddDays":false,"timeAltOnlyEvenDays":false,"timeAltMonths":"*","timeAltOffset":0,"timeAltOffsetType":"none","timeAltOffsetMultiplier":60000,"once":false,"onceDelay":"0.1","recalcTime":2,"x":140,"y":700,"wires":[["e99f367f.c025d"]]},{"id":"e99f367f.c025d","type":"BooleanLogicUltimate","z":"3cabff3a.3305b","name":"","filtertrue":"both","persist":true,"sInitializeWith":"WaitForPayload","triggertopic":"trigger","outputtriggeredby":"all","inputCount":2,"topic":"result","x":400,"y":560,"wires":[["de6c2444.b8195"],[],[]]},{"id":"45e70470.65dc44","type":"api-call-service","z":"3cabff3a.3305b","name":"Kamil informieren","server":"ad8e5e9e.dec0c","version":1,"debugenabled":false,"service_domain":"notify","service":"mobile_app_iphone_x","entityId":"","data":"{ \"message\": \"\"&payload&\"\", \t \"title\": \"Müll Abholung\"\t}","dataType":"jsonata","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":910,"y":560,"wires":[[]]},{"id":"de6c2444.b8195","type":"function","z":"3cabff3a.3305b","name":"Generiere Nachricht","func":"newmsg = {}\n\nnewmsg.payload = { data: { \"message\": msg.data.new_state.attributes.friendly_name + \" wird morgen abgeholt.\"} }\n\nreturn newmsg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":660,"y":560,"wires":[["45e70470.65dc44"]]},{"id":"ad8e5e9e.dec0c","type":"server","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true},{"id":"c147288e.624ad","type":"position-config","name":"Neuss","isValide":"true","longitude":"0","latitude":"0","angleType":"deg","timeZoneOffset":99,"timeZoneDST":0,"stateTimeFormat":"3","stateDateFormat":"12"}]
and this are the problems, that I have:
- I get only a message when I deploy the flow
- at the 13:03 (as example in the flow) I get error: "TypeError: Cannot read property 'new_state' of undefined"
- what should I do with "Gelbe Tonne" and "Braune Tonne" because they are pick up at the same day and in the message, that I get, is only the first one.
Thank You,
best regards,
kamil
