Modbus Read and Write float32 values - Precision issue or setup issue
Dear everyone,
I'm working on a node to achieve float32 values read and write based on IEEE754 (real type on PLC's)
So i have a flow to inject a float value in buffer parser and then parser maker to split that into 2 words of 16bit integers (so we can execute a modbus write).
Then i reverse the process with another parser to get back the same value. (but this needs a swap 16 operation). This is what i'm not sure now, if there is a mistake on my setup, and this amplifies my concern because we have also precision error after 4 decimal digits.
On modbus PLC's we just write the 32 bits straight in 2 words by pointing to the starting register, and then read back the same real value by pointing on the same starting register.
Is the result reasonable or there is a setup mistake ?
Below is the flow used:
        "id": "9be00b9bab774a27",
        "type": "inject",
        "z": "f9ec28042044c16a",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "4893.37207645",
        "payloadType": "num",
        "x": 220,
        "y": 100,
                "9f85b0f26fee4365"
        "id": "ea646b374b59410b",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "payload",
        "statusType": "auto",
        "x": 1110,
        "y": 100,
        "id": "fdb414cc9c0746f9",
        "type": "modbus-write",
        "name": "localhost",
        "showStatusActivities": false,
        "showErrors": true,
        "showWarnings": true,
        "unitid": "1",
        "dataType": "MHoldingRegisters",
        "adr": "1000",
        "quantity": "2",
        "server": "386f2a0ac05453c3",
        "emptyMsgOnFail": false,
        "keepMsgProperties": false,
        "delayOnStart": false,
        "startDelayTime": "",
        "x": 920,
        "y": 100,
                "ea646b374b59410b"
        "id": "9f85b0f26fee4365",
        "type": "buffer-maker",
        "name": "real to buffer",
        "specification": "spec",
        "specificationType": "ui",
        "items": [
                "name": "Voltage",
                "type": "floatle",
                "length": 1,
                "dataType": "msg",
                "data": "payload"
        "swap1": "",
        "swap2": "",
        "swap3": "",
        "swap1Type": "swap",
        "swap2Type": "swap",
        "swap3Type": "swap",
        "msgProperty": "payload",
        "msgPropertyType": "str",
        "x": 450,
        "y": 100,
                "e89f3d1c41906520",
                "e45569a956b055f6"
        "id": "e89f3d1c41906520",
        "type": "buffer-parser",
        "name": "buffer 2 words",
        "data": "payload",
        "dataType": "msg",
        "items": [
                "type": "uint16le",
                "name": "word1",
                "offset": 0,
                "length": 1,
                "offsetbit": 0,
                "scale": "1",
                "mask": ""
                "type": "uint16le",
                "name": "word2",
                "offset": 2,
                "length": 1,
                "offsetbit": 0,
                "scale": "1",
                "mask": ""
        "swap1": "",
        "swap2": "swap16",
        "swap3": "",
        "resultType": "value",
        "resultTypeType": "output",
        "multipleResult": false,
        "fanOutMultipleResult": false,
        "setTopic": false,
        "outputs": 1,
        "x": 700,
        "y": 100,
                "fdb414cc9c0746f9",
                "63e040941a10433f"
        "id": "63e040941a10433f",
        "type": "debug",
        "name": "debug 1",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 900,
        "y": 200,
        "id": "e45569a956b055f6",
        "type": "debug",
        "name": "debug 2",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "x": 640,
        "y": 180,
        "id": "99ccf7a240bbabe8",
        "type": "inject",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "4893.37000000000000000",
        "x": 250,
        "y": 220,
                "9f85b0f26fee4365"
        "id": "a00b6808469ed203",
        "data": "payload",
        "dataType": "msg",
        "items": [
                "type": "floatle",
                "name": "item1",
                "offset": 0,
                "length": 1,
                "offsetbit": 0,
                "scale": "1",
                "mask": ""
        "swap1": "swap16",
        "swap2": "",
        "swap3": "",
        "resultTypeType": "return",
        "setTopic": false,
        "outputs": 1,
        "x": 550,
        "y": 300,
                "7bc3c0f57af030c4"
        "id": "272d08a838e76627",
        "type": "modbus-read",
        "name": "read float",
        "topic": "",
        "logIOActivities": false,
        "showErrors": false,
        "unitid": "1",
        "dataType": "HoldingRegister",
        "adr": "1000",
        "quantity": "2",
        "rate": "1",
        "rateUnit": "h",
        "useIOFile": false,
        "ioFile": "",
        "useIOForPayload": false,
        "x": 220,
        "y": 300,
                "a00b6808469ed203"
        "id": "7bc3c0f57af030c4",
        "type": "debug",
        "name": "debug 4",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "x": 780,
        "y": 300,
        "id": "bfce9582d6b554bd",
        "type": "inject",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "4893.372",
        "x": 200,
        "y": 160,
                "9f85b0f26fee4365"
        "id": "7bc4f8f6c5e05361",
        "type": "modbus-server",
        "name": "local_modbus_server",
        "logEnabled": true,
        "hostname": "0.0.0.0",
        "serverPort": "2000",
        "responseDelay": 100,
        "delayUnit": "ms",
        "coilsBufferSize": 10000,
        "holdingBufferSize": 10000,
        "inputBufferSize": 10000,
        "discreteBufferSize": 10000,
        "showErrors": true,
        "showStatusActivities": true,
        "x": 1200,
        "y": 240,
        "id": "386f2a0ac05453c3",
        "type": "modbus-client",
        "clienttype": "tcp",
        "bufferCommands": true,
        "stateLogEnabled": false,
        "queueLogEnabled": false,
        "failureLogEnabled": true,
        "tcpHost": "127.0.0.1",
        "tcpPort": "2000",
        "tcpType": "DEFAULT",
        "serialPort": "/dev/ttyUSB",
        "serialType": "RTU-BUFFERD",
        "serialBaudrate": 9600,
        "serialDatabits": 8,
        "serialStopbits": 1,
        "serialParity": "none",
        "serialConnectionDelay": 100,
        "serialAsciiResponseStartDelimiter": "0x3A",
        "unit_id": 1,
        "commandDelay": 1,
        "clientTimeout": 1000,
        "reconnectOnTimeout": true,
        "reconnectTimeout": 2000,
        "parallelUnitIdsAllowed": true,
        "showLogs": true
Any comments appreciated.
Is that not the float type that the buffer parser already supports?
yes, in theory it is.
I'm just wondering why there is such a precision difference and why the reading flow needs swap16 to get the same data back.
