Missing semicolon in style section of ui_base.html
I don't know if it is the right place to say. Maybe it is better to directly submit an issue or raise a PR but as it is not yet released I prefer to do so.
On the latest master of dashboard on github, a semicolon is missing on line 4 :
 :root {
     --nr-db-dark-text: #444;
     --nr-db-light-text: #eee
     --nr-db-disabled-text: #999;
hence --nr-db-light-text and --nr-db-disabled-text are not defined.
Let me know if you want me to raise a PR or submit an issue.
thanks for spotting it - no need - will edit right now - but hmm yeah... they ought to be removed from there at some point so new themeing can work here also.
You're welcome.
Just realize that during the test of my custom node (I am using --nr-db-light-text in it ) with latest master from dashboard. I understand I will have to update to fit with new themeing.
Is there something to peek into already?
As per the 1.0 beta post - šŸŽ‰ Node-RED 1.0.0-beta.2 released
Ahh ok in this area :slight_smile:
