I have created a modbus-flex-server using node-red-contrib-modbus so that another PC can log data for energy monitoring. The data transfer works until the Modbus program is closed on the other PC. Then I get the error message:
11 Apr 07:13:56 - [warn] [modbus-flex-server:Server weather station] Error: read ECONNRESET
Once I get the error message, I can no longer read data from the modbus-server until I restart Node-RED.
I also tested this with the program qModMaster:
When I connect and close the program, the error message comes up.
When I connect, disconnect and close the program, the error message doesn't come up.
Can I change something in Node-Red so that the modbus-server works again when the error message comes
Node Red: 2.1.6
node-red-contrib-modbus: 5.16.0
OS: Windows 10
My Flow:
"id": "77de1006ed0ee9ad",
"type": "modbus-flex-server",
"z": "d2ef54c17e2c6eb4",
"name": "Server Wetterstation",
"logEnabled": false,
"serverAddress": "10.46.35.205",
"serverPort": "502",
"responseDelay": "50",
"unitId": 1,
"delayUnit": "ms",
"coilsBufferSize": "0",
"registersBufferSize": "20",
"minAddress": 0,
"splitAddress": "10",
"funcGetCoil": "function getFlexCoil(addr, unitID) {\n\tif (unitID === node.unitId && \n\t\taddr >= node.minAddress && \n\t\taddr <= node.splitAddress) { \n\n\t\treturn node.coils.readUInt8(addr * node.bufferFactor) \n\t} \n}",
"funcGetDiscreteInput": "function getFlexDiscreteInput(addr, unitID) {\n\taddr += node.splitAddress\n\tif (unitID === node.unitId && \n\t\taddr >= node.splitAddress && \n\t\taddr <= node.splitAddress * 2) { \n\n\t\treturn node.coils.readUInt8(addr * node.bufferFactor) \n\t} \n}",
"funcGetInputRegister": "function getFlexInputRegister(addr, unitID) { \n\tif (unitID === node.unitId && \n\t\taddr >= node.minAddress && \n\t\taddr <= node.splitAddress) { \n\n\t\treturn node.registers.readUInt16BE(addr * node.bufferFactor) \n\t} \n}",
"funcGetHoldingRegister": "function getFlexHoldingRegsiter(addr, unitID) { \n\taddr += node.splitAddress\n\tif (unitID === node.unitId && \n\t\taddr >= node.splitAddress && \n\t\taddr <= node.splitAddress * 2) { \n\n\t\treturn node.registers.readUInt16BE(addr * node.bufferFactor) \n\t} \n}",
"funcSetCoil": "function setFlexCoil(addr, value, unitID) { \n\tif (unitID === node.unitId && \n\t\taddr >= node.minAddress && \n\t\taddr <= node.splitAddress) { \n\n\t\tnode.coils.writeUInt8(value, addr * node.bufferFactor) \n\t} \n}",
"funcSetRegister": "function setFlexRegister(addr, value, unitID) { \n\taddr += node.splitAddress\n\tif (unitID === node.unitId && \n\t\taddr >= node.splitAddress && \n\t\taddr <= node.splitAddress * 2) { \n\n\t\tnode.registers.writeUInt16BE(value, addr * node.bufferFactor) \n\t} \n}",
"showErrors": true,
"x": 920,
"y": 280,
"id": "130d97601d6dd247",
"type": "function",
"name": "write 0-1",
"func": "var value=msg.payload;\nbuf=Buffer.alloc(4);\nbuf.writeFloatBE(value);\nvar value1=(buf[0]*256+buf[1]);\nvar value2=(buf[2]*256)+buf[3];\n\nmsg.payload = { 'value': value1,\n 'register': 'holding',\n 'address': 0 ,\n 'disableMsgOutput' : 1 \n};\n\nnode.send(msg); \n msg.payload = { 'value': value2,\n 'register': 'holding',\n 'address': 1 ,\n 'disableMsgOutput' : 1\n };\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 620,
"y": 120,
"77de1006ed0ee9ad"
"id": "62d87a0b86a3d9c1",
"type": "function",
"name": "write 4-5",
"func": "var value=msg.payload;\nbuf=Buffer.alloc(4);\nbuf.writeInt32BE(value)\nvar value1=(buf[0]*256+buf[1]);\nvar value2=(buf[2]*256)+buf[3];\n\nmsg.payload = { 'value': value1,\n 'register': 'holding',\n 'address': 4 ,\n 'disableMsgOutput' : 1 \n};\n\nnode.send(msg); \n msg.payload = { 'value': value2,\n 'register': 'holding',\n 'address': 5 ,\n 'disableMsgOutput' : 1\n };\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 620,
"y": 280,
"77de1006ed0ee9ad"
"id": "89d3ef35643e0908",
"type": "function",
"name": "write 2-3",
"func": "var value=msg.payload;\nbuf=Buffer.alloc(4);\nbuf.writeFloatBE(value);\nvar value1=(buf[0]*256+buf[1]);\nvar value2=(buf[2]*256)+buf[3];\n\nmsg.payload = { 'value': value1,\n 'register': 'holding',\n 'address': 2 ,\n 'disableMsgOutput' : 1 \n};\n\nnode.send(msg); \n msg.payload = { 'value': value2,\n 'register': 'holding',\n 'address': 3 ,\n 'disableMsgOutput' : 1\n };\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 620,
"y": 200,
"77de1006ed0ee9ad"
"id": "e790070a8061b4d8",
"type": "function",
"name": "write 6-7",
"func": "var value=msg.payload;\nbuf=Buffer.alloc(4);\nbuf.writeFloatBE(value);\nvar value1=(buf[0]*256+buf[1]);\nvar value2=(buf[2]*256)+buf[3];\n\nmsg.payload = { 'value': value1,\n 'register': 'holding',\n 'address': 6 ,\n 'disableMsgOutput' : 1 \n};\n\nnode.send(msg); \n msg.payload = { 'value': value2,\n 'register': 'holding',\n 'address': 7 ,\n 'disableMsgOutput' : 1\n };\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 620,
"y": 360,
"77de1006ed0ee9ad"
"id": "f310c64d0638c449",
"type": "function",
"name": "write 8-9",
"func": "flow.set('Regen_ges',msg.payload); //Regenmenge speichern\n\nvar value=msg.payload;\nbuf=Buffer.alloc(4);\nbuf.writeFloatBE(value);\nvar value1=(buf[0]*256+buf[1]);\nvar value2=(buf[2]*256)+buf[3];\n\nmsg.payload = { 'value': value1,\n 'register': 'holding',\n 'address': 8 ,\n 'disableMsgOutput' : 1 \n};\n\nnode.send(msg); \n msg.payload = { 'value': value2,\n 'register': 'holding',\n 'address': 9 ,\n 'disableMsgOutput' : 1\n };\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 620,
"y": 440,
"77de1006ed0ee9ad"
"id": "702dd68013e3558d",
"type": "comment",
"name": "Modbus Client für RESMA",
"info": "",
"x": 930,
"y": 200,
"id": "47ee50e4b162133b",
"type": "status",
"scope": [
"77de1006ed0ee9ad"
"x": 840,
"y": 100,
"c4b19bc781c90da0"
"id": "c4b19bc781c90da0",
"type": "debug",
"name": "ModbusServer",
"active": true,
"tosidebar": true,
"console": true,
"tostatus": false,
"complete": "true",
"targetType": "full",
"statusVal": "",
"statusType": "auto",
"x": 1010,
"y": 100,
