Trying to build message with CHANGE node. Not working
(And template node.)
This is the flow: (Basic)
[{"id":"15ae0152.83044f","type":"inject","z":"675e227d.d158b4","name":"Weekly","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"50 23 * * 0","once":false,"onceDelay":0.1,"x":160,"y":1990,"wires":[["c99fea29.aeaf1"]]},{"id":"c99fea29.aeaf1","type":"moment","z":"675e227d.d158b4","name":"","topic":"","input":"","inputType":"msg","inTz":"Australia/Sydney","adjAmount":0,"adjType":"days","adjDir":"add","format":"YYYY-ww","locale":"en_AU","output":"","outputType":"msg","outTz":"Australia/Sydney","x":390,"y":1990,"wires":[["8ed6e064.5d98e","d8d204f7.310a8"]]},{"id":"8ed6e064.5d98e","type":"change","z":"675e227d.d158b4","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"directory","tot":"msg"},{"t":"set","p":"payload","pt":"msg","to":"log_paths","tot":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":1990,"wires":[["791399b9.493ee","8921a9ee.bfb6d8"]]},{"id":"791399b9.493ee","type":"template","z":"675e227d.d158b4","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{payload}}reboot","output":"str","x":790,"y":1990,"wires":[["74e6ce8a.becc68"]]},{"id":"d8d204f7.310a8","type":"function","z":"675e227d.d158b4","name":"","func":"msg.directory = msg.payload;\n\nvar path = global.get(\"log_paths\");\nmsg.path = path + \"reboot/\";\n\nreturn msg;","outputs":1,"noerr":0,"x":570,"y":2030,"wires":[["d5e9569e.50cea"]]},{"id":"d5e9569e.50cea","type":"debug","z":"675e227d.d158b4","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":710,"y":2100,"wires":[]},{"id":"74e6ce8a.becc68","type":"debug","z":"675e227d.d158b4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":980,"y":1920,"wires":[]}]
Generate timestamp, feed it into moment node to get format YYYY-ww, send that to a change node to set the msg.directory to that path - sort of, into template node to append to the path name, which is held in msg.payload.
Ok, the global stuff:
given log_paths is set to: /media/pi/06BB-C87D/logs/
So at this stage I would expect:
msg.directory to be 2020-12
and
msg.payload to be /media/pi/06BB-C87D/logs/reboot
This is what I get/see:
{"_msgid":"b3cea20a.1254b","topic":"","directory":"2020-12","payload":"/media/pi/06BB-C87D/logs/reboot"}
But if I go down the lower path via the function node I get:
{"_msgid":"b3cea20a.1254b","topic":"","payload":"2020-12","directory":"2020-12","path":"/media/pi/06BB-C87D/logs/reboot/"}
Which looks a lot better than the first one.
Ok, the second one does it a bit differently. I gives me msg.path and msg.directory
Hope you can get what I am wanting to do.
Where's the elephant?
Try using {{{payload}}}reboot in the template node
(I gotta ask)
Why the 3 { ?
In the example in the template node there are only 2.
But thanks for the reply.
Google search 'mustache syntax'
from Mustache Reference
All values are HTML escaped by default. If you want to return unescaped HTML use the triple mustache {{{name}}} . Or you can use {{& name}}
It was knowing it is "mustache syntax"..... Yeah, I have heard of it, but just hadn't put the two together.
