Modbus-getter working but flex-getter not working
I am trying to rebuild a project that I have that;s running correctly on a second rpi 3b+
The underlying software on both boards are the same as far as I know.
Here some data:
afbeelding
I managed to use modbus-flex-connection, that is working fine.
One thing I am also trying to change is, to use modbus-flex-getter instead of modbus-getter.
I have them both side by side, to test, the modbus-getter is working fine, but the flex-getter, I can't get to work.
modbus-getter is configured as follows:
Function "Prepare" in front of the flex-getter, looks like this:
afbeelding
afbeelding
The status of flex-getter doesn't change if I force the inject node. Nothing comes out in the debug node.
I know there are many questions about this subject as well as many answers also. But I can't find any answer for my problem. Maybe also it can be something stupid that I overlooked. Anyone has ideas?
OK, after a long time, I see my stupid mistake.
Msg1, should really be msg1.payload
Right, problem solved!
