I'm getting data through REST API for flow meters I need to show it on the insights hub through MindConnect Lib. But MindConnect Library has an expiration date and it needs to be renewed manually. Is it possible for node-red to regenerate the onboarding key .
If you were to explain what the manual renewal process is, then I feel sure that someone can help.
I have instances in NR that require expiring tokens to be renewed, these are all done within NR once it becomes aware of an expired Token (Onboarding Key??).
Also this is in the wrong Category. This one is for people developing Nodes to use with NR, not for flows.
