Missing nodes, old lockfile and incomplete registry
Good evening,
My Rpi4 sdcard broke. New sdcard, new node-RED LTS (v22.14.0) and npm (11.2.0) installation. My flows are back but I'm missing a lot of nodes and when I try to install them I get this message for every node I'm missing:
npm warn old lockfile
npm warn old lockfile The package-lock.json file was created with an old version of npm,
npm warn old lockfile so supplemental metadata must be fetched from the registry.
npm warn old lockfile This is a one-time fix-up, please be patient...
npm error code ENOVERSIONS
npm error No versions available for < node name>
These are warnings but the message: " this is a one-time fix-up, please be patient..." doesn't reassure me.
Have they been removed from the registry (https://registry.npmjs.org/)?
It might be worth trying without the old lock file as this will ensure the newest versions of all the dependencies are used, which may skip the missing nodes.
Stop Node-RED, delete the lock file, you don't need it. Check that your package.json file contains the expected nodes, delete the node_modules folder and then do a npm install.
Thank you guys for reading and advice :+1:
I followed your advice but unfortunately I kept getting the above messages, even after a reinstall of node-red.
Because node-RED was the 1st only installation I thought it would be better to start from scratch. Removed the sdcard and reinstalled Pi OS and ran the node-RED installation script (what beautiful scripts!). Then I installed all missing nodes...without any problems. The next step is to restore the backups of my flows. I have confidence :wink:
